RV.Net Open Roads Forum: Beginning RVing: RV caulking
 > RV caulking
Beginning RVing Related Tips
LWR
Laurel Hill, Fl
Good Sam RV Club
Posted: 11/12/09 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
The old caulking around the front edges of my 5th wheel is old and cracking. Going to stripe and clean it off and need to know what caulking to use. Camping World has 2 different sealants but not sure which to use, ProFlex Flexible sealant and Dicor Self Leveling Lap sealant. At first I just simply added more silicone to the caulking cracks but now I figure it is best to stripe it all and put 1 fresh coat on the edge. Please advise before I start making a mess, Thanks
tvman44
Southwest Louisiana
Posted: 11/12/09 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
The Dicor Self leveling is for on the roof. So I guess I would use the Proflex.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
tjar66
Portland OR
Posted: 11/12/09 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
tvman is correct use the proflex. Now the only question is white or clear?
2006 Dodge Ram 3500 Cummins
2007 Desert Fox 305j
2004 TRX 450r Mine
2005 Yamaha Raptor 350 Wife's
2006 Honda 300ex Sons
2007 Honda 250ex Daughter
tjar66
Portland OR
Posted: 11/12/09 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
tjar66 wrote:
tvman is correct use the proflex. Now the only question is white or clear? I don't know if anyone else had this problem but I found that if I cut the tip donw just to the minimum way to much caulk comes out and I make a huge mess. I tired using a metal coat hanger and melting it into the tip and it worked pretty well.
Deen
Vancouver, WA
Good Sam RV Club
Posted: 11/12/09 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
Fist off you'll have to remove ANY residue from the silicone (and that's not going to be easy) as almost nothing will stick once silicone has been used. That's why the higher end manufacturers never use silicone as the primary sealant.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor and Recruiter
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
52nd yr of RV'ing
John Wayne
Long Beach, Ca
Good Sam RV Club
Posted: 11/12/09 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Look at Eternbond tape and you will not have to worry about calking again.
John & Carol
01 31'Sea View single slide, F53 V-10
96 Toyota 4-Runner auto 4x4 (Remco, M&G brake system)
KF6HCH
JR45
Warren/OR/USA
Posted: 11/12/09 11:09pm Link  |  Quote  |  Print  |  Notify Moderator
X2 on the Eternabond Roof tape, clean it up tap it and forget it!
http://www.bestmaterials.com/Eternabond.aspx?gclid=CIHb6OCegJwCFSRPagod-VnI_A
JR
06 F350 4x4 PSD Lariat FX4 CC LB
Coolant Filtration System
PressurePro Monitors
2003 Alpenlite Limited
Fifth Airborne
Ridgewood 30RK
3 Slides
PJG061073
North Carolina
Posted: 11/13/09 10:20am Link  |  Quote  |  Print  |  Notify Moderator
JR
JR45.... I went to the website..
Does this site also have CAULKs for around WINDOWS...etc ??
Thanks..
Have a wonderful day..
Regards,
M&P ..
2008 Safari Cheetah-40 SKQ
"CAN'T SHOW MY PICTURE, ..I'M IN THE WITNESS PROTECTION PROGRAM"..
randco
Sarasota, Florida
Posted: 11/14/09 03:32am Link  |  Quote  |  Print  |  Notify Moderator
JR
Thanks..
Duh... Did you read anything on the website?
NewRVerDiane
Madison, Wisconsin
Posted: 11/14/09 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Is the window sealant for application on the outside of the window? I was at a high powered car wash trying to get the grit off the front on MH and there was leakage at top of window.
Thanks.
Diane
Madison, WI
'94 Horizon 21 1/2'
 > RV caulking
