RV.Net Open Roads Forum: Class A Motorhomes: 1972 Dodge Escapade Class A ...
 > 1972 Dodge Escapade Class A ...
DaGunster
Lakeside CA
Posted: 12/31/09 11:15am Link  |  Print  |  Notify Moderator
Good Day,
Well I bought my first motorhome. It's a 1972 Dodge Escapade - a class A - 20ft in length.
Big spender - I paid $300 for it and $100 to tow it.
The body and interior are in outstanding condition given the condition - the paint can use some work - but I think Charger Blue & Yellow will look nice on it :-)
It has a 318 Dodge engine. It does not run at the moment - they owners daughter said that it did run when put in storage.
I've some questions.
* Where can I find technical information on the chassis of this thing?
* How can I tell what transmission is in this thing?
Any advise people can offer me specific to Dodge chassis motorhomes with 318 engines?
Picture 1 : http://i45.tinypic.com/13yexr6.jpg
Picture 2 : http://i46.tinypic.com/2upzbif.jpg
Much thanks in advance.
Cheers
Gunnar
* This post was edited 12/31/09 11:58am by DaGunster *
trop-a-cal
Palm Coast Fl
Posted: 12/31/09 11:26am Link  |  Print  |  Notify Moderator
Go to a Chrysler dealer and have them run the VIN. 318's were leaded regular gas for many years, as they did not have hardened valve seats. That was changed somewhere in the 70's so it may or may not need an additive to the todays unleaded regular fuels. If you run it on to days fuel and it was designed for leaded you can burn the valve seats,(in the heads). The transmission probably is torque flight three speed, that should have the filter and fluids changed first thing, even before you drive it. It has points and you can update it to electronic ignition for better performance. Chiltons has manuals, and they may still be available at your local library.
chast
Marlton, NJ
Posted: 12/31/09 11:29am Link  |  Print  |  Notify Moderator
Hey Gunnar-Congrats on your purchase--much luck and many happy miles in your future. The Dodge 318 is a great engine. How bout some picture posts on your new baby? Google Dodge chassis owners club and you will find all kinds of support. Post any questions you might have here and the answers will be forthcoming. We have owned three motorhomes on the Dodge chassis and while they may not be the most exciting or innovative going, they are strong and dependable. Happy 2010 and best of luck to you.
chartrue2@aol.com
MrWizard
Traveling
Posted: 12/31/09 11:33am Link  |  Print  |  Notify Moderator
very likely an M400 chassis, the VIN# will help you identify the chassis
do a google search for dodge M400, and for 318, you will find all kinds of info
the biggest hassle will be identifying your brake system, take a rally good look at the master cylinder and follow the brake lines all the way to the rear wheels
dodge used 3 different systems in the 70's
some have a vacuum boost at the master cylinder
others have boost cylinder under the frame near the rear axle
there are (2) sizes of brake shoes and drums
the electrical for the chassis it pretty std across all models, except for the ignition switch harness & plug which changed around 1978 70-77 should all be the same
I had a 72 lifetime class A from Boise cascade on a 71 chassis, friends with other dodge chassis, i've put a fair amount of time into working on dodge RV's
* This post was edited 12/31/09 11:46am by MrWizard *
Radiate The Happy
1997 F53 Bounder 36s
DaGunster
Lakeside CA
Posted: 12/31/09 12:01pm Link  |  Print  |  Notify Moderator
Wow! Thanks for the responses - and so quick. I'll check out the Google area and do some digging.
Pictures are in my original post - I edited the post and added pics.
Cheers and Happy New Year.
sum1
So-Cal
Posted: 12/31/09 12:07pm Link  |  Print  |  Notify Moderator
My '72 27' M400 had a 413" motor, but to second what Mr Wizard said, brake systems can vary. If I remember correctly, mine had two boosters. The thing stopped on a dime and gave me 9 cents change. Rode like a truck on it's bias ply, tube tires and split rims, but tracked straight and had LOTS of clearance for accessing those remote, rough sites I prefer.
mowermech
Billings, MT
Posted: 12/31/09 02:25pm Link  |  Print  |  Notify Moderator
Keep in mind that there may be two different VINs, one for the chassis, and one for the finished coach. If you are researching the chassis, you will want the chassis VIN, NOT the coach VIN. The VIN on the title/registration should be the coach builder's number.
I ran into this problem with my old 1977 Pace Arrow Class A on a Dodge chassis.
The 318 is a good engine, to be sure, but if I were to fix one of those old coaches up, I would install a 360 with electronic ignition and throttle body fuel injection. One of the pre-computer ones to make it simple. Of course, a 440 would be nice, but perhaps a little bit much!
Yes, the tranny should be the 727 TorqueFlite three speed. If you ever have any problems with it, there are heavy duty kits available for those things that improve them greatly over the way Chrysler built them. I highly recommend going heavy duty if you ever have to rebuild it!
Good luck, and have fun with your new toy!
CM1, USN (RET)
Daily Driver: '06 PT Cruiser Turbo
Toy: 1999 Dodge QC LWB, Cummins, Automatic, 4X4
Other toys: a pair of Kawasaki Brute Force 750 ATVs.
DaGunster
Lakeside CA
Posted: 12/31/09 02:53pm Link  |  Print  |  Notify Moderator
So far I have confirmed - It is an M300 chassis for sure.
Thanks all - I will have some questions as time goes on.
LVJ58
Las Vegas, Nevada
Posted: 12/31/09 04:13pm Link  |  Print  |  Notify Moderator
Here's a link to transmission rebuild kits etc:
http://spideraccessories.stores.yahoo.net/bm10229.html
Have Fun--
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
johnsonbert
Houston, TX-Ironwood, MI
Posted: 01/01/10 08:24pm Link  |  Print  |  Notify Moderator
Congrats, we had 72 but 26' long. Had 6000 miles on the 413ci when we got it in 1994. We put radials and regular wheels on it and redid a lot of it and put on about 45000 miles on it before selling it in 1999. JCWhityney haed many chassis parts for it, obtained dash air add on kit from a junk yard and also added a roof air, body was prewired. One disadvantage, ours did not have a grey tank, just one for the black, had to keep a 25 gal tote hooked up when in use. We had a lot of fun in it and somebody else still is. One of the nice things about these is you don't have to be an electronic genius to work on them.
Happy Travels Bert
2006 Monaco Dynasty Diamond IV 42' Tag, ISL 400,(new to us), Residential Refrig, 10KW Onan, Bosch Washer/220V Dryer (previously 2003 American Tradition 40W) 2010 Chev Malibu LT
