RV.Net Open Roads Forum: Class A Motorhomes: Inverter Question
 > Inverter Question
bdemattia
Full Timer - Florida right now
Good Sam RV Club
Posted: 11/07/09 11:15am Link  |  Quote  |  Print  |  Notify Moderator
Never thought of it before but my question is do you keep your inverter on all the time? Had some power fluctuations at a recent CG and I asked a neighbor if he lost 50 Amp like I did that night. He told me he wouldn't really know if it went off and came back on while he was sleeping as his inverter kicks in and all of his clocks keep working. I knew the power was off as several of our clocks were flashing. So is it best to just keep the inverter on?
Tom N
Sarver, PA/Crystal River, FL/Indiana, PA
Posted: 11/07/09 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Your batteries will eventually deplete if the inverter is left on without power. I never leave mine on.
Sarver, PA/Crystal River, FL/Indiana, PA · FMCA 335149 · Mystic Knights of the Sea
2005 Suncruiser 38R · W24 chassis, no chassis mods needed · 2003 Honda Civic EX · 2008 Honda Odyssey EX-L
BigSkyBob
Western Montana
Good Sam RV Club
Posted: 11/07/09 11:24am Link  |  Quote  |  Print  |  Notify Moderator
I've never turned off my inverter.
2008 Monaco Camelot 40PDQ, 4 slides, 2008 Dodge Ram 1500 Hemi Quadcab 4x4. Blue Ox, Garmin 7200 GPS, Doran Pressure pro on all 10, M&G Brake, 50 amp SurgeGuard, FMCA, Coachnet.
Once you're dead you have lost a very important part of your life.
bdemattia
Good Sam RV Club
Posted: 11/07/09 11:26am Link  |  Quote  |  Print  |  Notify Moderator
If the inverter doesn't kick in and provide power off the batteries until the shore power or generator is removed how would the batteries run down?
* This post was edited 11/07/09 11:33am by bdemattia *
hwybnb
Posted: 11/07/09 11:35am Link  |  Quote  |  Print  |  Notify Moderator
My 600 watt inverter draws about 2 amps in idle (standby) mode. I leave if off except when using it.
Fishinghat
Western Washington, USA
Posted: 11/07/09 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
In six years, I've never turned mine off. I'm normally connected to shore power at home or while at a rally or in Yuma for the winter. When boondocking, I run the generator twice a day to keep the house batteries charged up.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
JFG
TN
Posted: 11/07/09 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
The inverter should "kick in" as soon as there is a demand for it. I've never cut mine off.
Fred
2chiefsRus
USA Somewhere
Posted: 11/07/09 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
We leave ours on all the time as we are moving down the road and when we are plugged into shore power. We do shut if off when we are boondocking only turning it on when we actually want/need it.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2003 Odyssey
Two cats - Kitty & Casey (19 & 16 years old)
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what's left.
kd8wdave
Middletown,OH
Good Sam RV Club
Posted: 11/07/09 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is only on when I need it. It doesn't come on automatically, it's not that fancy. My coach didn't come with one, so I added it. Was a real good buy at Dayton Hamvention, 1000w, and I have it set up for 600w max. It works just fine.
cheers
gswcgi
Wandering
Posted: 11/07/09 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Rarely ever turn ours on even when I dry camp. Either plugged into pole power or use the generator. The first two years I owned this rig I left it on all the time and burned out a mother board. Had the board replaced and the Xantrex tech told me no sense to have it on unless you are using it, I don't use it!!
'03 Safari, DP, 36" Nissan 4X4 toad
 > Inverter Question
