RV.Net Open Roads Forum: Toy Haulers: sewer hose holder.
Search only in Toy Haulers
 > sewer hose holder.
Toy Haulers Related Tips
uncleroman
clear lake texas
Posted: 11/13/09 06:49am Link  |  Quote  |  Print  |  Notify Moderator
the stock sewer hose holder on my jayco is a bad joke. its way to short and not even big enough around, for my rhino hose. i cant figure anywhere to build something to put it. i got a 6" pvc and was gonna mount it underneath but it hangs down too low. im stumped. right now im looking to have an aluminum tonge box built. that fits over the batterys. but would rather have something closer to the hookup
2000 f250 7.3 4x4 supercrew shortbed- k&n, hypertech programmer, stock exhaust minus baffles and muffler
equal-i-zer hitch
prodigy brake controler
2006 24z jayco octane- no mods, yet
928gt
Western North Carolina
Posted: 11/13/09 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Here is a link to how I did mine, probably not big enough for the hose you mention but it might give you some ideas..
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23082367.cfm
David
2007 Weekend Warrior LE3505 Billet Edition
2005 F-350 DRW CC LB 4x4 Tow Boss w/Tow Command
Al/Reeni
Ft Myers, Fl
Posted: 11/13/09 07:50am Link  |  Quote  |  Print  |  Notify Moderator
I made these out of plastic fence posts from Lowes. Bought 2 eight-footers and cut them in half. The front 2 hold hoses and the back 2 carry some supports I made by splitting a 4 inch PVC pipe.
928gt
Posted: 11/13/09 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Thats cool ^^^ looks like a mini rocker launcher!
mapguy
Puget Sound
Posted: 11/13/09 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Mine is the 5" fence post from Lowes mounted to a unistrut with off the shelf unistrut brackets/hardware.
It is full width across trailer to store multiple sections of hose with fittings.
Stainless hinge and velcro to hold closed
TF36DSMatt
SoCal
Posted: 11/17/09 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
I did the same... the Lowe's fencepost works well with the RhinoFLEX sewer hose from Walmart. It fits perfectly. I didn't, however, go to the trouble of making the fancy hinged door... I just used two brass hitch pins (about $3 apiece) and drilled a horizontal hole close to each end of the fencepost to stick the hitch pin through. Inside one fencepost I have 25' of hose... a 15' main hose and a 10' extension hose in case I need it.
Hitch pin:
