RV.Net Open Roads Forum: Tech Issues: What to set acumulator tank pressure to?
 > What to set acumulator tank pressure to?
Tech Issues Related Tips
Center Pin
Fort Langley, BC
Good Sam RV Club
Posted: 11/10/09 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Well with camping over for the year I have been slowly knocking off items on the to-do list. Last weekend I got two Fantastic Fans installed (love them!). This weekend I will cram my upper half into a space that will be so comfortable that I have already made a chiropractor appointment for Monday. This space is where the 2G acumulator tank will go. Being that I do not want to shoe-horn myself into there too many times, I would like to set the pressure first. My water pump is a FlowJet 03526144, the pressure switch max is 50 psi, and from the research I've done the minimum should be 10 psi lower.
What should I set the tank pressure at? I was thinking it should be 42-45 psi, thinking that it will be full before the pump kicks out, and it will empty before it kicks in. Does that sound right?
Trailer: 07 Tango 299BHS
TV: 2004.5 Dodge 610 CTD 3500 QC 48RE 2wd Laramie SRW, FP Gauge, FASS 95/95, Rhino Lining, Hensley Arrow, Reese Signature Series 5er Hitch, Air Bags & Compressor, Canopy, AL Boat Rack.
Been running B100 home brew June 2008!
cathcartww
Stone Harbor, NJ
Good Sam RV Club
Posted: 11/10/09 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
I think you will find that you want it set significantly lower than that. We have one of the small one liter tanks sold for marine and RV use, and it is set around 10 psi. At this pressure, it helps dampen the pulsation and noise of the pump, and keeps the pump from even coming on if you need a little water for something. When you need more water - like for a shower - the pump kicks on, and you run with full pump output pressure. I would start low to minimize pump starts, then if you find you aren't getting enough pressure before the pump kicks on, increase it.
Bill and Kate from Stone Harbor, NJ
with Sunny (the parti poodle) and Molson (the goldendoodle)
1995 Chevy/Quigley 4x4 G20 Van (the "Salty Dog")
2005 Jay Feather 29N (the "Salty Dog House")
Pro Series SC hitch
Bobbo
Memphis, TN
Good Sam RV Club
Posted: 11/10/09 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is 20 psi
Bobbo, Linda and the furry kids (German Shepherd and German Shepherd mix)
2007 Winnebago Outlook WF331C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
C Schomer
Buckeye, Az.
Posted: 11/10/09 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
The air psi needs to be slightly lower than the cutin psi of the pump to get the most drawdown capacity out of the accumulator. I started out by setting the air psi much higher than the pump cutin, then I thoroughly purged all the air out of the water system and let the pump naturally come up to the cutout point. Then I SLOWLY let air out of the bladder til the pump came on, then gave it one tiny pssst extra. This way sets it right on the money without needing to know exactly what the actual pump cutin psi is and no need for gauges to cause any error. Craig
03Dodge QC HO CTD Dually NV5600 4.10 Rear/WD A2K turbo Diablo Predator Quad BF 4" exh PRXB Pacbrake Rancho 9000s FS Airbags Onboard air/in-cab controls HUGE custom intake Custom hauler bed. 98 Sunnybrook 30RLFS 5er.WHOEVER INVENTED WORK DIDN'T HAVE AN RV!
Hoppers4
Port Orchard, WA
Posted: 11/10/09 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
Experimented with mine and found 20 psi to work the best.
08 Winnebago Sightseer 29R
Jim&Peg
Central Ohio
Posted: 11/10/09 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
To set it accuratly you need to know the "kick in" pressure of the pump. For best performance, the accumulator should be set to 2 psi below the kick in pressure of the pump. A little lower will not hurt too much, but you do not want it higher than that.
mbopp
Henrietta, NY, USA
Posted: 11/10/09 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
20-25 PSI in my 2 gallon accumulator workes best for me.
"A bad day of camping is better than a good day at work."
'04 GMC Envoy & '05 Travel Star 21SSO
17' Wenonah Kevlar & 16' Dagger Royalex canoes
http://community.webshots.com/user/mbopp0153
marvmarcy
Polson, MT, USA
Good Sam RV Club
Posted: 11/10/09 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
I recently installed a new ShurFLow 5.7. I kept the existing accumulator tank at 30psi (factory set) because it worked well with my old SureFlow 2.8. The new pump has variable speed with 65psi max. The old pump was single speed with 50psi max.
The tank smoothed out the pulsations and reduced pump run time and cycling. While it may not be optimum, it works so well that I tend to think there is an acceptable range - maybe 20 to 40psi.
If you change the tank pressure be sure it is done with no water pressure on the tank.
JMHO
Marv
2001 Volvo VNL42T420, ISX450/1650, super 10sp w/GearMaster
2003 Newmar Mountain Aire 38RLRK (20K GVWR, tandem duals)
Piaggio MP3 400 scooter
RVing since 1979 - Fulltime since 2000 (mostly CO, MT, NC & Key West)
Retired USAF
You can't take the Fisherman out of this Camper
Ontario, Canada
Good Sam RV Club
Posted: 11/10/09 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
I installed a two or three gallon one about 3 or 4 years ago (Can't remember the exact size, it's about 10-12" in diameter). If I remember correctly the instructions stated the air pressure should be set at 25 lbs. It works very well at that pressure.
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: 2002 Cougar 276EFS & 2005 Laredo 29GS; 2002 GMC 2500HD Ext Cab 4x4; (Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
Golden_HVAC
Fulltime, CA, USA
Posted: 11/10/09 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I set mine at 10 PSI. This allows the most water into the tank with the least amount of water, and then the pressure will stay above 15 PSI until the tank is almost completely empty, then will drop below to 10 PSI as the last drops of water leave the tank.
Remember to check the air pressure every 2-3 years, if you want to.
If you had the air pressure at 30 PSI, then there will be a lot more air, and therefore less water in the tank once it reaches 50 PSI.
Good Luck,
Fred.
