RV.Net Open Roads Forum: Dinghy Towing: Ford Ranger as a Toad:
Search only in Dinghy Towing
 > Ford Ranger as a Toad:
jerseyjim
New Jersey
Posted: 03/31/10 07:38am Link  |  Print  |  Notify Moderator
Buying a Ranger...probably a late model used...and need some info. I've researched here in the forum...but can't locate the info I need:
Figuring to use the Ranger as a toad (FOUR DOWN), I need to know:
Can it carry around 1,000 pounds in the bed? (I want to put my Harley and an electric winch (Cruisemaster) in the truck.
Not caring if the truck is a stick shift or automatic....a stick means no mods at all...put it in neutral and go: the automatic, if a 2 wheel drive...I get a Remco disconnect....if it's a 4 wheel drive, I need a "chip" in the transmission? What might the Ford part # be?...and what is the proceedure to tow 4-down?
Thanks in advance.
gone2dadesert
Encinitas, Ca
Posted: 03/31/10 07:59am Link  |  Print  |  Notify Moderator
Checkout the dinghy guide Here
As far as 1K lbs in the bed, the Ford website doesn't say...[emoticon]
good luck
2011 Hurricane 31J
2008 Jeep JK Unlimited Rubicon
texasbaskets
Frisco, TX
Posted: 03/31/10 08:22am Link  |  Print  |  Notify Moderator
I read through some Ranger forums and the only two cautions I saw are that you might need load levelers and the tailgate cables should be reinforced.
This is kinda cool. [emoticon] [emoticon]
Compact Bed Extender.
Good luck.
Michael, Kay, and Prissy (The vicious 6 pound Malti-Poo)
'05 Coachmen SportsCoach SE 372DS a.k.a. ">"Mana's Cabana"">
RedRollingRoadblock
Oregon
Posted: 03/31/10 08:23am Link  |  Print  |  Notify Moderator
If you go to Ford Fleet they have the information. Go down to item #12 "Four-Wheel-Down" Towing then you can select your year.
PUCampin
Castaic
Posted: 03/31/10 08:48am Link  |  Print  |  Notify Moderator
Payload for the Ranger is around 1200lbs, so yes you could put the Harley in the back. But you may want to add some overload springs or load levelers of some kind. Also be sure you have tires that can handel the load, Rangers usually have P tires stock.
2007 Expedition EL 4x4 Tow pkg
1981 Palomino Pony, the PopUp = PUCampin! (Sold)
2006 Pioneer 180CK = (No more PUcampin!)">
Me"> DW"> and the 3 in 3 ">
DD"> 2006, DS "> 2007, DD "> 2008
n4hwl
Murfreesboro,TN
Posted: 03/31/10 08:42pm Link  |  Print  |  Notify Moderator
I have a remco disconnect on a 1988 ford ranger that I don't need anymore that I would like to give to someone.
Ken
2014 Tiffin Zephyr
T bone
Amarillo
Posted: 04/01/10 08:49pm Link  |  Print  |  Notify Moderator
I have a 2002 Ranger I tow and sometimes haul two ATVs in the back. I did put air shocks on and have no troubles .
2017 Georgetown 329S
2015 Toyota Tacoma toad
JohnnyT
On The Road
Posted: 04/02/10 06:01am Link  |  Print  |  Notify Moderator
Moved from class A forum.
jerseyjim
New Jersey
Posted: 04/04/10 05:04am Link  |  Print  |  Notify Moderator
Thanks for all the responses....reality being reality, I could not find a "good" Ranger in my price range....but I did find a really nice 2003 extended cab Chevy S-10.
Now...I need a Remco driveshaft disconnect. Anybody got one to sell or "give away"? LOL!! None listed on E-bay or craigslist......
Again, thanks.
tatest
Oklahoma Green Country
Posted: 04/06/10 12:36am Link  |  Print  |  Notify Moderator
1000 pounds in the bed is a real stretch. I've done it. It may be within the documented capacity of the truck (at least for a regular cab) but it sure rides low in the back and is real light on the front end.
Tom Test
Itasca Spirit 29B
