RV.Net Open Roads Forum: Fifth-Wheels: Upside down handle on hitch
 > Upside down handle on hitch
Fifth-Wheels Related Tips
RonandConni
Greentown In
Good Sam RV Club
Posted: 11/08/09 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
I flipped mine down several years ago and have not had any problems. I am 6' tall so I do not have any problems reaching the handle. My wife can not reach the handle but that is ok cause it is not her job.
WE GO WHERE WE ARE TOWED!
Ron and Conni
Greentown, In
Cedar Creek 29LRLBS
Ford F-250 6.0 Diesel
jgallego
Deer Park, Texas
Good Sam RV Club
Posted: 11/08/09 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Mine was installed that way I have a quad fold cover on the bed.
Jaime
2009 Heartland Big Country 3355
5500 Onan Gold, Ultra Fab Leveling System, Dual Air
TV 2007 Chevrolet 2500HD Crewcab
Duramax/Allison, Prodigy, Firestone Ride Rite
elwood1944
Mid Michigan
Posted: 11/08/09 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Works good for me, I have had mine that way since we picked up our fiver
John Jane and "Little Dude"
2007 Chevy Silverado Classic 2500HD 4X4
EC\SB 6.0/ 4:10
2007 Jayco Jay Flight FW RKS 27.5
rick83864
Sandpoint, ID
I should have explained better, I have the DRW fender to contend with. I can't reach the lock unless truck has weight on it.
06 Dodge 3500 Laramie 4x4 Dually
5.9 Cummins HO Automatic,Jacobs brake, Dodge Navigation
06 Grand Junction 34' Mor/ryde, 5500 Onan genny, Dual A/C, Fireplace
21500 GVW
T-10 Parabolic
North Carolina
Posted: 11/08/09 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
With the hitch tilted up add a wood wedge between the jaws and the body of the hitch. This will tilt the handle down enough to close your cover.. Just remember to remove the wood wedge before trying to hook-up... T-10
2005 King Ranch, 350 DRW. CC, 8' bed, 4X4 6.0 PSD
2004 Jayco Designer Medalion 31rls
Charlie D.
Gonzales, La.
Good Sam RV Club
Posted: 11/08/09 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same bed cover as you. Tie that strap around the folding cover when open. Failed to do that one time and left it flapping. Wrapped around the drive shaft and sounded like a cannon going off.
Couldn't get over the side of the road quick enough.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
JJnLilly
Ohio
Posted: 11/08/09 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
I turned mine over long ago. It's not a problem to pull and it sure makes it easy to put my cover on.
2007 Ram 2500 QC CTD
2004 Cougar 290RK
Bill1374
Saratoga Springs, NY
Good Sam RV Club
Posted: 11/08/09 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
I cut mine off just above the first bend and drilled a new hole for the cotter pin. That gave me a straight pull handle that would easily clear my bed cover.
Bill
2006 Heartland Big Horn 3400rl
2007 Dodge quadcab, 6.7 auto
arm
Alberta & Texas
Good Sam RV Club
Posted: 11/08/09 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
I have closed my roll-and-lock cover over the hitch for years now. No Problem. I do clip the strap to something solid when towing so it doesn't flap around and get caught in drive shaft. Don't ask me why I do that now.
2004 Crusier CF26RK
2004 Dodge 2500, Quad Cab,Hemi,4.10, 4X4
2006 Yamaha EF2400iS
CactusJohn
Scottsdale, AZ
Posted: 11/08/09 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Dayle1 wrote:
The downside is having to reach over the bed rails to pull the lever and not having the handle end at shoulder heigth for a straight line pull. When I had a PU with a bed cover, rather than flipping the handle, I was able to drill a different hole and rotate the handle just enough to clear the cover when unhitched yet just above the bed rail when the hitch was in use.
I too drilled a new hole and rotated the handle just enough to clear the cover. Works great.
2007 Ameri-Camp (RIP) Summit Ridge SF27RK 5er
2008 F250 Lariat SuperCab, 6.4L PSD
Reese 16K Kwik-Slide with BedSaver
