RV.Net Open Roads Forum: Technology Corner: Batwing ant
 > Batwing ant
Technology Corner Related Tips
hottubkid
SCHAUMBURG,IL
Posted: 11/08/09 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2004 southwind with the batwing ant that came with it. If I hook uo a converter I get about three stations and I am sitting about fourty miles out of chicago. The amp fot this is buildt into my switch box. But I am wondering if I were to replace the antenna with a different one that would use the same mount would it improve my reception greatly or should I save the money/ Also which antenna would you suggest I switch to?????
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
sch911
Rochester Hills, MI
Posted: 11/08/09 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
A couple of things...
The amp is actually inside the Batwing itself. The wall plate with the LED on it is simply the power supply for that Amp.
You could try the add on "Batwing" clip on upgrade. It's supossed to increase digital reception.
Test & System Engineer (Thermal Systems incl. towing, Detroit 3)
2003 Damon Challenger 348 Class A - F53 Triton V10
Posted by Macintosh
YC 1
Yuba City Calif.
Posted: 11/08/09 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Nope, the batwing is a very good antenna. You can add the little yagi but you probably won't pull in more stations, just a better signal on the ones you get now.
H/R Endeavor 2008
2007 Hummer H3 toad
Ranger Boat
Crazy Ray
Monroe,La
Posted: 11/08/09 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
I would go to DIRECTV. JMO
RET ARMY , DW Donna , Summer (Furkid) . Class A, 2000 Gulf Stream, 4 SAMS 6VOLTS, DIRECTV, YAMAHA 2400 GEN , TOW 97 Wrangler/Honda CR V. Garmin GPS 7200 . "Living Our Dream". NASCAR FAN (14,18,,20,11) Love CO & NM
robsouth
Near Atlanta, GA
Good Sam RV Club
Posted: 11/08/09 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
Sometimes just a little "redirection" of the bat wing and another "scan" on the converter will find more stations. The bat wing is very directional.
Dodge Ram 3500 Cummins Turbo Diesel Dually
Terry 22U
Regal 1900LSR
"Great minds like a think"
Artum Snowbird
Campbell River, B.C., Canada
Posted: 11/08/09 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
not
Mike and Carole
2006 Triple E Regency 27 foot SXL
2005 16.6 Double Eagle
Wheel Estate
Emery, S.D.
Posted: 11/08/09 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
i agree that the bat-wing works pretty good, if it is getting power....can you remove the cable going in the bat wing and check for dc voltage? that will test the power switch and the cable going to the bat-wing. then check the cable to the TV to the switch for damage and connection. after that i would think you would have to change the bat-wing. if you do there is a replacement style just for dig TV....
...on edit....to test for voltage measure from the center pin to the outside shield
Rick & MaryAnn
we accompany, a beagle, sir Cody, drive '06 Phaeton
SMI brake stopping a Jeep liberty toad
othertonka
Stockton, CA
Good Sam RV Club
Posted: 11/08/09 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
You should go to this web site and enter your zip code and that will bring up all of the TV stations within range that you should be able to pick up. It also gives the direction in degrees, (need a compass) that you need to point your antenna. Your antenna receives it's best signal from the side of the batwing that is opposite the side where the Coax cable enters the batwing. So if for instance the chart says channel 3.1 is at 235 Degrees and it is 30 miles away, point the side of your antenna, using the compass, to 235 degrees and then using the Converter menu, select "Auto Scan" or "SCAN" or something that resembles those words, and let the scan run. Make sure that the TV is set to the same channel that you selected on the converter, CH 3 or CH 4. Now if the web site does not show very many channels close enough to your location, you are out of luck.. If there are many stations at different directions than the direction you are pointed to, you will have to reaim your antenna and SCAN again.
So here is the link. Good luck
Antenna web
On edit, one other thing, make sure that your TV is set to "Antenna" and not "Cable"
Here is a link to another post that has a drawing of the "front" of a batwing.
Batwing direction
Scroll down about 3 posts
* This post was edited 11/08/09 07:24pm by othertonka *
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Campinfan
Washtenaw County, Michigan
Posted: 11/13/09 09:13am Link  |  Quote  |  Print  |  Notify Moderator
I installed one of those clip on antennas that attaches to the bat wing---works great. Got more stations.
________
2008 F 250 FX4 4WD, V10, 4.10 Tow Command
35' 2007 Crossroads Cruiser CT32SB
Wonderful Wife and 3 small kids
TXiceman
(Near) Houston,TX
Posted: 11/13/09 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Ading the Wingman to the Batwing, will make the antenna a bit more directional. And another point is there is no such thing as a digital antenna.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
 > Batwing ant
