RV.Net Open Roads Forum: General RVing Issues: Toilet Doesn't Hold Water - Causes?
 > Toilet Doesn't Hold Water - Causes?
General RVing Issues Related Tips
Sunseeker2007
Camp Hill, PA
Good Sam RV Club
Posted: 11/15/09 10:04am Link  |  Quote  |  Print  |  Notify Moderator
The toilet in my motorhome isn't holding water for more than a couple of hours anymore. What should we look for to identify cause/repair?
Thanks for your help.
enblethen
Moses Lake, WA USA
Good Sam RV Club
Posted: 11/15/09 10:10am Link  |  Quote  |  Print  |  Notify Moderator
Debris is the gasket area of slide valve.
Thetford has tool called bent screw driver to clean groce. You can make one out of coat hanger type wire. Bend about one inch 90 degree bend on one end. Turn off water, hold slider valve open, insert short end into groove. Move around seal area with gentle force.
Can also use round about 3 inch diameter toilet brush to clean groove area in similar movement.
Bud
Suzuki XL7 pushing Pace Arrow
trop-a-cal
Palm Coast Fl
Posted: 11/15/09 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Could just have toilet paper stuck in area where it closes. Rinse it out with water. Could have dryed gaskets, add a little dish soap every month, and it gets softer, and seals better. Just put soap in when it has water above the drainerand it will get to the gaskets as it leaks or is flushed down.
skipnchar
Topeka Kansas USA
Posted: 11/15/09 10:37am Link  |  Quote  |  Print  |  Notify Moderator
I always try the EASY stuff first. Try lubricating the rubber O ring that seals the toilet with a little petroleum jelly. If that works, problem solved. Good luck / Skip
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
Happy Prospector
The Great American Southwest
Posted: 11/15/09 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Mine does the same thing every so often, it just needs a good cleaning. I use Scrubbing Bubbles. Turn off water, open valve to get rid of any standing water, spray with cleaner- use quite a bit, go have a beer and let it sit for about 5 minutes and use 3 inch round scrubber. You may have to do twice. This has worked for me. Have fun. Kevin
big dave
Soldotna, Alaska, USA
Posted: 11/15/09 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Cleaning it usually works, but I have had to replace the seal. They sell a kit for it.
Dave & Rose C
90 Safari Ivory 34' DP
04 Saturn VUE V6
JJBIRISH
Butler, PA, USA
Good Sam RV Club
Posted: 11/15/09 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure which toilet you have but if it’s a thetford, you can find all you need to know here…
click
Love my mass produced, entry level, built by Lazy American Workers, Hornet
hershey
Albuquerque,(fulltime) NM, USA
Posted: 11/15/09 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
If its a theford with the ball shut off valve, you can remove the top portion of the toilet and remove the rubber gasket, clean the calcium deposit off of it and replace it and your good to go for quite a while. We fulltime and I have to do this about once a year or so.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99 - 5
RGordon
Atoka, TN/North Ft Myers, FL
Good Sam RV Club
Posted: 11/15/09 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Mine had calcium deposits built up on the seal. Took apart and cleaned, then reinstalled, worked OK.
Ron & Libby Gordon
07 Ford F350 Dually Tow Boss Diesel
07 Mobile Suites 38RL3 #3698
02 Winnebago Adventurer 35U V10 (Former RV)
Learn from yesterday, live for today, hope for tomorrow
sneakers145
CT
Posted: 11/16/09 12:13am Link  |  Quote  |  Print  |  Notify Moderator
If cleaning and vaseline don't work, try slamming the flapper closed a few times hard. That was what finally worked for me.
Jay
Two kids and two Brussels Griffons
Nights camped in 2009: 27
2000 Fleetwood Bounder 32H
2007 Ford Focus
