RV.Net Open Roads Forum: Tow Vehicles: They want $5K - FINAL REPORT
Search only in Tow Vehicles
 > They want $5K - FINAL REPORT
Tow Vehicles Related Tips
armyhockeynut
Ft Myer, VA
Good Sam RV Club
Posted: 11/12/09 10:08am Link  |  Quote  |  Print  |  Notify Moderator
For those who have followed my previous post and provided feedback. Here is the end result. Picked up my truck from the shop yesterday (Wednesday 11 Nov)...Final Bill $650
Replaced Outer Pinion Bearing
Pinion Seal
Axle Flange Gasket
Pinion Sleve/Spacer
Pinion nut
Rear axle Cover gasket
Friction modifier
Gear Lube (2 qts)
Grease/solvent/cleaner
Needless to say, the Labor was the main part of the bill.
Truck sounds much better...
Thanks for all the input..
* This post was edited 11/14/09 07:37am by armyhockeynut *
David - Ft Myer, VA
Active Duty Army 25+ years
2004 Terry Quantum 330FKDS
2001 Chevy Silverado LT 2500HD 4WD CC LB
8100 VORTEC, Auto ,4.10, Allison Trans
GS Chapter President(2002-2004)
Virginia State Staff (2006-2009)
Good Sam Club Life Member
jim1632
Arlington, VA
Posted: 11/12/09 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
I live in Arlington near Ft. Myer. What truck shop did you finally use for the repair. Due to the urban location, it has been difficult to find close by locations to handle my small motorhome.
armyhockeynut
Ft Myer, VA
Good Sam RV Club
Posted: 11/12/09 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Jim,
I went to AA Truck & Auto Body. Located down by Ft Belvoir. 8536 L Terminal Rd, Lorton, VA 703-550-5533
They work on just about anything. Have done Brakes on my trailer and regulary take my trailer there for the annual inspection. Give them a call and see what they can do for you...Ask for Jon.
b_salgado
Salisbury ,NC,USA
Posted: 11/12/09 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
I am glad they got you fixed up! So tell me.... Did you go camping last weekend or not?
04 Lariat Supercrew 4x4,5.4,3.73, Edge tuner, flowmaster duals
06 Trail Bay 31BH, nicely optioned
Equal-i-zer
Prodigy
Follow vehicle, 05 KIA Sorento EX for the golden retrievers.
Engineer9860
Eagle Scout dad
Posted: 11/12/09 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
That repair could have been done without replacing some of those parts......
The fact that they were replaced tells me the guy did the job right. You shouldn't have any trouble with the things that were replaced anymore.
Good Luck.
2002 Chevy 2500HD 4x4 8.1/ZF6sp RC/LB
2001 Chevy 2500HD 4x4 6.0/4L85E EC/SB
1997 Chevy Blazer 4x4
1994 Chevy K-2500 4x4 C6P 5.7/4L80E
1979 Chevy K-30 4x4 4sp 4.10
1977 Chevy K-30 4x4 4sp 4.10 454
"The Queen of the Skies"
Luke Porter
Not on the road :(
Posted: 11/12/09 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
I missed out. Did the place that wanted $5k do the work?
States I have spent the night in my current rig, bought three years ago.
Have RV'ed through 49 states and been in all 50, just short of my half-century.
dodge guy
Bartlett IL
Posted: 11/12/09 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
The only thing I would`ve done different was insatll both pinion bearings w/races. other than that sounds like a good deal.
I`ll bet your glad you asked now huh?!
Wife Kim
Son Brandon 8yrs
Daughter Marissa 7yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear, Hellwig sway bar
Reese HP dualcam,Prodigy brake controller.
A bad day of camping is
Redoildoctor
Land of the Fruits...Nuts...and The Govenator!!!
Posted: 11/13/09 12:32am Link  |  Quote  |  Print  |  Notify Moderator
HUH???? Your name suggests you were/are an engineer of some sort.
Enlighten me on which parts could have been done without????
Personally I may have done more based on the mileage(which I dont know or remember) and the simple fact that the differential is already disassembled.
Learjet
Louisiana
Good Sam RV Club
Posted: 11/13/09 08:55am Link  |  Quote  |  Print  |  Notify Moderator
read his WHOLE post again.
2006 Nissan Titan CC with tow package added Timbrens
2006 KZ Frontier 2303P-F
Dual 6 volt GC batts
Equal-i-zer
Yamaha EF2600c Tri-Fuel Gen.
in the past...2001 Hurricane 30Q Chevy workhorse
Engineer9860
Eagle Scout dad
Posted: 11/13/09 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Shade tree mechanics will try to get by without buying a new crush sleeve, etc.
I have seen flat rate dealerships repair a leaky pinion seal by marking the pinion nut, and pinion as to where the nut was originally torqued.
After the seal is replaced and the yoke is put back into position, they replace the nut, and then give it a 1/16th of a turn. By doing this, they retain the preload on the bearings.
Is it fixed by this method? Yes. Will it last? Probably. Does the tech have any idea as to what his "new" pinion bearing preload value is? No. Is it fixed according to proper axle setup guidelines? NO.
FWIW, crush sleeves are a non-reusable item.
