RV.Net Open Roads Forum: Beginning RVing: Satellite TV no signal
 > Satellite TV no signal
Beginning RVing Related Tips
bluiz1948
oregon
Good Sam RV Club
Posted: 12/21/09 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
We have had directv in our new motor home, it has a dish on top. we were camped in Eugene OR and got a picture with directv, now we are in Vancouver,WA and can not get a picture. It tells us we have a weak sign/no signal. There is nothing blocking our signal, called Directv and they had me try a couple of things but nothing worked. Does any one have a suggestion of what to try?
StanleyandIris
Louisiana
Posted: 12/21/09 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
Any rain or snow in the area? This will interfere with reception. Are you between mountains, in a valley? Same thing.
Iris
bldrbuck
Boulder, Colorado
Good Sam RV Club
Posted: 12/21/09 11:16pm Link  |  Quote  |  Print  |  Notify Moderator
Did Directv take you through using the signal strength feature? Is the dish pointed to the satalite? Are you in an area that has others recieving Directv? Give is more information.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
haddy1
Chesterfield, MO
Good Sam RV Club
Posted: 12/21/09 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
What kind of dish?
2003 Winnebago Journey DL
2007 Jeep Wrangler Toad
RJsfishin
Winston Or.
Posted: 12/22/09 06:30am Link  |  Quote  |  Print  |  Notify Moderator
Give more info !
Like,...do you know how to aim a dish, or are you depending on automatic doing it for you ? Have you changed any connections etc etc.
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
bobandvicki
indian harbour beach, fl
Good Sam RV Club
Posted: 12/22/09 10:58am Link  |  Quote  |  Print  |  Notify Moderator
We have Dish 500 and have occasionally had to call the Dish techs for help - Sometimes we get a tech who can't help us - sometimes we get a tech who knows less than us - when that happens and it becomes obvious that we are getting nowhere, we thank them - hang up and call again - we never get the same tech twice - not only are you not getting the same tech you are probably not even getting the same country - the 2nd tech almost always is successful - SOMETIMES YOU CAN BE IN A PLACE WHERE THERE IS NO SIGNAL - check with other campers around you that have Direct - Bob
04 Ford F350 KgRanch PSD SB 6.0L 4X4
09 34FT Cougar 318SAB 5th Wheel
Wherever I happen to park
Posted: 12/22/09 11:09am Link  |  Quote  |  Print  |  Notify Moderator
One thing I advise folks with a roof-mounted antenna to do is get a switch, A common A/B antenna switch (about 2 bucks at the google store)
n-USfficial&client=firefox-a&um=1&ie=UTF-8&cid=10829462333985487116&ei=bwoxS9WyK4fClAeX_pmXBw&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CB4Q8wIwAg#ps-sellers">Google Store Link
You unhook the lead to the LNB in on the sat receiver and hook it to "A"
You run a nice new RG-6 cable to a Bulkhead or basement or, in the case of a rig like mine it's mounted on the Brake Bell Crank Bracket, and hook it to the "B" terminal
The remaining terminal gets a short RG-6 Coax jumper to the LNB in on the receiver
now.. When you park under the evil signal eating tree.. You slap the switch fromn "A" (Which by the way means ABOVE) to "B" (Below or you may have noticed a plethora of "B" words in the connection placement list) and hook up your ground dish
Actually you hook up the ground dish THEN slap the switch
Reset the receiver and.. Aim around the obstruction.
elh0146
Sioux Falls, SD
Posted: 12/23/09 07:45am Link  |  Quote  |  Print  |  Notify Moderator
We also are DirecTV customers and as long as there is nothing around to block the signal, we've never been in a place within the USA where we could not get a signal.
Posted: 12/23/09 11:02am Link  |  Quote  |  Print  |  Notify Moderator
I will also ask another question
What channels are you looking for.. I mean if it's HBO or the DirecTV brag channel (100, 101 or 102, forget which) you should see it anywhere
if it is your local Channel 7 (or pick a number) you may simply be too far from home
Check for one of the "Cable" channels or better yet the DirecTV Brag (info) channels. Again, I think that's 102.. I can get it without even an account. In fact it's the only thing I can get without an account.
