RV.Net Open Roads Forum: Fifth-Wheels: Mobile Suites - Specifications?
 > Mobile Suites - Specifications?
johncrazyels
Vancouver/California
Posted: 12/19/09 11:38am Link  |  Print  |  Notify Moderator
I can't find any info re weights and dimensions of the various units of the Mobile Suite. Do I have to contact the company directly? To my knowledge, it's the only 5er company that doesn't provide such basic information on their web site.
SooperDaddy
Posted: 12/19/09 11:54am Link  |  Print  |  Notify Moderator
You're right, their Brochure shows a lot of info and pics, just no specs! I wonder why they'd do that?
Try Googling the specific MS model and on the dealers website there are specific specs such as weights, lengths, etc. Good luck!
My posts shouldn't be taken for factual data, and are purely fictional, for entertainment purposes, should not be constituted as related to scientific, technical, engineering, legal, religious, spiritual, or practical advice. After all it's FREE! Amen. ">
Mayoman
Tennessee
Posted: 12/19/09 12:07pm Link  |  Print  |  Notify Moderator
Our 2005 36TK3 is 36 ft. inside length. Total length ~38ft. Weighed on scale 16,500 lbs. with our load, estimate 14,800 empty for our 5er.
Pin weight 3400 lbs.
Volvo VNL 780
2005 Mobile Suites 36TK3
ET Air Ride Hitch
amxpress
Clayton, NC
Posted: 12/19/09 12:56pm Link  |  Print  |  Notify Moderator
Because of the large variety of models available, the specs and floorplans are on a seperate brochure. Which model are you interested in?
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L still at the zoo. (in the serpent cages)
ereed52
Columbus, OH
Posted: 12/21/09 10:05am Link  |  Print  |  Notify Moderator
The specifications you are looking for are listed under floor plans. Click Floorplans than on Specs
Rubber Ducky
Central Indiana
Posted: 12/21/09 09:19am Link  |  Print  |  Notify Moderator
I bet a dealer will tell me that I can pull one of those 43 footers with my 1993 Nissan short bed pickup.[emoticon] By the way, this pickup has a 4 cylinder and automatic. I MIGHT have to use a slider hitch!!
Robert & Tricia
Gemstone
Boydton, VA
Posted: 12/20/09 05:45pm Link  |  Print  |  Notify Moderator
I pulled this info from another forum site...the basic model numbers are equal to the length, give or take less than a foot....
The Select Suite will be the lightest capacity rig
The Mobile Suite will be the middle capacity rig
The Elite Suite will be the heaviest capacity rig
32TK3 Telescoping Kitchen Triple Slide
32RS3 Rear Sofa Triple Slide
36RS3 Rear Sofa Triple Slide
36RE3 Rear Ent. Center Triple Slide
36TK3 Telescoping Kitchen Triple Slide
38RL3 Rear Lounge Triple Slide
36RSSB3 Rear Sofa Side Bath Triple Slide
36TKSB3 Telescoping Kitchen Side Bath Triple Slide
36TKSB4 Telescoping Kitchen Side Bath Vanity Triple Slide
38RLSB3 Rear Lounge Side Bath Triple Slide
38RSSB3 Rear Sofa Side Bath Large Kitchen Triple Slide
38TKSB3 Telescoping Kitchen Side Bath Triple Slide
40DB3 Double Bedroom Triple Slide
Again, you can probably forget looking for weights posted on the internet site, there are too many variables...instead, look at the axle and tire specifications to get an idea of their max possible carrying capacity.
Regards
Gemstone
'06 Elite Suites TK3, '95 KW T-600, '08 Softail Classic , '06 Softail Deuce
arm
High River Alberta, Arizona,Texas, Ontario,BC
Posted: 12/20/09 04:55pm Link  |  Print  |  Notify Moderator
Try searching on www.doubletreervsuites.com and clicking on specifications.
Still can't find actual lengths, weights etc.
Good luck.
1996 Roadtrek 190 Popular
2- Schwinn folding 7sp bikes
Honda EU2000i
Gemstone
Boydton, VA
Posted: 12/19/09 08:21pm Link  |  Print  |  Notify Moderator
Here is some data:
43 footer
DRV
Weights will vary greatly, depending on chosen options...suffice it to say they are very heavy. Our 37' loaded, with granite option, washer/dryer is 19K pounds.
Regards
Gemstone
Delaine and Lindy
Linden Tn. (The View)
Posted: 12/19/09 02:01pm Link  |  Print  |  Notify Moderator
Drv is one of the few high end 5th wheel manufactors that will customize a 5th wheel. As said abov there are many different floorplans. We oreded 2010 Mobile Suites 38 RSSB 4 and used three different floor plans and did remove a window and change some cabinet doors etc. However when we picked-up in Aug there among the paper work and manual was a sheet showing the weight at each wheel and the total weight. I would recomend you contact Drv and they can tell you the exact weight when delivered. GBY.....
2012 Chevy Silverado 3500HD DRW's LTZ ******Traded******
Trailer Saver Air Ride (SOLD) (Sold)
2010 Mobile Suites 38 RSSB 3, with vanity slide (SOLD)
"Montana" our Sweet Furr Kid
12/21/10 "RIP" miss you!!
We are BLESSED!!!!
