RV.Net Open Roads Forum: Class A Motorhomes: Disconnect Qickee retracting steps for supports
 > Disconnect Qickee retracting steps for supports
jjverb
Wisconsin
Good Sam RV Club
Posted: 11/12/09 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
I want to disconnect out Quickee steps so I can put jacks under them for support while we winter in Texas.
We have a 1999 HR Endeavor.
But I do not have a clue where the fuse is located. Do I cut the motor wires? Prefer not to.
I do not want the steps retracting while there is something holding them up because it will break the link or cause some other damage.
I know there some breakers back by the batteries, but they are not marked and I hate to do trial and error on them.
Anyone have a clue?
Thanks - John
hershey
Albuquerque,(fulltime) NM, USA
Posted: 11/12/09 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Just open the steps and turn them off in the open position. Thats what I do on a regular basis. I use a step support under mine anytime we are in the same location for more than a couple days.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99 - 5
jjverb
Wisconsin
Good Sam RV Club
Posted: 11/12/09 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
We have been here 3 weeks and I bumped the switch once and they closed, now I started the engine to burn off some fuel, and of course, the steps retracted.
I replaced that link once and it is not an easy task, and I want to try to avoid that job again.
John
deandec
El Dorado Hills, CA
Posted: 11/12/09 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
I suspect the steps are commingled with other items on a fused line, so disconnecting the fuse might not provide the result you want.
Why not cut one of the power lines to the motor and install a switch on that line? That way you control the steps when parked and there will be no override.
Dean
95 CC Magna, Jeep GC
don/lou
Brandon MB Canada
Good Sam RV Club
Posted: 11/12/09 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Then You will probably drive away with it still down and really damage the step on something !!!
My thought on this idea!
Don & Louise
2000 Coachman Catalina 330 MSB /F53
Rear air bags, 4 Koni FSD Shocks & Davis Front TruTrac
2008 Impala- Remco Lube Pump , Blue OX tow bar & Brake Buddy
deaop01
Mansfield, Ohio
Good Sam RV Club
Posted: 11/12/09 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I do that with mine. Under the steps by the motor mine has an inline plug. I just unplug that and put jacks under both sides. It cost me $50 to repair the link. That is what the plug is for so it can be unpluged to repair.
Good luck
Ron
Betty and Ron
2002 Bounder 31W
8.1 with 5 speed Allison
2 slides
2005 Colorado toad
jjverb
Wisconsin
Good Sam RV Club
Posted: 11/12/09 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
I was looking around under there for a disconnect and there is a bright yellow tag on the wires to the motor saying not to cut the motor wires.
I talked to another camper and he also has the plugs to disconnect the motor for repair and he disconnects them for supports.
My wires are solid to the motor, no plugs.
What the heck?
John
robatthelake
Vancouver Island
Posted: 11/12/09 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
There is a plug there , Either at the Motor end or between the Motor and the controller.
Rob & Jean
Dutch Star Diesel Pusher ..Tracker 4X2
havin fun
don't know yet we are not their yet .
Good Sam RV Club
Posted: 11/13/09 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
we have a 1999 GB it did not have a plug it was wired together .replace the controlor now it has a plug.
retired
havin fun with 1999 georgie boy 3515
and the wife too .
V-10 ford
It's hard to make a come back if you haven't been any where ? !!
North Hampton Local Weather
Edouard
Hudson, Quebec, Canada
Posted: 11/13/09 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Per our signature, our 99 Endeavour has a plug under the steps, used it a few times trouble shooting.
Eugene & Stella Theriault,
1999 Endeavour 34CG/V-10 F-53.(No Slides)
2010 Chevy Equinox. Blue Ox Aladin. Demco Base Plate
FMCA 318247
