baunno
Tennessee
I cleaned my fresh water tank last week and noticed that the gauge doesn't work on our 2012 28-RLPT. It became apparent when over filled water started raining between the sealed under carriage and the frame. Has anybody had this problem?
I'm thinking that I'll fill it to what I guess is around half full and pull it to our first trip of the year to see if it frees it up.
I suppose warrantee would cover this. Any thoughts?
"Onward thru the fog!"
Huskerdude
Norfolk, Ne
baunno wrote: I cleaned my fresh water tank last week and noticed that the gauge doesn't work on our 2012 28-RLPT. It became apparent when over filled water started raining between the sealed under carriage and the frame. Has anybody had this problem?
I suppose warrantee would cover this. Any thoughts? On our 2011 Premier 28rlpr , the fresh water fill tube at the tank wasn't tightened.Heading out for the first trip of the year !!!
"> Huskerdude, Mrs. Huskerdude 2017 Crossroads Sunset Trail ST310RL, 2005 F150 XLT Crewcab, 5.4 liter, tow package
gregrc75
New Bedford, Massachusetts
Added a shelf to the top of each wardrobe. Thanks to an idea in the "cool mods" thread in the TT section of this forum
Greg and J
Ben - Yellow Lab. Charley - Red Lab
2018 Keystone Bullet Premier 30RIPR
2016 Nissan Titan XD SL 5.0
SabreCanuck
Winnipeg
I finally got around to finishing off adding some drawers to the Bullet... Just waiting for some trim to come in from Keystone to finish things off..
New pot drawer under the bench.
![[image]](http://i40.tinypic.com/2j13akx.jpg)
![[image]](http://i41.tinypic.com/aorixh.jpg)
New drawers for DW's drawers ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif) ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
![[image]](http://i43.tinypic.com/aajivn.jpg)
2011 GMC 2500 D-Max Denali
2015 Palomino Columbus 325RL
Our kids have 4 legs. ">
gregrc75
Thank looks fantastic! How did you match the stain so well?
Carolina_Camper
Whisperng Pines, NC
gregrc75 wrote: Added a shelf to the top of each wardrobe. Thanks to an idea in the "cool mods" thread in the TT section of this forum.
Have my shelves cut, but couldn't find the studs to screw the Firring Strip to. How did you locate them?
gregrc75
Carolina_Camper wrote: gregrc75 wrote: Added a shelf to the top of each wardrobe. Thanks to an idea in the "cool mods" thread in the TT section of this forum.
I used cove molding and applied heavy duty liquid nails to the back. I pressed the molding to each side of the cabinet and used my brad nail gun to hold them in place while the glue set up. I just used 3 small brads on each.
SabreCanuck
Winnipeg
gregrc75 wrote: Thank looks fantastic! How did you match the stain so well?
All of the drawer faces are pieces from the camper so it was really easy to match the stain... LOL.
The drawer face under the bench is the piece that I cut out from that panel. I took the entire end off and very carefully ran it through the table saw.. So I actually ended up with four straight edge's and a 1/8" gap all the way around![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif) . The drawer face is flush with the panel when closed which I'm not exactly sure of yet, but we'll try it that way for a while.
The drawer faces under the bed are actually shelves from the pantry that I had left over from a previous mod of "slide out pantry". I cut two shelves to the size I needed.
All of the currently raw edges are going to get edging applied that I ordered from keystone dealer for $0.40/foot or something like that.
CampinEarls
Schertz, TX
Nice job!
Can you post a pic of the inside of the compartments where you attached the drawer slides and stuff?
My plan was to do exactly what you have done in both areas, I never got around to doing it last year.
2009 Chevy Z71 CrewCab
2010 Bullet Premier 31BHPR
gregrc75
SabreCanuck wrote: gregrc75 wrote: Thank looks fantastic! How did you match the stain so well?
The drawer face under the bench is the piece that I cut out from that panel. I took the entire end off and very carefully ran it through the table saw.. So I actually ended up with four straight edge's and a 1/8" gap all the way around ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif) ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif) . The drawer face is flush with the panel when closed which I'm not exactly sure of yet, but we'll try it that way for a while.
Great idea! I never thought of using the shelves and other hidden panels so it will match perfectly. I thought of making a countertop extension out of the laundry chute cover so it matches but havn't thought it out yet in my head.
I see you also got matching handles, were those from Keystone as well or were you able to find them at a home center?
