RV.Net Open Roads Forum: Travel Trailers: New purchase "must have" items for TT?
 > New purchase "must have" items for TT?
Page of 5
fla-gypsy
North Florida
Posted: 01/17/10 06:53am Link  |  Print  |  Notify Moderator
The extras you need depend largely on the type of camping you do and how well you like gadgets.
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
sdadams
Posted: 01/17/10 06:57am Link  |  Print  |  Notify Moderator
Sounds like you have it covered except for steaks, beer, etc...
2010 Flagstaff 831BHSS
2011 Chevy 2500 HD CC 6.0 Gas
go6car
New Jersey
Posted: 01/17/10 07:10am Link  |  Print  |  Notify Moderator
Congratulations on the new TT!!! Some other things you might want to consider, depending on your subjective preferences -- Other stuff you might already know/have, but here goes: (I might be redundant in what some of the other posters have already outlined):
Should already have a smoke detector/carbon monoxide detector in the unit. Make sure you test prior to delivery.
• Good mirrors on your tow vehicle (if not already equipped with them)
• Chemical for the toilet/holding tanks
• Black streak remover for the exterior
• A good, portable leveler.
• Lynx levelers or similar (if you didn’t already have for the popup. We used our old ones from our popup days, but did need some additional ones for the TT)
• A sewer hose support (if you go places that don’t let you have the sewer hose on the ground. A decent, relatively cheap one is the “Camco’s Sidewinder”).
• Depending on where you camp (if you go places where you only have a 50 amp site) -- A 30amp to 50amp converter. (A good one I’ve found is “Power Grip Dogbone Adapter 30 amp to 50 Amp”).
• Ball grease for the hitch ball. Lowes has some from Reese in a small tube that is ideal for portability. (Looks like a small tube of Vaseline).
• Might want an awning mat for the length of your new awning. Tons on Ebay and the other camping stores. I have a 20’ Prest-o-Fit one (looks like turf) and also a 20’ one that is a plastic weave type (like from Awningmats.com). Both are good – depends on personal preference.
• Bracket for the refrigerator/freezer that allows you to leave it cracked open when not in use and also during the winter. (The dealer should probably have this). Is a small gray plastic wedge thing…
• Depending on camping needs, some people install a second battery (we did) right next to the original one. Got a permanent plastic case with strap from the dealer to house both.
• Depending on where you camp, might want a water filter/purifier. This is personal preference, and there are a ton of units (permanent and disposable).
• Might want more water pressure from your standard-issue showerhead. We got an Oxygenics one (Camping World). It made a huge difference!
• Ask for anything you need to de-winterize the unit (should already be done when you get it), and also anything you’d need to winterize next season (RV antifreeze, etc.). Good info here: LINK
Most important-- ENJOY!!! (Shouldn't have any trouble with that one, LOL!!) [emoticon]
2016 American Coach Revolution 42T
2004 Jeep Wrangler
HappyTrails2U2
Tennessee is home but being held hostage in GA.
Posted: 01/17/10 07:20am Link  |  Print  |  Notify Moderator
Don't forget wheel chocks. A couple of these BAL X-chocks will keep the rock and roll down while your walking inside your trailer. I bought a starter kit for mine. They say it's cheaper than buying each item separately but I couldn't swear to it but anyway it seems to have just about everything you could need in it. I did buy the upgrade kit that has a better sewer hose in it than the one that came with the kit.
2010 Rockwood Signature Ultra Lite 8315BSS
2003 Chevy Silverado 1/2 Ton Extended Cab
downtheroad
Pacific Northwest
Posted: 01/17/10 07:49am Link  |  Print  |  Notify Moderator
Lots of good suggestions...but I have to question one of them..
a solar panel is not a "must have item."
Go camping, take a pad and paper, you will soon discover what are "must have items."
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
flguppie
Treasure Coast-FL
Posted: 01/17/10 08:09am Link  |  Print  |  Notify Moderator
toilet paper for RV
don't leave home without it
FL-Guppie "small fish in a big pond"
2014 KZSpree Connect 220rbk
2010 Ford F150 SuperCrew 5.4L
TURBODOG1000
INDY
Posted: 01/17/10 08:30am Link  |  Print  |  Notify Moderator
I second the GOOD MIRRORS and you also need AWNING TIE-DOWN STRAPS, it can get windy! & a BATTERY SHUT-OFF SWITCH. The LP leak detector cannot be turned off and will drain the battery in 3 days during storage. The sewer hose needs to be a upgrade from the one that comes with your new TT, like RHINO brand sewer hose. A set of WALKIE TALKIES, you are not backing up a pop-up any more and walkie talkies can save a marriage.
Congrats on your new TT!
2002 F350 PSD Crew Cab Long Bed DRW
2016 Highland Ridge RV, Mesa Ridge MR310BHS TT
Back-up camera on the TT with infrared & microphone
Prodigy
ScanGauge II
Reese duel cam hitch, U-bolt style ($40 at a garage sale)
2 canoes, 3 kayaks, & camping dog (Tootsie)
eric james
Sioux Falls, SD
Posted: 01/17/10 08:38am Link  |  Print  |  Notify Moderator
I second the awning tie downs. I use the "hold awn" brand. Excellent product.
I found going to a larger camper the walkie talkies are critical (unless you like to hear your better half yelling at you).
I also have a tree branch lopper. Nothing worse than a tree branch scratch on new fiberglass.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
NHFirefighter
NH
Posted: 01/17/10 09:01am Link  |  Print  |  Notify Moderator
Tire pressure gauge. The right tow set-up - weight distribution if appicable and sawy bar.
3500HD Duramax
Crusader 290RLT
Line-X and Fold-a-Cover
coug
Eastern Washington
Posted: 01/17/10 09:07am Link  |  Print  |  Notify Moderator
Here's what we did with our first popup and we do it with every trailer after that. Get the free catalog from your RV dealer and just go through it page by page. You will always see something you forgot. Then take a paper and pencil with you every time you go. We bought one of the composition books and started making a list of things to buy right away, things to fix right away, and stuff to do over the winter. As someone else once said on this forum eventually you will create a list of things to take out! Have fun!
2010 Arctic Fox 22GQ
2011 Chevy 2500HD LTZ
Page of 5
