RV.Net Open Roads Forum: Tech Issues: Fuel injected portable generators,,,,soon?
 > Fuel injected portable generators,,,,soon?
Tech Issues Related Tips
tpi
Southern CA.
Posted: 11/10/09 12:18am Link  |  Quote  |  Print  |  Notify Moderator
It can't be too much longer..can it?
Honda has 108 and 150 CC fuel injected scooters.
Suzuki has 250 CC fuel injected entry level motorcycle. This is the engine output range for many portable camping generators.
All are equipped with catalyst for cleaner exhaust. The engines compensate the fuel mixture for temperature and elevation. The Honda scooter engines use liquid cooling. Could make for a very quiet clean generator.
SWD
Peoples Socialist Republic of Saskatchewan
Posted: 11/10/09 03:35am Link  |  Quote  |  Print  |  Notify Moderator
Good point, however existing red and blue gen sets are pricey as it is. Seems to me that this would be "excessive" technology for just a simple generator.
Tvov
CT
Posted: 11/10/09 04:11am Link  |  Quote  |  Print  |  Notify Moderator
I certainly can see generators coming out with it. More and more lawn mowers are coming out with fuel injection. Larger generators may already have fuel injection.
2008 F-250 CrewCab 5.4L,
amxpress
Clayton, NC
Good Sam RV Club
Posted: 11/10/09 05:08am Link  |  Quote  |  Print  |  Notify Moderator
This is very true, however, it would be a very costly generator.
Honda's are among the most expensive portable generators I looked at. Adding fuel injection would make them even more expensive.
Water cooling might make it a bit quieter, but it also adds weight and more maintenance. i.e. radiator, water pumps. hoses, etc.
Briggs & Stratton did a study and were able to drastically cut emissions by building their engines to tighter tolerances. Something I'm sure all small engine manufactuers are doing now.
For a generator, the engine stays pretty much at one speed, or close to it, something a carburetor can work well at. I think we're going to see carburetors for a few more years.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2008 Palamino Sabre 31RKTS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
Travel in peace, left the M-I-L at the zoo with her relatives...
Corkey05
Washington State
Good Sam RV Club
Posted: 11/10/09 07:32am Link  |  Quote  |  Print  |  Notify Moderator
And, a carbureted engine with the fuel tank on top doesn't require a high pressure fuel pump. It would seem for a simple device like a generator, simple is better and more reliable.
2008 HR Endeavor PDQ - Blazer 4 Down
FMCA F374292
melton
Glen Allen, Virginia
Posted: 11/10/09 08:10am Link  |  Quote  |  Print  |  Notify Moderator
I installed a 5.5kw fuel-injected Onan Marquis Platinum in my motorhome a few years ago. Model 5.5 HGJAA-600A. Had to tee into the vehicle's fuel return line to the gas tank. The tank already had a seperate pickup tube for the generator. So, it's out there, but it ain't cheap.
On edit, after re-reading the title of the post, i realize that i missed "portable". Sorry about that.
* This post was edited 11/11/09 08:53am by melton *
forrest melton
Trust God, wait patiently, and watch expectantly.
Dr Quick
M'boro, Tn
Good Sam RV Club
Posted: 11/10/09 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Vehicle gas fuel injectors are driven by a pump in the gas tank,(this keeps it cool), that puts out 40 to 60 PSI and it has to run continuously. Also injector is controlled by a computer, and a whole bunch of sensors to continuously adjust fuel flow.
Unless someone can come up with something simpler, I doubt that it will happen.
Dr quick
Generator Jim
Conway, SC
Good Sam RV Club
Posted: 11/10/09 08:51am Link  |  Quote  |  Print  |  Notify Moderator
We all need to go on the ONAN web site and look at the 'Platinum' series of generator sets that have been fuel injected for the past few years. Check Melton's post above.
JimL
Jim & Jane Latour
08 Chevy 3500HD, crew cab, dually, Duramax/Allison
05 Wilderness Advantage AX6 365 BSQS, Onan 3.6KY
Retired AF CMS (E9) Power Generation and Onan RV genset Level III tech
Grand Strand Sams
Blog.rv.net
tpi
Southern CA.
Posted: 11/10/09 09:31am Link  |  Quote  |  Print  |  Notify Moderator
I'd like to see a fuel injected model along side the current lineup. Starting with the 3000 watt unit. Fuel injection may be impractical in the small 1000 watt units while keeping small size and weight. I can see fuel injection in the 2000 watt unit using an air cooled engine. I think the 150 CC liquid cooled Honda scooter engine could be very nice for a super quiet 3000 watt generator. It may gain 10 pounds or so over the current model, and could be on casters. But I can see 6 dB quieter with little or no exhaust odor with 20% lower fuel consumption.
As far as the cost, if this technology is in entry level motorcycles (which cost little or no more than their carbureted competition), it couldn't be too expensive.
Corkey05
Washington State
Good Sam RV Club
Posted: 11/10/09 09:40am Link  |  Quote  |  Print  |  Notify Moderator
I can see fuel injection for on-board RV generators, or whole house stationary generators. But with the small portables, the fuel injection and water cooling seems to bring to it complexity and weight, both enemies of the small lightweight portables.
Anything is do-able, but it seems common sense would keep the portables to a minimum of complexity, while still letting it do it's job.
