13ronzo
Englewood FL
Hi,
Has anyone used an apartment sized stacked washer / dryer in their r/v? Are there any down sides to this idea other than loss of some storage space?
Thanks,
Ron
MI Director
Michigan
Good Sam RV Club
Whirlpool makes about the best unit.
I am still wayne_tw
everywhere
At least one Sears unit, a 120 volt model, will only allow the use of one appliance at a time. You cannot wash and dry at the same time. The big plus is that these units are known for their reliability and can be serviced by most any appliance repair.
tahiti16
Camarillo, CA
I would check on the requirements for a residential unit being moved, many if not all are supposed to have the motor/transmission in the washer tied down when being moved. They are not designe dto bounce down the road, since except in CA they generally don't move while installed in your stick house!
Ray, Cheryl, Cory & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 5 speed auto 2 slides 7.5 KW genset
JUrban
Delaware
Most residential driers are 230v/30A. RV's have 120v.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
Fairgrove
Wauseon, Ohio
I installed one of these last year and it does a great job.
Ariston Washer
2003 45ft Monaco Executive
Howard Power Center Steering
Pressure Pro Tire Monitor
4 Solar Panels
Fishinghat
Western Washington, USA
Add to the 220volt requirement and the motor tie down while being moved, they have to be perfectly flat while being used. That's fine in a stick house, but might pose problems in a coach that gets moved.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
Jim & Betty
Brandon, South Dakota
Good Sam RV Club
I have the whirlpool washer and dryer with the stack kit they work very well. They are not 220 volt and do not come apart because they move down the road. If you need size info or model numbers PM and I will get back to you. These were a part of the original MH equipment.
JimR
fuzzyface
Algonac, Michigan, U S A
Good Sam RV Club
This was one of the requirements for our new motorhome -- the DW HATED the Splendide in our Bounder, and LOVES the stacked whirlpool units in our Newmar.
It is 120 Volts, and works very well.
Happy Travels
Mike
Linda and Mike Kruzin' in a Kountry Star
dav5942
Stuart, FL
Got a residential combo now for three years-no problem! Had stack W/D in my boat for 10 years(actually was in the bow of the boat)traveling as far as South America-no problem. The "bouncing" in a motorhome is minimal compared to a boat.
2007 Newmar 42' Mid Engine w/Fatboy,ATVs-in Garage,Rubicon w/4" lift,MotorMetal whls,MickeyT Baja tires-Cherokee w/4"lift in tow, Hog Valley FL(a diamond in the rough)
Alaska '09 Part2
Alaska Fishing Newmar Mid Engine '09 On the Road Again
