RV.Net Open Roads Forum: Fifth-Wheels: how do i fix a squeaky floor?
 > how do i fix a squeaky floor?
trophyhusband
Fort Walton Beach
Posted: 11/15/09 09:32am Link  |  Print  |  Notify Moderator
i have 2010 montana and the floor in front of the shower squeaks. its extremely loud when its cold outside and it gets quieter as the day warms up. once it gets to the upper 80's the squeak is gone. i've looked from the basement while my wife walks the floor, but i can't really tell where its coming from or how i would fix it. what the heck do i do? when one of us gets up to pee it wakes the other, and it drives us both nuts in the mornings.
larry barnhart
wenatchee. wa usa
Posted: 11/15/09 10:25am Link  |  Print  |  Notify Moderator
I would think something rubs to make the sound and yuou will have to work at finding where and why. We have a 2001 alpenlite and sometimes after sitting in Az in the dry air we get a squeak at times. Nothing that makes a problem but look to see if some trim is moving at the shower area or maybe the floor moves up and down at the shower install to the floor. Hope somebody has fixed theirs to help you.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
kenboat
southwest illinois
Posted: 11/15/09 12:20pm Link  |  Print  |  Notify Moderator
I would think it is a warranty issue.
You should take it back to the dealer.
Ken
1999 Ford F250 SuperDuty CC LB 7.3 TD
2008 KZ Sportsmen S245RL2
1956 Owens Outboard Wooden runabout boat
RRyall
SW PA
Posted: 11/15/09 07:18pm Link  |  Print  |  Notify Moderator
I agree with Ken, it should be a warranty issue for you. OTOH, it sounds as if it is at a stress point so to speak where the floor deck is loose over a floor support, the frame, etc. and it goes away after it swells up from enough heat. If you can find the spot, I believe that you could resolve it fairly easily, it is probably somewhat difficult to pinpoint, as you have already found out. If you can physically touch the area, you can probably pinpoint it much easier by placing your fingers against the floor and sensing the location that way while your helper makes the floor squeal. I believe that you can feel where the spot is better than listening for it. Good Luck.
BobsYourUncle
Calgary Alberta Canada
Posted: 11/15/09 10:13pm Link  |  Print  |  Notify Moderator
A squeaky floor is almost always caused by a loose fastener.
If there is a nail or screw that goes down through the floor that was not put in tight enough, or they missed or partly missed the floor framing, the cause of the squeak is the floor plywood or whatever they used moving up and down on the fastener.
Picture a nail in a piece of wood with the head sticking up a bit out of the floor. The floor ply sits up off the joist a bit. When you step on it, the floor plywood moves down until it contacts the joist. The floor is moving up and down on the nail with that annoying noise.
The cure for that on a 2010 model year is WARRANTY!
The cure on a model out of warranty is to exactly locate the loose nail or screw and hammer or thread it in tighter, if it is only loose.
And / Or run a screw into the center of the joist in the area of the problem fastener. When the floor can't move, it can't squeak.
Now obviously you cant just go running screws through a finished lino floor. If carpet, you can run screws through it into the floor joist. This will take some careful calculations to determine where the joists are.
Duramax / Allison
Fire Red
1997 Triple E Topaz 27' Bunkhouse TT
Veebyes
Posted: 11/16/09 07:14am Link  |  Print  |  Notify Moderator
Irritating. Got a squeak in my Alpenlite too. Right in front of table at what must be the spot stepped on most often.
I know. Loose screw or missed screw. Why don't they glue & screw these things together? Getting at them later is impossible. Carpet would have to come up. The carpet goes down before anything else interior goes in.
These things are not designed with future maintenance in mind.
2007 Alpenlite 34RLR
NavyDood
NW of DFW
Posted: 11/16/09 07:51am Link  |  Print  |  Notify Moderator
It's a camper. More squeeks to come. I have a couple also. Can't pin point it either. I just take the easy way out and ignore it.
- Retired Navy Chief
- Vanilla 04 2500 QCSB, 4x4, 48RE w/MagHytec DD, Smarty Jr, 4" Exh, Modded Air Box, Isspro Gauges, Quadzilla RPG w/fuel pressure, DynaTrac front, Coolant By-Pass Filter
- 06 Pilgrim 30RE2SLF-5 13,300lbs loaded. B&W Companion
BobsYourUncle
Posted: 11/16/09 09:43am Link  |  Print  |  Notify Moderator
I have successfully addressed squeaks under carpet by running screws through the carpet, tightening the floor to the joists. The head of the screw pulls through the carpet, leaving a small hole that disappears into the carpet. Of course, if the carpet is very flat, you may see the hole.
45Ricochet
North Idaho
Posted: 11/16/09 02:25pm Link  |  Print  |  Notify Moderator
Earplugs will help.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
