RV.Net Open Roads Forum: 200 watts of solar panels on luggage rack, my install
 > 200 watts of solar panels on luggage rack, my install
Page of 17
Truck Campers Related Tips
sleepy
Oak Ridge,Tennessee
Posted: 11/23/09 10:05am Link  |  Quote  |  Print  |  Notify Moderator
I recently installed 2 ea AMSolar 100 Watt each Photovoltic Panels.
I chose this brand for several reasons:
I like the fact that they have an output of 21.5 volts. (others are 17.5 V) As I understand it under less than ideal light conditions the panels could lose 3 or 4 volts. Once the panels are puting out less than 14V the batteries may not charge well or fully.
I like the 48 cells in each panel instead of the normal 36. I am told that this will allow me to gain more total photons to convert to power when the PV panels are mounted flat. (An important factor, since we travel constantly)
Another factor that I think is important... these PV panels are longer and narrower... this means that they will fit on a RV roof easier... between all of the other stuff that we have up there.
And... AMSolar has an excellant reputation!
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans model 6150/AC/winter package
AirFoil, Trimetric, LED lights
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
sleepy
Oak Ridge,Tennessee
Posted: 11/23/09 10:07am Link  |  Quote  |  Print  |  Notify Moderator
The packages came by UPS... 2 boxs with panels and another with the controller, wiring, instructions, and a refridgerator combiner box.
Would you believe the boxs for the panels were $25 each... but they were really protected.
sleepy
Oak Ridge,Tennessee
Posted: 11/23/09 10:11am Link  |  Quote  |  Print  |  Notify Moderator
The back of a PV panel with the sealed box for the connections to the panel.
Data
pianotuna
Regina, SK, Canada
Good Sam RV Club
Posted: 11/23/09 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Hi Sleepy,
I've very excited for you!
Tell us what controller--and what size of wire (big fat I hope).
Regards, Don
Kustom Koach Class C 28'5" 256 watts solar, 875 amp hours in two battery banks 12 volt batteries 2500 watt inverter.
sleepy
Oak Ridge,Tennessee
The third box... contents
sleepy
Oak Ridge,Tennessee
Posted: 11/23/09 10:16am Link  |  Quote  |  Print  |  Notify Moderator
inside the PV Panel connection box
the AMSolar supplied 10 gauge wire is round so that it can be sealed
You probably noticed... I'm working in the camper... we had inclimanant weather... again, and again.
simple enough... I make extra notes (reminders)... for dummies like me
sleepy
Oak Ridge,Tennessee
Posted: 11/23/09 10:26am Link  |  Quote  |  Print  |  Notify Moderator
I am mounting the PV panels using the existing luggage rack. The luggage rack didn't have to be adapted at all... I just pulled the plugs out of the cross bars.
Different views
I cut round foam insulation to fit the cross bar pipes and slit it for the stand-off.
The clear tubing represents the cross bar pipe...
I made stand-off brackets out of "B-line Unistrut" aluminum angle.
Mooney
Santa Barbara, Ca
Good Sam RV Club
You're going to LOVE that system!
'08 Ford F550, Lariat, Link Air Suspension, Roll-A-Long Conversion, Twin Turbo 6.4, TorkLifts, SuperHitch, "Monster Duty Truckasaurus"
'09 Host Everest, Dual Pane, AM Solar, Link 1000,Prosine2.0,Tank Htrs,Honda EV4010,HD Motosat,Wave 6.
Host Everest Photos
sleepy
Oak Ridge,Tennessee
Posted: 11/23/09 10:31am Link  |  Quote  |  Print  |  Notify Moderator
this is how it mounts on the panels and into our "cross bars"
sleepy
Oak Ridge,Tennessee
Posted: 11/23/09 10:33am Link  |  Quote  |  Print  |  Notify Moderator
This is how the panels are bolted together and wired up ready to go to the roof!
Page of 17
