RV.Net Open Roads Forum: Travel Trailers: Water line repair
 > Water line repair
depdawg
GA
Posted: 01/26/10 08:45pm Link  |  Print  |  Notify Moderator
Where can I purchase the plastic line and fittings used in campers for fresh water? This is for a a Jayco. Also what is the size of the lines?
I'm hoping they can be obtained at a Lowe's or hardware store......
2001 Ford F-250 PSD Crew Cab
2007 Jayco Jay Flight 26 BHS
Deewayne
Metro Denver, Co
Posted: 01/26/10 09:04pm Link  |  Print  |  Notify Moderator
You should be able to get the pipe from ace hardware.
Go here for fittings: http://www.dan-marc.com/rv-parts-plumbing-pextite.html
Dewayne & Linda
Amateur Radio - ??DLH, Wife - ??LLH
2006 Chevy 2500HD, LBZ.
1992 24 ft. Fleetwood Wilderness
The stars seem closer when sitting around a campfire.
swebber
Brunswick , MD
Posted: 01/26/10 09:32pm Link  |  Print  |  Notify Moderator
The water lines should be 1/2", the size should be printed on the lines themselves.
Steve Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 2000W Inverter & 4000W gennie's
My Camping Pic's
LIKE2BUILD
Mt. Zion, IL
Posted: 01/26/10 10:20pm Link  |  Print  |  Notify Moderator
Lowe's will carry all the PEX tubing, fittings, and crimp supplies you will need.
Do not use the Pinch clamps on fittings:
Instead use crimp rings.
The Crimp Tool is a little spendy, but worth the investment.
Here's a pretty good PEX repair guide. The stuff is easy to work with once you're used to it.
KJ
'02 Jayco Qwest 324G
'04 Chevy 2500HD CrewCab |6.0L|2X4|4.10:1 | Eaton Posi-Trac
Curt MagnumV receiver
Eaz-Lift Hitch with Reese Dual Cam
2000 Crownline 205BR
'96 Polaris SLT780 PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (12, 6, & 4)
1 forgiving wife!!!
jeffymac
Port Orford, OR
Posted: 01/26/10 10:27pm Link  |  Print  |  Notify Moderator
Im an RV parts dealer and here's my humble opinion.... It is getting harder to find anyone who uses crimp fittings anymore. Pex slip on fittings are what most repair shops are switching to nowdays, and we sell a ton. They will fit most rv lines as well and are available at most rv parts stores now. They come in almost any configuration in seval sizes from 3/8 to 1/2 and so on. They are easy to install yourself and require only cutting the line cleanly with a plastic tubing cutter, then slipping the fitting on and pressing firmly to seat the seal ring inside. Just thought this may save you some searching, some time, money and labor at a repair shop!
pigman1
Delaware
Posted: 01/26/10 11:04pm Link  |  Print  |  Notify Moderator
I've been using the pinch clamps with PEX for quite some time without a problem. The crimp tool I bought at Lowes pinches all sizes and I paid $29 for it. Tools for the copper rings are size specific. Just be sure you keep the tool adjusted properly with the gauge that comes with the tool.
John
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Street Atlas USA Plus
sharker6
fulltime KY, NC, FL, MA, TN
Posted: 01/27/10 04:15am Link  |  Print  |  Notify Moderator
Another option is the plumbing used for lawn irrigation systems. It's adjacent to the plumbing dept. at Lowes. I've also used garden hose repair parts for emergencies.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
depdawg
GA
Posted: 01/27/10 06:04am Link  |  Print  |  Notify Moderator
Thanks for all the replies. Now that I know the name of the tubing that helps tremendously.
I did a quick search on the Lowe's website for PEX tubing.
The line I am working on is a clear piece of plastic piping. It goes from a clear supply line to the outside shower, on the hot water side. I did not see the same type tubing on the Lowe's site but if I am understanding everyone if it is the same size it will work. It is only a piece a few inches long.
hwybnb
Posted: 01/27/10 07:13am Link  |  Print  |  Notify Moderator
Unless you plan on doing a lot of PEX plumbing don't bother with the crimp fittings and tool. ACE Hardware and many home improvement stores sell Flair-It and Shark Bite fittings for making PEX connections without special tools.
I have never seen clear PEX so the line you are looking at might be vinyl but you should be able replace it with PEX. Seeing that it is a hot water line I do not think vinyl is the right type to use.
SUMRX4
VA
Posted: 01/27/10 06:41am Link  |  Print  |  Notify Moderator
I would echo the slip-on pex fittings. Yes the clamp ring fittings work but I have two issues with then. The connectors themselves are copper which corrode. I had one blow out on my water heater in the house after only 6yrs. Second when you see one of the crimping tools you will understand my point here. They are about the size of a pair of bolt cutters. I don't know about your RV but not many places in my rig I could even get these on the lines much less have room to swing the handles.
So much has changed with plumbing over the years it's quite simple to make repairs today. Years back you had to put copper to copper, pvc to pvc. Now a days they have fittings that will just about allow connecting most any two types of material. Just make sure the fitting is the correct size for each line going in it and you should be fine.
 > Water line repair
