RV.Net Open Roads Forum: Total Rebuild of a 1979 Dodge Class C
 > Total Rebuild of a 1979 Dodge Class C
Page of 349
oldtrucker63
Harlan Kentucky
Posted: 04/25/12 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
The next to the last video.......Its about time.
Come on in.
Without Trucks,....America Stop's
oldtrucker63
Harlan Kentucky
Posted: 04/26/12 06:28am Link  |  Quote  |  Print  |  Notify Moderator
Thunder storms here today, Makes me one more day down, I might find something to do inside the old girl today.......
Trish Davis
eastern Ohio
Posted: 04/26/12 10:42am Link  |  Quote  |  Print  |  Notify Moderator
I like your backsplash. A LOT.
Where are you putting the bead board?
oldtrucker63 wrote:
I built the cabinet door's and drawers today, I will stain and add the white bead board in the morning, It's really coming together now.
MMarieT
Idaho
Posted: 04/26/12 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Wow...you have been working hard...looks good...enjoy!
oldtrucker63
Harlan Kentucky
Posted: 04/27/12 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Around the cabinet, I'm finished with that, I will upload some photos tonight, The site must have been down and I was about to go crazy......LOL
oldtrucker63
Harlan Kentucky
Posted: 04/28/12 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
The site has been down and photo bucket was also down, Here is where the bead board go's.
MMarieT
Idaho
Posted: 04/28/12 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
That looks great...you guys will have years of fun...and knowing you did it yourself brings even more into the good times....we are getting started finally on the framing...we are starting from the ground up..I can't wait....will have tons of questions at times...hope you don't mind...have a great evening...
oldtrucker63
Harlan Kentucky
Posted: 04/28/12 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
Ran the gas line for the generator today and it would not pump any gas through the line, OK The fuel pump quit so I bought a new fuel pump and still no gas, I could blow through the line but no exhaust on the line so I took the tank off and found that the end that was on the line tube had some kind of one way valve on it, I removed it and now it works fine, Only I had just went and pumped 27 gallons of gas into the tank just before I installed the generator's gas line and with no way to pump the gas back out I took the tank off with the gas still inside the tank, It will be a Bit*h to put back but I will get it there some how........... That is just part of a rebuild............I ran the generator with the tank out on the ground and I had to re-adjust the choke and idle because when the roof AC kicked on and ran on cool for a few then it would kick off causing the generator the run pass the 1800 RPM limit causing it to shut down, Its fixed now and running great I just need to install the gas tank tomorrow.
MMarieT
Idaho
Posted: 04/28/12 10:44pm Link  |  Quote  |  Print  |  Notify Moderator
work work work...never ends...but worth it...
gotsmart
Aberdeen, WA
Posted: 04/29/12 01:29am Link  |  Quote  |  Print  |  Notify Moderator
oldtrucker63 wrote:
... Only I had just went and pumped 27 gallons of gas into the tank just before I installed the generator's gas line and with no way to pump the gas back out I took the tank off with the gas still inside the tank, It will be a Bit*h to put back but I will get it there some how...........
Allow me to recycle a classic phrase:
Sucks to be you!
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
Page of 349
