RV.Net Open Roads Forum: Fifth-Wheels: Help pipes keep freezing!!!!
 > Help pipes keep freezing!!!!
Kentuckyblueyes
Washington State
Posted: 12/14/09 10:04pm Link  |  Print  |  Notify Moderator
It has been so cold here!!! Been down to at least 10 degrees. That is not normal weather for here! Our pipes keep freezing where it's hooked up too. Thank the Lord it has not burst yet! No matter how much we wrap they still freeze!!! What can I do. Been having to heat water up on stove for dishes etc. Thanks for any advice! God bless!!!!!
FXSTOHIO
Ohio
Posted: 12/14/09 10:07pm Link  |  Print  |  Notify Moderator
Try leaving the water faucet drip one on cold side and one on hot side in both kitchen and bathroom. That should keep them from freezing up. Have done that here more than once in a real cold winter
2008 Pilgrim Lite 21LRB
2014 Chevy Silverado Z71 Double Cab 4x4 5.3 V8 3.42 Rear End
Yamaha EF2400IS
Amateur Call N8HXR
SGTJOE
Utah
Posted: 12/14/09 10:58pm Link  |  Print  |  Notify Moderator
When the temps are cold enough to freeze, it is time to fill the water tank and disconnect the water hose from the rv and from the water source, drain all the water from the hose. On your sewer hose, close the gray tank off and make sure there is no water left in the sewer hose, it will freeze and may break the hose.
2001 Trade Winds 7390
Toad 03 Grand Am
2oldman
Pahrump
Posted: 12/14/09 10:09pm Link  |  Print  |  Notify Moderator
Use the water tank and keep the furnace on and don't run out of propane!
time2roll
Posted: 12/14/09 10:15pm Link  |  Print  |  Notify Moderator
Wrap is not enough. You need some heat tape.
675w Solar pictures back up
grampachet
West Coast
Posted: 12/14/09 11:59pm Link  |  Print  |  Notify Moderator
If you choose to let the water drip, remember it has to have some place to go and by the time it gets part way down the sewer hose it will probably freeze on you and then the bigger problems begin.
2004 F-250 KIngRanch,CC,SB,SRW,4x4,V-10,3.73
2008 Montana 3000RK
Shotgun
CA
Posted: 12/15/09 12:41am Link  |  Print  |  Notify Moderator
heat tape,
if you are set up semi-perminit, you can also skirt the sides, from the trl to the ground. I have used 1/2" ply and 2" solid foam insulation. Then put a heater under the trl.
but you will need to heat tape the hose and all exposed pipe.
Hunting is not a hobby. It is much more life sustaining than that.
Dale-pilot, Jeanette-co-pilot
Electrician since 1978
2003 30' Sprinter 5er
2001 Dodge CTD
Jarhead 1
Weymouth Ma USA
Posted: 12/15/09 05:54am Link  |  Print  |  Notify Moderator
Get into warmer climate!!
Bill
2004 KSDP 3702
2007 Vue
Semper Fi
skipnchar
Topeka or somewhere else
Posted: 12/15/09 07:22am Link  |  Print  |  Notify Moderator
Correct. YOu can put the warmest coat you have on a snowman and it doesn't make it any warmer. The main problem of using a summer time RV in cold weather is the open belly that exposes the water pipes to the cold. Won't be of much help THIS year but after you take some of the excellent suggestions to get you by temporarily you'll need to enclose the belly of the RV and insulate the plumbing. Adding a heat duct that dumps into the now enclosed belly is ONE way of heating the plumbing but installing electric tank heaters is even better because you could then still use electric space heaters for cabin heat. Adding 12 volt heaters ALSO makes it possible to actually TRAVEL in very cold weather without freeze ups.
Good luck skip
bercher
Edmond, OK
Posted: 12/15/09 07:32am Link  |  Print  |  Notify Moderator
Its been to 10F here in Oklahoma, I second heat tape AKA "wate pipe heat cable".
http://www.homedepot.com/h_d1/N-5yc1vZ1xhm/R-100196820/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Tape the heat cable along any exposed hose and/or pipes you dont want to freeze, then wrap them in some type of foam insulation, then wrap with some duct tape or something to help keep the rain out.
Good luck.
2010 Open Range 385RLS
2009 Chevy Durmax/Allison 2500HD Ext Cab
PullRite SuperGlide 18k
