Well...I finally got around to installing the "new" Air Lift Controller I compressor system. Here is my previous post on the subject:
luv2skyski wrote: After I installed my AirLift Sureset I started having trouble with the pressure transducers. One of the transducers was sending a no pressure signal to the controller which in turn was sending more air to the bag. Luckily I was dumping my tanks at the time and heard the compressor kick on. The bag was nearing 100 PSI and I was able to pull the connector out of the controller before it popped. AirLift sent me a couple of new transducers and everything was fine for a about a year.
Lately, I’ve been getting erroneous readings (fluctuating, different than what my analog gauges are reading) so I again called AirLift.
They said that they cannot get parts for the Sureset system any longer and that they will do an even swap for the dual path Load Controller 1 system or upgrade to the Air Lift WirelessAIR Remote System for an additional $199. Which is a little odd because the WirelessAIR system only costs $80 more if it's purchased new.
Either way I'm going with the old tried and true analog gauge, two needle, dual path system. I'm tired of the digital system and it's erratic operation. I hope they got the bugs worked out of the wireless system but I'm just not willing to take that chance.
Has anyone else had problems with their Sureset system?
Anyone have the wireless system? Any problems? Compliments? Compaints?
BTW - You can still purchase the SureSet system for $300. (Hope you don't need any parts!)
Dave.
I ended up putting the gauge, toggle switch, and deflation buttons in the dash instead of using the supplied gauge panel.
"IMPORTANT: All preassembled gauge panels have been 100% leak and function tested. Do not attempt to tighten, loosen, or adjust any fittings or connections. This will likely cause a leak or malfunction and void the warranty."
They are not kidding. Of course it leaked. Specifically the brass "tees" that go from the gauge to the deflation buttons. The radius on the air lines was too severe so I ran two air lines from the firewall. One went directly to the deflation button and one went to the gauge:
(air line/tees only near steering linkage for photographic purposes)
I built a shelf/splash shield for the compressor and solenoid assembly to sit on. I already had a couple of holes in the bed where a pork chop box was mounted to attach the aluminum angle. It mounts in the space between the truck bed and bedside:
Hopefully this is far enough out of the way and the shelf large enough to prevent direct splash to the compressor or solenoid valves.
I'm guessing the two leads on the back of the gauge are for an internal dash lite option so they can be illuminated when you turn on your running lights?
Follow me as I full-time the Redneck Way at The Journey of the Redneck Express CBChannel 17Redneck Express '1992Dodge W-250 "Dually" Power Wagon - Club Cab Long Bed 4x4 V8 5.9L gashog w/4.10 Geared axles '1974KIT Kamper 1106 - 11' Slide-in
Wow deja vu
course there's not a lot of options. Good job!
I see they've changed the gage-that would be worth updating to. Ours the numbers are really small and the graduations are 7 1/2#increments? -there also at the perimeter of face so cant see them while driving.
As to comp location, I mounted our compressor in virtually identical location-its been there since Feb of 04 with no problems. The only difference I can see is my comp has a remote air intake that I located in cab. Even so I get a lot of water in the separator. I don't see one on yours?
I hadn't taken pics of our compressor install, now Ill just point to yours if someone asks
Mark
I gotta ask: how in the world did you manage to assemble the gauge & fittings up under the dash? I find that every time I try to work under there it's a royal pain, due to bifocals & laying on my back bending in three directions.
JoeChiOhki wrote: I'm guessing the two leads on the back of the gauge are for an internal dash lite option so they can be illuminated when you turn on your running lights?
Exactly. I tied it into the dimmer switch.
AnEv942 wrote: Wow deja vu
Mark
No separator. I think I'll look into that.
MTBob wrote: I gotta ask: how in the world did you manage to assemble the gauge & fittings up under the dash? I find that every time I try to work under there it's a royal pain, due to bifocals & laying on my back bending in three directions.
Bob
It wasn't easy, that's for sure.
Spott wrote: 1999??? that undercarriage is too clean to be that old.
We don't need to use road salt all that much down here. Pretty much never. It's sure nice to the vehicles.
