Lauralee610
California
I am going to tow my trailer to the midwest this spring. I am on a limited budget. I have a Nissan Titan and A Zepplin 181.(see signature) The Nissan has a tow capacity of #9500 and the trailer weighs #4800. Keeping everything in weight range. Do you think I need a weight distributing hitch or sway control. How bad will it be if I don't have one. I will eventually get one but don't think I can afford it before I leave.
Thanks
Peter
Laura
Cricket and Lewis (Cats/Sons)
2005 Great Nissan Titan
2004 Beautiful 18ft Zeppelin
Learjet
Louisiana
Good Sam RV Club
Is the actual tounge weight under 500 lbs? How does it tow right now?
2006 Nissan Titan CC with tow package added Timbrens
2006 KZ Frontier 2303P-F
Dual 6 volt GC batts
Equal-i-zer
Prodigy brake controller
Yamaha EF2600c Tri-Fuel Gen.
in the past...2001 Hurricane 30Q Chevy workhorse
skipnchar
Topeka Kansas USA
The limitation on weight is the receiver on your truck. It should be rated for at least 500 lb. without a WD hitch. The trailer is not supposed to sway but if it should START swaying is a really bad time to go shopping for a means of stopping it. I'd install a friction anti sway bar as insurance against a catastrophe. You PROBABLY don't need it but do you want you and your family to "probably be safe"? Good luck / Skip
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
facory
Mineral Bluff, GA
Good Sam RV Club
For the low cost of a friction type anti-sway bar - do it. I use one made by Reese and don't have any problems on the highways and large trucks. Well worth the investment and should work great on your rig.
2008 20' Cruiser RV Toy Hauler
Dodge Durango 5.9L
Harley 06 VRod
Lauralee610
California
The truck and trailer tow very well without anything. Like towing a pea. My truck hitch is #600 Draw Tite. The manual says the tongue weight is #460 and Oh!! I just looked at the trailer weights combined dry and carrying capacity is #3800. I just looked at Camping World and they have an eaz-lift for $59.00 Now that is doable. Reese is about $139.00. What is the difference between right and left? Do I need to have it installed professionally?
Thanks again
aeohio
New Mexico
Good Sam RV Club
I would ask what it would cost to have it installed at CampingWorld. However if you are mechanically inclined then I doubt it would be all that complicated.
You may also want to look at Craigslist to see if there is anything in your area.
2010 Passport UL 290BH
2006 Ford Expedition Limited
Arn
Ottawa Valley, Ontario, Canada
Simple to install yourself. If you know how to use a tape measure, drill & wrench it can be done quickly. Left & right are just that, left side or right side mount. I went with left side so I could take it off without having to step over the tongue or walk around the truck. The majority seem to be mounted on the right but it also depends on what might be in the way where you need to mount it.
Arn
1958 Me
1963 Her
Sometimes a 2002 granddaughter
Sometimes a 2004 black lab
2010 Rockwood Ultra-Lite Rear Lounge 2604SS
2005 F-150 XLT Super Crew Cab 4x4, 5.4 Triton, 3.73 LS, tow package, Prodigy Controller
Chuck&Gail
In the Colorado Mountains
IMO if you tow without sway control keep speed under 45 mph. Yes, I am serious.
WDH less important, but be careful to not get front wheels on TV too light so steering suffers. Ok as long as you don't fill TV with stuff.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
kfriceman
Ferndale, WA
Lauralee610 wrote: The truck and trailer tow very well without anything. Like towing a pea. My truck hitch is #600 Draw Tite.
That is 600# capacity is for the hitch itself; you need to find out what the tongue weight capacities are for the truck.
-Kevin
2008 Tango 299BHS * 2007 GMC Yukon Denali
Trip count 2009: 7
Nights camped 2009: 33
The Rice Paddy
Learjet
Louisiana
Good Sam RV Club
if you added that hitch to your truck, then your max tow weight is not 9,500 lbs since you don't have the "Big Tow" package. No worries you are still under the tow weight for the non- Big tow Titans.
