bp122084
Portland, Or
So here where I live it gets down to at the coldest 20 degress (and maybe once a year at that). I would still like to be able to use my trailer without have it all winterized though.
Is there anything you guys can recommend that I could do to keep it where I could still take it out for a weekend if it was nice without having to de-winterize, without spending a ton of money?
Or am I pretty much out of luck?
2008 Weekend Warrior Supercross
2008 Cadillac Escalade
2009 Yamaha YFZ450R Red/White
2009 Yamaha YFZ450R Black/Red
nayther
Burbank, CA
Where do you keep your trailer? If it has power I would put an electric heater in it, set at as low as you can, say 40 and one underneath it to keep the tanks from freezing. You'd have to put some type of barrier around it to hold in the heat a little, like some plywood or a tarp.
The other solution for the tanks is heat strips. They should have some at the RV store or online and then wrap the tanks with insulation as best you can.
DIRT BIKES RULE
'05 Duramax CC short bed
'06 3005 Rage'n Falcon
emort
Ingleside, IL
Good Sam RV Club
You could just drain the water tanks and the low point drains and blow out the water lines with an air hose. You can get the air hose adapter at wal mart in the rv section for about $3. It screws into the city water connection under the trailer. You adjust the regulator on the air tank or compressor to about 40psi and use an air chuck like you would use for a tire. Than cup your hand around the drain in the sink and showers and use a blow gun to blow the water out of the p traps. It won't cost you anything when you winterize the trailer because you dont use any RV antifreeze. Or you could pour some antifreeze in the p traps. You wouldn't even use a 1/4 gallon of the pink stuff. When your ready to go out for a weekend just put water in and go.
Y-Guy
Tri-Cities, WA
Good Sam RV Club
I'll second emort's comments, we used our toy hauler and now motorhome pretty much up till January, at that time I put it down for a couple of months. I just drain all the water, blow the lines and dump a bit of pink stuff in the drains. The other key thing is to suck up just enough pink stuff to replace any water in your water pump. I can buy a couple gallons for several trips through the winter.
Winnebago Sightseer 35J | Custom ATV Trailer | Polaris Sportsmans & Honda Recons
bp122084
Portland, Or
Ok thanks guys! I appreciate the tips. This is my first trailer so still getting the hang of all this stuff!
campNride
Oklahoma City
I do the same thing that emort mentioned. It has worked great for me so far because I don't have to dewinterize the trailer to use it for the weekend. No problems in the past couple years doing it that way. Make sure to remember to drain your hot water heater and to refill it before you turn it back on.
1998.5 Dodge Ram 2500 with a few mods
2004 Wanderer Wagon Toyhauler
1997 XR400R Plated
2003 Polaris Trailboss 330
WhitehouseLV
Big Sky State
whats your highs like during those cold days?
Traveling Whitehouse
2006 Keystone Raptor 3612DS
2004 Chevrolet Silverado 3500 CC LB DRW Duramax LLY 4x4
Reese 20K Hitch
Prodigy Brake Control
2007 Honda Rincon & 2000 Honda Rancher
bp122084
Portland, Or
i'd say there around 15-20 days of freezing nights. During the day maybe up to low 40's. Usually doesn't get super cold here
tjar66
Portland OR
I would winterize and just in case we get another freak snow/freeze storm like last year. It's only a few bucks to winterize and not that hard. Looks like we may be close if you need a hand let me know.
2006 Dodge Ram 3500 Cummins
2007 Desert Fox 305j
2004 TRX 450r Mine
2005 Yamaha Raptor 350 Wife's
2006 Honda 300ex Sons
2007 Honda 250ex Daughter
mynetdude
Grants Pass, OR
hmm some Oregonians, looks like I'll be in the Portland area next month
