RV.Net Open Roads Forum: Fifth-Wheels: Where are trailer locks on 5th Wheel slide?
 > Where are trailer locks on 5th Wheel slide?
Mantej Kaur
Canada
Posted: 02/03/10 02:35pm Link  |  Print  |  Notify Moderator
Hello, I recently purchased a 2005 Travelaire 275 Genesis fifth wheel. It indicates it has "travel locks" on the slide. The owner's manual is not with the RV and I'm having a hard time finding info on the internet. Does anyone know where the releases are for the locks? I have looked up on the slide, but cannot find anything. Are the locks outside the RV? I believe something is engaged, as it will not open when the button is depressed. I would appreciate any help I can get. Thanks.
Post moved from Towing Forum to 5th Wheel Forum for better response
Moderator - Towing Forum
* This post was edited 02/03/10 11:43pm by an administrator/moderator *
jetboater454
Camping or home
Posted: 02/03/10 02:45pm Link  |  Print  |  Notify Moderator
All "travel locks" I have ever seen are inside the trailer on top of the slide.They fit between the slide and the wall.Get a small step ladder and look on the inside. good luck.
Hunting down a 5th wheel toyhauler
'07 Toyota Tundra
Harley Dyna Lowrider
KID2TEXAS
West, Tn
Posted: 02/03/10 02:50pm Link  |  Print  |  Notify Moderator
They look like slide bars that you would use in an 18 wheeler trailer to keep things from sliding around. They usally have a lever on them to lock them in place. Like stated above they are usally always on top of the slide out but can be on the side but always inside the rig.
good luck.
Kid
Here is what they look like, click here...
* This post was edited 02/03/10 03:02pm by KID2TEXAS *
2006 Ford F-250 Super Duty, Amarillo Special Edition 4 X 4 & 6.0 PSD,
2015 Columbus 320 RS
Me, a Wife and two crazy kids that are to cool to go anymore ">
Golf cart that matches the Amarillo truck.
Mn Hkr
Hardwick,Mn / Mission,Tx
Posted: 02/03/10 03:35pm Link  |  Print  |  Notify Moderator
On our 5ver(NuWay HitchHikerII) the lock is on the bottom outside of the larger slide. On ours it is a bolt-approx 5/8"- that you would put a nut on to hold it in while you travel. We have not used it because it has not moved while traveling.
skipnchar
Topeka or somewhere else
Posted: 02/03/10 03:37pm Link  |  Print  |  Notify Moderator
The answers you got are true SOME of the time but certainly not in all cases. Some trailers have built in locks that are actually a bolt that is placed in the slide from outside of the trailer. Some are on the awning side of the trailer and some are as others mention, bars that fit on the slide roof on the inside of the trailer. I have no idea where your particular model are located. It's ALWAYS a good idea to use slide locks so you get a water tight seal when towing in wet weather. There is little chance of a slide coming OUT and that's really not what they're designed to prevent but they keep the water out.
FiverDragger
MI
Posted: 02/03/10 07:11pm Link  |  Print  |  Notify Moderator
My fiver has it's locks on top of the slides. They snap locked or unlocked and stay up there whether the slide is in or out. I forgot them once and it made a 70.00 mess. Now there are reminder notes on the slide switches.
Ron
2002 Chevy 2500HD 6.0 4.10 axle ext cab longbox
36' Carriage Lite Dbl Slide Fifth Wheel
Ron, Barb and Scooter the watchmop
Sinterior
Vernon BC
Posted: 02/03/10 09:13pm Link  |  Print  |  Notify Moderator
Hi, I had a 2004 Genesis GW270, and the slide "locks" were 2 aluminum bars with rubber ends that went between the slide and inner wall of the side. They just wedged in place but do work! DW forgot to remove then once and the gears skipped over 4 teeth of the rack. Luckily no damage but I had to have the slide realigned.
DianneOK
Donnelly, ID
Posted: 02/04/10 07:27am Link  |  Print  |  Notify Moderator
That was not true in our case [emoticon] [emoticon]
We had a '02 Alfa the had "traveling" slides [emoticon] All three would creep out while driving down the road. Put in a total of five new motors, one full set of gears and had 3 fires because of poor construction and inadequate components. After the third fire, I was going to let the beast burn to the ground [emoticon][emoticon]
That was when we ordered a Teton.......
Dianne (and Terry) (Fulltimed for 9 years)
Donnelly, ID
HAM WB6N (Terry)
2012 Ford F350, diesel, 4x4 SRW, crew cab, longbed
2009 Lance 971 Truck Camper, loaded
Life Member Good Sam
Geocache..."RVcachers"
RV net Blog
Camping, nature's way to feed the mosquitoes
LEWISCLAN
southern ca.
Posted: 02/04/10 08:47am Link  |  Print  |  Notify Moderator
wow I heard Alfa was a nice set up
BiggerBen
Alberta Canada
Posted: 02/04/10 09:24am Link  |  Print  |  Notify Moderator
We have the same unit, Legacy/Genesis LW275 (04 model). Our slide lock was a bar with rubber ends.
2004 Kustom Koach Legacy LW275
2005 Dodge Ram 3500 CTD SRW
DW, Hanna and Lucie (our dog and cat)
