RV.Net Open Roads Forum: General RVing Issues: RV Oven
General RVing Issues Related Tips
brenden
rehoboth beach, delaware usa
Posted: 11/09/09 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Our gas oven cooks unevenely, burning outsides and undercooking inside of food. Have been told to put ceramic tile in oven to even out heat distribution. Does this work? What kind of tile? Will a pizza stone on the lower rack do the same thing?
Thanks
Mark & Daryl
Rehoboth Beach De
mark berryman
skipnchar
Topeka Kansas USA
Posted: 11/09/09 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
It probably works OK but so does simply lowering the cooking temp by a few degrees.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
Rolling Condo
South Carolina
Posted: 11/09/09 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it does work either a tile or pizza stone. In addition, check out the oven temps using a oven thermometer. Might need to adjust oven temps. On mine I cut back 25 degrees on my setting.
'90 GMC R2500 7.4L
'90 Avion 34V
Cummins Onan P4300ie
Reese Dual Cam HP
Prodigy
arizonadesertbrat
Where ever the pipeline leads
Posted: 11/09/09 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
I put a pizza stone and one of those cooling racks on top of it, I then put whatever I am baking/roasting on that rack, that allows air to flow all around the pan. It seems to work better. I also picked up a hint the other day, light the pilot and let it burn a few before turning the oven to your desired temp. Also, be sure the oven is all the way heated before you place your food in it. All these things have helped me a lot. I can even do cornbread and rolls without the bottom burning.
btd35
Spokane, WA
Posted: 11/09/09 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
Is the door fitting tightly against the door seal, and is the door seal in good shape. This is very important for even heating in any oven. It is designed to circulate the heat around and then out the upper vent slot. If the door is not sealed tightly, you will get hot and cool spots and the oven thermostat probe won't be reading the proper oven temp either.
A poorly fitting door, (sprung hinges, bad springs, broken door spring, a screw come loose etc.)
As said earlier, be sure the oven is up to heat, minimum 10 min before you put food in. No oven reaches it's proper temperature cycling before 15 min of being on, and actually more like 25-30 min. When calibrating an oven temp, you need to have an oven on for 30 min, then check the temperature.
Tom & Beth
05,Grand Junction 35TMS
99, Dodge 3500 Dually.
Dick_B
Palos Heights, IL USA
Good Sam RV Club
Posted: 11/09/09 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
For immediate responses you could search this Forum for `oven' then search the results for `tile.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
ML
Livingston TX
Posted: 11/09/09 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
Got rid of the RV gas oven and put it a Fisher Paykel dishdrawer then replaced microwave with a Whirlpool Convection Speedcook Oven
The oven grills, bakes, nukes and is very easy to clean. 16" turn table easily accommodates 9x13 cake pan.
ML
Jacksons
columbus,ohio
Posted: 11/09/09 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
qn air bake cookie sheet on lower shelf also does wonders
2002 Rockwood 8272s
2005 Yukon xl Denali 6.0
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
robsouth
Near Atlanta, GA
Good Sam RV Club
Posted: 11/09/09 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Whew!! A lot more expensive than using a tile, cookie sheet, or pizza stone. Got some money you wanna lend?
Dodge Ram 3500 Cummins Turbo Diesel Dually
Terry 22U
Regal 1900LSR
"Great minds like a think"
mynetdude
Grants Pass, OR
Posted: 11/09/09 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
LOLZ
