RV.Net Open Roads Forum: Class A Motorhomes: Loose grill
 > Loose grill
dragonfly835
Roving
Posted: 11/13/09 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
The grill on my 07 Itasca Sunova is completely loose -- the frame keeps it from fall off. I can push it into place, but I can't see where there is a bolt hole or clip for it.
Any suggestions?
Deen
Vancouver, WA
Posted: 11/13/09 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
That may be all that holds it in place to begin with. Maybe some shims to hold it from rattling if that's a problem.
GBMcruisair
Bemidji,Mn, USA
Posted: 11/13/09 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Go on Winnebagos website and look at the replacement parts diagrams for your model. You should be able to see what kind clip or bolt they are using.
Kip & Judy
2000 Georgie Boy Pursuit, 2001 Cherokee toad
1951 Pontiac with 400cu GTO running gear
1964 Corvair Monza all original
GBMcruisair
Bemidji,Mn, USA
Posted: 11/13/09 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
go here: http://www.winnebagoind.com/service/submenu/2007.htm click on your model and then click on: exterior front end
wolfe10
Posted: 11/13/09 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
Clickable: http://www.winnebagoind.com/service/submenu/2007.htm
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
RPagington
Berryville, VA
Posted: 11/14/09 05:39am Link  |  Quote  |  Print  |  Notify Moderator
My Winnebago 29R grill came loose also. Mine was glued in and the glue could not hold the weight. I ended up making brackets and bolting it all together, now it won't come loose.
Ralph
Winnebago Sightseer 29R towing a yellow mini cooper
teeznu
Posted: 11/14/09 05:44am Link  |  Quote  |  Print  |  Notify Moderator
I too have the same issue with our 06 Vectra. The front grill is all fiberglass. When I lifted the hood portion, to pull the generator out, a visual inspection left me almost speechless. Mine has no bolts or clips. It is merely held on with several metal "angled" pieces of steel with slots in the metal. Then, a "glob" of "caulk" (I'm sure it's a special kind) is placed on the back side of the fiberglass grill. The caulk oozes (sp) through the slots in the metal angle. Once dry, that is all that holds our front grill in place. 2 of the metal angles have come loose. I'll email Winnie and get a recommendation as what to use.
* This post was edited 11/14/09 05:56am by teeznu *
dragonfly835
Roving
Posted: 11/14/09 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to each of you! I'll check for "caulk", the website, explore some clips and figure this out, thanks to you all.
Clay L
Sioux Falls, South Dakota
Good Sam RV Club
Posted: 11/14/09 10:05am Link  |  Quote  |  Print  |  Notify Moderator
I believe what they use is:
Winnebago part number 112901-02-000
Plexus MA330 Methacrylate Adhesive 50ml found at ITW Plexus, Danvers, MA 01923
The surface has to be clean. You might want to call Winnebago and ask about surface prep.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
dragonfly835
Roving
Posted: 11/14/09 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
WOW. Thanks!
 > Loose grill
