RV.Net Open Roads Forum: Tech Issues: Sewer hard plumbing
 > Sewer hard plumbing
nymustang50
Lindenhurst NY
Posted: 03/24/10 08:56am Link  |  Print  |  Notify Moderator
I have a 34ft 5ther at a seasonal spot up in the poconos and I want to hard pipe the sewer lines but want to make it removable as well. Anyone do this?
Bumpyroad
Virginia
Posted: 03/24/10 08:59am Link  |  Print  |  Notify Moderator
any good RV store will sell a bayonet fitting that is threaded to take a standard pipe thread.
bumpy
targaboat
sulphur springs, tx, usa
Posted: 03/24/10 09:33am Link  |  Print  |  Notify Moderator
I would keep a small length(6") of flexable RV sewer hose and keep the connection to the RV standard. Otherwise as some have said, you can buy the necessary fittings from the local RV stores and home stores.
Fly Boy
SpoiledRotten
Central Mississippi
Posted: 03/24/10 09:49am Link  |  Print  |  Notify Moderator
I hard pipe mine as well when it's parked on the Ponderosa (our one pad personal campground in the country). I use my flush king and a 4" rubber connector with S.S. clamps to make the connection between the PVC and the 5er.
Remember though... DO NOT open your black tank valve and leave open if you are staying in one spot for extended periods of time. You'll still need to dump when the black tank gets over half full.
Just the 3 of us...SpoiledRotten, TotallyRotten, and ALittleRotten
2000 F-250 Lariat, CC
7.3 PSTD-Superchipped
2005 33RL2 New Vision - AKA "SpoiledRotten"
2000 Jeep Wrangler Sahara Edition
hitchup
Fulltiming and sitting.
Posted: 03/24/10 09:10am Link  |  Print  |  Notify Moderator
We always use PVC hard pipe since we stay in one place about 6 mos. DH gets the 4" PVC with at least one elbow and uses a short piece of flexible RV hose that attaches to RV. Then he clamps the PVC to it and we're good for the winter. Have never had any leaks.
2014 DRV Mobile Suite Estates 38RSB3....our custom home
2014 Ford F450 KR CC 4x4......his office
2015 Lance 1172 TC.....mobile Motel FOR SALE
Working Fulltimers since 3/2005
"Shoot for the Moon! Even if you miss it, you will land among the Stars."
RJsfishin
Winston Or.
Posted: 03/24/10 09:22am Link  |  Print  |  Notify Moderator
Hard piped lotsa things. If ya don't want to glue it, drill it,..run a ss screw into it.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KingDome/sat, 2 Oly Cat heaters, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
nymustang50
Lindenhurst NY
Posted: 03/24/10 10:04am Link  |  Print  |  Notify Moderator
Yeah I know about the keeping it closed I'ved had the seasonal spot now for over 3 years its just now I'm in the mood to go to hard pipe so it works better..
