RV.Net Open Roads Forum: Fifth-Wheels: Washer/Dryer vent Install
 > Washer/Dryer vent Install
waroland
Mt. Juliet, TN
Posted: 01/29/10 05:49pm Link  |  Print  |  Notify Moderator
I am about to install a combo washer dryer in the front closet and I need to know the proper way to rout the dryer vent and where to cut the vent to get outside. I have purchased the 90 degree adapter.
Thanks for your help.
* This post was edited 01/29/10 09:23pm by waroland *
2002 Fleetwood Revolution
2006 Honda CR-V toad
donn0128
Pronounced Ore-gun
Posted: 01/29/10 05:57pm Link  |  Print  |  Notify Moderator
I don't think there is a "proper" way to install the dryer vent. Make a small hole where you think you want to install the vent and probe inside the wall for studs. Once you have identified where they are and that there is no electrical or plumbing in the way, proceed cutting the hole. It is really scary the first hole you make in that beautiful side, but be careful, use lots of masking tape on the outside to help prevent tearing and you will soon have a 4 inch hole all done.
Don,Lorri,and Charlie Bear 2016
The Other Dallas
Mile High
CO
Posted: 01/29/10 06:11pm Link  |  Print  |  Notify Moderator
Keystone had an orange sticker on ours that said approximately where to vent. I measured a couple of dozen times to make sure I avoided graphics. I drilled a pilot hole and measure again. I used a 4" hole saw, but it was too shallow to finish from one side. I had to go outside to finish drilling.
Ours was in the center closet, so there may be a few differences, but for the most part just make sure you place in a spot that is easy enough to route the vent hose behind the unit. Ours was tight enough I had to go up an over the dryer motor, but I believe they want you to stay low on the combos because of the damp lint.
We have some pics in our mod link below if you want to see, but again ours was in a different location. My buddy just put the combo in his forward closet and just went straight out the side.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
2chiefsRus
USA Somewhere
Posted: 01/29/10 06:20pm Link  |  Print  |  Notify Moderator
Won't it take a lot longer to dry with a 90 degree bend instead of venting it directly outside? It already takes quite a while for a dry cycle on a combo unit.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
waroland
Mt. Juliet, TN
Posted: 01/29/10 07:58pm Link  |  Print  |  Notify Moderator
Straight out would go through the front cap.
christopherglenn
Near Yosemite
Posted: 01/29/10 11:21pm Link  |  Print  |  Notify Moderator
you want to drill a pilot hole all the way through, then holesaw from each side. if you punch through from the inside to the outside you will cause more deformation to the siding, then if you cut it from the outside in.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Flintstones
Massachusetts
Posted: 01/30/10 06:08am Link  |  Print  |  Notify Moderator
On our Cedar Creek there was a sticker where to drill. I would use a 4 1/8 Lenox hole saw with center guide drill bit, make sure the hole saw and the drill bit are sharp. Set the drill bit for no more than 1/2" to 3/4" out from 4 1/8" hole saw
1. Figure out from the inside where the wall studs are, look for the small staples that attach the inside wall panels to the studs, they are usually filled with white spackle.
2. Carefully look at where the electic wall outlets are in the laundry area, chances are good the wires run kind of level to and from the wall outlets, make note from the outside (measuring down from the roof) where any marker light wiring may logically be, and lastly think about where plumbing supply, drain and vents may logically be.
3. Carefully, and without a lot of pressure, drill though the inner wall material, stop immediately when you punch through. Clear away the fiberglass insulation, look for plumbing and electrical.
4. If all looks good from the inside, proceed to drilling the hole through the exterior by drilling without much pressure through the interior wall only until the guide bit penetrates the exterior wall of the camper. Then go outside, and on good stable footing, proceed to finishing the hole from the outside.
If the inside hole turns out to be bad, that's o.k. as it won't show like a bad outside hole will. I would consider not using any type of angle vent kit, less restriction means better drying. When you caulk the vent on the outside, think like a raindrop.
Finally, I would never, ever, drill a hole in the fiberglass front cap.
ArkieVet
Fulltimer
Posted: 01/30/10 11:08am Link  |  Print  |  Notify Moderator
Drill the smaller hole and "explore" inside the wall to be sure that you have room for the larger hole. Then, when you're sure, drill only through the inside wall. Inspect, again, before drilling through the outer wall. Then, pilot hole, only, from the inside, and finish from the outside. Good luck.
Retired U.S. Army SFC ('67 - '88)
(Infantry, AG Corps)
Nam Vet - Infantry (68-69-70 & 71-72)
2009 F350 Crew Cab Dually PSD Tow Boss
2009 Cameo F35SB3 w/TST TPMS
Life Member MOPH and DAV
KC5UCN
fishingbob61
cookevill tn
Posted: 01/30/10 12:34pm Link  |  Print  |  Notify Moderator
My HR had a sticker on the wall to make the hole, maybe if you contact the man they can tell where to cut hole.
Bob and Sue
51 years camping
2005 Fleetwood Bounder DP
2004 Chevy. Tahoe
bstark
Ontario, Canada
Posted: 01/30/10 01:31pm Link  |  Print  |  Notify Moderator
If aluminum studded, on a very cool morning without any heat in the coach view the condensation pattern on the side of the coach created by the fiberglass without framing behind it warming faster than the framing profile. That might give you a place to start.
Today is just the tomorrow you worried about yesterday!
