RV.Net Open Roads Forum: Tech Issues: Suburban Furnace Outside Air Wheel
 > Suburban Furnace Outside Air Wheel
Tech Issues Related Tips
deandec
El Dorado Hills, CA
Posted: 12/11/09 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
My Suburban furnace was working fine and quietly. After running for two nights of sub 30 degree weather, it began screeching like a rusty gate in the wind.
If I remove the outside air wheel, the unit runs perfectly and quietly. I cleaned the wheel of dirt and put it back on both with and without the cover and the screeching returns, just not as loud.
The wheel looks fine, seems to be balanced (as best one can tell).
I will buy a new wheel on Monday, but I am not confident that will fix anything. What else should I be examing to rid myself of the noise?
Thanks for any ideas
Dean
95 CC Magna, Jeep GC
robsouth
Too Near Atlanta, GA
Good Sam RV Club
Posted: 12/11/09 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
What is an "air wheel"?
Dodge Ram 3500 Cummins Turbo Diesel Dually
Terry 22U
Regal 1900LSR
"Great minds like a think"
Chris Bryant
DeLand, Florida, USA
Posted: 12/11/09 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
I would guess that the bearings on that side are dry, so either try to lube the motor, or replace it.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
deandec
El Dorado Hills, CA
Posted: 12/11/09 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
So, when the wheel is mounted that is too much load on the bearings? That sounds possible. Unfortunately, they say the motor is sealed so my option would be to replace the motor. I guess the wheel is cheaper at $10.00 so I'll try that first then move to the motor for $130.
"Air Wheel" my term for the thing that spins on the motor shaft to move outside air around the furnace.
TXiceman
(Near) Houston,TX
Posted: 12/11/09 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
I too ask, what is an "air wheel"? are you asking about a blower of centrifugal fan wheel?
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with one miniature Schnauzers, one standard schnauzer and one African Gray parrot. Practicing for retirement!
vikx
Washington State
Posted: 12/11/09 11:39pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with Chris, replace the motor. Some folks also replace the "air wheel" but you might not have to spend the money. VK
Dave H M
IL
Posted: 12/12/09 04:39am Link  |  Quote  |  Print  |  Notify Moderator
If the "air wheel" is not rubbing on anything and the center is still firmly affixed to the outside part then I would think it surely would be a motor bearing. I just hate it when things come from the factory as a bummer.
The big squirrel cage fan on my house furnace started raising heck and on that one the inside hub had came loose from the cage.
Dusty R
Charlotte Michigan 48813
Posted: 12/12/09 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Just put some oil on the shaft next to the motor. Some where someone said they drilled a small hole in the motor at the bearing to oil it. If nothing is loose in/on the fan wheel replacing it would be like changing a light bulb when the breaker was tripped.
Dusty
burd1959
burton mich
Posted: 12/12/09 07:33am Link  |  Quote  |  Print  |  Notify Moderator
i had same problem took out motor found piece of rubber hose 3 inchs longer than the shaft on motor filled hose with grease and got bolt that slid tight into hose held hose down over shaft and pushed 4 or 5 times on both ends of motor cleaned up the excess grease on both ends of shafts and its worked perfect since time 2 hours money spent 0 dollars make shur no loosenes in bearings
deandec
El Dorado Hills, CA
Posted: 12/12/09 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, I will try the lube the motor thing since some have had success, it is free, and the parts store is closed.
BTW, on my parts list Item 350110 is "Wheel, Combustion Air" so I created the term Air Wheel
Dean
OP
