RV.Net Open Roads Forum: Tech Issues: white plastic turned yellow
 > white plastic turned yellow
TF36DSMatt
SoCal
Posted: 11/09/09 10:15pm Link  |  Print  |  Notify Moderator
I agree with the Krylon Fuzion... but use the stuff made for plastic:
Krylon Fusion for plastic
billyboy
md
Posted: 11/10/09 04:12am Link  |  Print  |  Notify Moderator
softscrub worked for me, then wax
09 winny adventurer 32h 33 ft towing 015 focus
Gene&Ginny
North Kingstown, RI
Posted: 11/10/09 11:28am Link  |  Print  |  Notify Moderator
RRUGG wrote:
Does any of that stuff work on fiberglass? ...
Awesome and bleach also works on my fiberglass door panels but my doors never seem to get as bad as that trim stuff after a year.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
RRUGG
Newaygo, MI,USA
Posted: 11/10/09 05:51am Link  |  Print  |  Notify Moderator
Does any of that stuff work on fiberglass? Our HR has aluminum siding but fiberglass on the doors. I assume the aluminum and fiberglass matched when new.
RRUGG
2009 Chevrolet Silverado LTZ 1500 4x4 5.3L
2011 Kodiak 281RLGS travel trailer
2011 Egg Camper
2010 Chrysler Town & Country
Good Sam life members
Bob & Grace professional retirees
Camped in 49 states. Missing Hawaii.
sonicsix
Jerry n' Cynthia
Posted: 11/10/09 07:08am Link  |  Print  |  Notify Moderator
Clean it, paint it with spray paint made for plastic and be done with it. Why do it once a year with a cleaner when you can do it just once? I repainted the trim around around the window on our door and the vent cover for the "over the stove" fan. Looks better than new.
Sandia Man
Rio Rancho, NM
Posted: 11/10/09 11:38am Link  |  Print  |  Notify Moderator
I paint mine with plastic paint but may try the cleaners mentioned in a pinch.
BFL13
Victoria, BC
Posted: 11/11/09 05:22pm Link  |  Print  |  Notify Moderator
96Bounder30E wrote:
I sprayed my yellowing refer access door with "oil eater" and the yellowing just ran off leaving the door white again........
Had to try it. I used a spray degreaser I had left from another job called "Extra-strength
Tools and Parts Cleaner" (MotoMaster in this case) on the yellowing cover for the outside shower. It actually worked quite well running off as described above. Amazing.
The warning on the can says it contains toluene,acetone,propane,ethenol,and d-limonene
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
5erTrailerTrash
Anchorage, Alaska
Posted: 11/11/09 08:48pm Link  |  Print  |  Notify Moderator
Toluene and ethanol will both dissolve plastic. It probably works by removing the top layer of the plastic which has oxidized to yellow. The amount removed may be so miniscule as to not matter, but I think you should use it cautiously. Additionally, it will oxidize again eventually. Perhaps paint would be a better option.
96Bounder30E
America is my home!
Posted: 11/11/09 09:05pm Link  |  Print  |  Notify Moderator
I told ya!............I've done it once on my now 14 year old MoHo........I wouldn't do it often but once or twice in 10 years shouldn't be a problem.........
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
igor2brvn
Posted: 11/12/09 09:16pm Link  |  Print  |  Notify Moderator
Paint it using the Krylon Fusion for plastic. It will stay white and easy to clean with soap and water. The harsh cleaning chemicals will erode the "outer skin" and make cleaning more difficult.
From the peak of good living
Eager to be RVing
2011 Cedar Creek Custom 36RE
2008 Ford F-350 CC Lariat DRW 6.4L Diesel
"Ford makes it, International shakes it!"
