Fairgrove
Wauseon, Ohio
I am looking at a 2010 Camry with an automatic transmission. I can't find a list that new.
Dan
2003 45ft Monaco Executive
Howard Power Center Steering
Pressure Pro Tire Monitor
4 Solar Panels
Crazy Ray
Monroe,La
Dan, what does the owners manual say? I bet you will need a LUBE Pump from REMCO.
RET ARMY , DW Donna , Summer (Furkid) . Class A, 2000 Gulf Stream, 4 SAMS 6VOLTS, DIRECTV, YAMAHA 2400 GEN , TOW 97 Wrangler/Honda CR V. Garmin GPS 7200 . "Living Our Dream". NASCAR FAN (14,18,,20,11) Love CO & NM
Fairgrove
Wauseon, Ohio
We have one for the weekend on a test drive but no manual only a quick guide.
Dan
womps
Olds
According to remcotowing.com, tow dolly only unless it is a manual transmission.
amxpress
Clayton, NC
Good Sam RV Club
It cannot be towed 4 down.
There are no late model Toyota vehicles (with automatic transmissions)that can be safely towed 4 down without installing an auxillary oil pump for the transmission. i.e. Remco.
Or you can always use a tow dolly.
edited 11/10/09 06:02am by amxpress *
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2008 Palamino Sabre 31RKTS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
Travel in peace, left the M-I-L at the zoo with her relatives...
Bruce Brown
Northern NY
Just an FYI; for a car in the same size class I believe you'll find the Ford Fusion AWD is able to be flat towed with no modifications. The Edge and Flex AWD models are and the AWD system is the same to my understanding.
We tow a manual transmission model Fusion and it makes a wonderful tow vehicle.
And as much as I'm not a fan of Consumer Reports, in their blog titled "Ford Fusion – The best car you don’t know about", even they are saying great things about the Fusion.
Just one snip for the above link; "Two more pluses: Not only does the Fusion have excellent crash-test results but it’s also one of the more reliable cars in our annual auto survey. It is more reliable than the ubiquitous Toyota Camry, an honor it’s held since the Camry’s 2007 redesign."
Take a look.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
wandering1
Ask the dealer.
HR
wolfe10
I would NOT ask the dealer for their advice/knowledge-- it is too likely that they will not know and could even tell you what you want to hear to sell you a car. I WOULD ask the dealer to look at a copy of the Owners Manual.
And the statement that no late model Toyotas are towable 4 wheels down applies ONLY to the automatic transmission models. Toyota does have manual transmission models that ARE towable 4 wheels down, including the Camry.
If you are a member of FMCA, go to this website for a list of what is towable 4 wheels down for each of the last 10 years: http://www.fmca.com/index.php/magazine/towing/204-towing-index
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
Bruce Brown
Northern NY
Be careful with that towing guide as Toyota/Lexus changed the status of some models from "towable" to "NOT towable" after their release. Unfortunately these changes came after some people had bought these for towing and had transmission issues.
brobox
Sunny SW. Florida
Being that the Camry is front wheel drive, only the manual transmission is towable. All automatics in the Camry have to be towed on a dolly.
Chuck
02 Travel Supreme, 2 street side slides
09 Toyota Tacoma 2WD
