Jr66
Canada
Hi All
Looking for my first 5th wheel. This has aluminum walls and wood roof trusses. Is that a problem. I want to stay under 25K. Looking at the Copper Canyon model 298FWBHS. Is this a decent model? What are the most important construction things to look at in a fidth wheel. I have a 2008 Dodge Mega 6.7l Diesel to pull with.
Thanks
kirkj55
Nor Cal
Check out the Nu Wa web site, they have a good video that talks about construction, wood and aluminum.
The Nu Wa is a high end unit but the video is good info to have when looking at other rigs.
danoren
Where ever I Camp
You have truck that will pull with no problems this size 5W.
I have good experiance with Crossroads take a LOOK
F-350 ,2006,XLT,SD,LB,EC,6.0LT,Auto,SRW.
5W Cruiser 2006 CF29CK Crossroad
The world is a book,if you are not traveling than you are still on the first page.
P.A,Good Sam,TomTom GO720
Website
dodgebob08
Mississippi
we have a copper canyon and do like the camper, just wanted to mention that the frame/general construction seems fine but the fit and finish on the inside lacks a lot. their quality control lacks a lot though it may be improved now, ours is a couple of years old.
2008 Dodge 2500 MegaCab CTD
2006 Copper Canyon 295RLS
modelaford1929
sootville
Good Sam RV Club
Jr66 wrote: Hi All
Thanks
Could just about buy anything when you have junk to pull it with, ROTFFLMAO
mwebber78
Maine
I would second the Crossroads Cruiser line. They have all alum. construction, walls, roof truss and floor joists. The floors/roof/walls are framed 16" OC, just like your home. The walls have fiberglass batts and there is additonal insulation via astrofoil reflective sheets in the floor/roof/walls. Also, they don't use OSB, they use plywood decking on the roof and main living areas.
There are many floorplans, great units, longer warranty then most (2+5 years) and great owner's forum.
www.crossroadsrv.com to checkout the campers
www.crossroadsrv/forum to checkout the forum
www.rvwholesalers.com to checkout/build/price the Cruiser
Good luck, we looked at the Copper Canyon but a few things I didn't like were the fit/finish, low R-value and they use OSB decking (personal choice).
Michael
2 DD's and my DW
6 Acre's in Southern Maine
2009 Crossroads Cruiser CF31SB
2008 Chevy 2500HD LT 4X4
Camping Pictures
C Schomer
Buckeye, Az.
I don't know who makes copper canyon but don't buy the cheapest and lightest - the most important things aren't visible. The two worst problems we had with our first entry level 5er was the weak frame (flexing tore up the front end) and there was no vapor barrier under the alum. siding and wind blow right thru that thing and there were also countless other quality issues. Craig
03Dodge QC HO CTD Dually NV5600 4.10 Rear/WD A2K turbo Diablo Predator Quad BF 4" exh PRXB Pacbrake Rancho 9000s FS Airbags Onboard air/in-cab controls HUGE custom intake Custom hauler bed. 98 Sunnybrook 30RLFS 5er.WHOEVER INVENTED WORK DIDN'T HAVE AN RV!
mwebber78
Maine
It's a Keystone product.
BOB MU
home
Quote: Could just about buy anything when you have junk to pull it with, ROTFFLMAO
Tell us what you have that is so great for a TV?
usmohls2@yahoo.com
CA
OH NO! This is turning into a tow vehicle bashing forum! Shame on YOU modelaford.
