RV.Net Open Roads Forum: General RVing Issues: Eletrical Outlets Won't Work
 > Eletrical Outlets Won't Work
General RVing Issues Related Tips
sjones6335
Dracut, MA
Good Sam RV Club
Posted: 11/09/09 10:33am Link  |  Quote  |  Print  |  Notify Moderator
I know this has been asked before & I've read the posts. My problem is my electrical outlets worked last night & now none are working except the tv one. I've checked the fuses, breaker panel, & the GFI in the bath room nothing seems to fix it. Is there a hidden fuse somewhere I'm just not seeing? I have a 2010 Roo 19 if that helps. Please help if you can.
Steve
2005 Chevy Trailblazer LT
2010 Rockwood Roo 19
NORM WADDELL
PENSACOLA FL 32514
Posted: 11/09/09 10:39am Link  |  Quote  |  Print  |  Notify Moderator
If you are talking 110 volt AC,
there will be no FUSES involved;
only circuit breakers and GFI
receptcles. Open and reclose all
circuit breakers......then look
for a second GFI receptacle.
If this doesn't solve the problem,
start removing covers (power OFF)
and look for loose connections.
L NORMAN WADDELL
30 FOOT ALLEGRO
SATURN TOAD
WIFE AND 2 DOGS SUGAR BEAR & COCO BEAR
downtheroad
Puget Sound
Posted: 11/09/09 10:40am Link  |  Quote  |  Print  |  Notify Moderator
I know you said you checked the GFI...but it still sounds like that to me..
Our trailer has 2 GFI's. Maybe you have another one hidden somewhere.
Or maybe the GFI you did check is faulty. This happened to us recently. I replaced it and problem solve.
"If we couldn't laugh we would all go insane"
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Picture
Reese Dual Cam HP
Lots of other stuff nobody cares about
skipnchar
Topeka Kansas USA
Posted: 11/09/09 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Many trailers have as many as four separate GFI circuits. Since you checked one in the bathroom, does THAT outlet work OK?
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
maddog348
Bakersfield,CA
Good Sam RV Club
Posted: 11/09/09 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Possible 'shore power' out & TV receptacle on inverter.??
garry1p
Oklahoma
Good Sam RV Club
Posted: 11/09/09 11:16am Link  |  Quote  |  Print  |  Notify Moderator
If you have 50amp service check the CG circuit breaker one side may be tripped turn off and back on to reset.
If you have a problem that tripped the GFCI then it will not reset until you fix the problem.
Unplug everything that's on the GFCI and then try to reset.
You might call the dealer and ask if you have a hidden GFCI somewhere in the RV.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
advntrs
greenwood, Indiana
Posted: 11/09/09 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Most people (including me) forget to check the GFIs on the outside of the unit. This one will put at least one side of your RV out of business.
"Behind each great fortune,lies a great crime"
lanerd
Ridgecrest, CA
Good Sam RV Club
Posted: 11/09/09 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Another possible culprit may be a circuit breaker on your inverter (if you have one). Also, as advntrs mentioned above, check your outside outlet too for a tripped GFI.
M GO BLUE
Southgate, MI
Posted: 11/09/09 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
GFI's are usually located in the bathroom, kitchen and depending if you have any outside plug there may be one there also...reset them all
ERIC & BEV
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fith wheel
Onan 5500W Marquis Gold gas generator
KEEP A LOOK OUT FOR OUR SPRING 2010 RALLY!
PackerBacker
Home is Montreal Qc & Seasonal is NY Adirondacks
Posted: 11/09/09 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Had something similar happen to me with several outlets suddenly not working. It turned out to be a circuit that was wired directly to the inverter; I reset (pushed) a small white button (next to the green 'on' light) on the inverter and all was fine again.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
My Photos
