Open Roads Forum
Print  |  Close
Topic: V10 oil burner?
Posted By: mblaster on 04/04/10 11:32am
I consider myself a bit fanatical whan it comes to oil and filter changes. I change frequently say every 3 months or so and maybe 2-3 K at most. I use Mobil 1. I'm always towing and the rig pulls like a champ. I've got 35k on the odo without a hitch and there are no leaks. Heres the thing. I add 6 quarts and drain 5 every time....interesting.
Anyone else burn some oil?
01 Southwind 32V
02 Grand Cherokee toad
21ft Carrera Elite daycruiser (summer)
Posted By: Corkey05 on 04/04/10 11:38am
Is 1qt going into the filter? The filter doesn't drain when you drain the oil. If you're replacing the filter during oil change, then one qt will go to the filter (assuming it's a 1qt filter).
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
Posted By: barnaclebill on 04/04/10 12:04pm
That sounds correct to me! Fill with 6, drain out 5, the rest is in the filter and engine. Not every drop drains out.
2009 Monaco Camelot 42PDQ
425 Cummins
Chevy Equinox or Tracker
Blue Ox towing
Posted By: Artum Snowbird on 04/04/10 12:14pm
It does sound a bit odd, I wouldn't think the filter holds more than a couple of cups. After I take my filter off, same engine as you, I hold the filter and drain it into the pan.
You would think that once the initial oil is in the nooks and crannies inside the engine, if that stays there, then it is always there, and it doesn't need replacing.
Anyway, you have piqued my interest now. Does the dipstick start and end at the same place before and after the change? It is normal to use some in 3000 miles, and some doesn't come out of the filter... (weigh it to see how much is left).
Mike and Carole
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers
Posted By: Tom_Anderson on 04/04/10 12:16pm
If you're using 1 quart between oil changes, I would hardly call that an oil burner. Do you ever check the oil in between changes? Is it low?
Posted By: fourmat on 04/04/10 12:20pm
ck it before changing i bet your full last quart is in the filter and motor like others have said
2009 Challenger
Posted By: BaldyD1 on 04/04/10 02:38pm
Had a 2002 Mirada 340MBS with V-10 for about 35,000 miles and never had an oil consumption problem and do not remember adding oil between the changes every 5,000 miles. Plz 4giv anee mrs-spellins.
Speedy, Jackie & Dusty {Shih-Tzu/Maltese}
2006 Kountry Star KSDP 3912
2005 Saturn Vue (dinghy)
Posted By: fla-gypsy on 04/04/10 02:43pm
I agree with this too. The level on my dipstick never moves but I have not really measured how much I have when drained.
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
Posted By: BobR on 04/04/10 03:57pm
Check your owners manual. It will advise oil capacity with and without an oil filter. I seem to remember oil consumption of 1 quart every 1000 miles is acceptable.
Posted By: ArchHoagland on 04/04/10 04:54pm
Only real way to test this would be to change the oil, drive around the block and change it again. See what you measure the second time.
A quart over 3,000 miles is about normal as far as I'm concerned. Used to have a 70 Olds Cutlass with a 350 that burned a quart every 1,000 miles.
GM said that was allowable and within their specs.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Posted By: moparmaga2 on 04/04/10 05:17pm
The filter on the V10 is not exactly small, I am sitting here looking at a Motorcraft one for an upcoming oil change. Whenever I change the oil, the filter is full to the brim with oil. It would not hold a whole quart, but maybe half of one.
2015 Jayco Greyhawk 31DS
2013 Ram 1500 Laramie Hemi
2008 Yamaha FJR Sport Touring Bike in the bed of the truck
Posted By: Tom_Anderson on 04/04/10 06:06pm
Am I the only person who has never measured how much oil came out of my engine when I drained it?
Posted By: 4gone on 04/04/10 05:37pm
I never take out exactly what I put in on any vehicle. Ther is always some in the filter, even if you empty it, compare it to the new one and it's always heavier, some stays in the engine, clings to the drain pan, in my case runs down, hits the front I-beam and gets wiped with a rag. If it reads good on the dipstick before you change it and doesn't read a quart low, I wouldn't (and don't) worry about it.
2007 Damon Daybreak 3276
2010 Suzuki Grand Vitara
Even Brake
Firestone air bags
Blue Ox Alladin tow bar
Hankook Tires
Posted By: jy on 04/04/10 05:59pm
My 99 V10 has 70k miles and uses about a quart of oil every 3k miles according to the dipstick.I rarely add any oil as I usually change the oil every 3k miles.
99 Coachmen 322QB, Ford V10,18 foot Load King open trailer, 2007 Mustang GT Toad, Gibson exhaust,Royal Purple lubricants.Recently retired and planning on doing more RV'ing.
Posted By: 427435 on 04/04/10 06:08pm
Even a quart in 1000-1500 miles wouldn't be excessive in something that only gets 6-7 mpg.
Forget about it.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 80,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
Posted By: ottocontrol on 04/04/10 07:34pm
2000 35U suncruiser with 76,000 miles on the V10. Run mobil 1 and it will burn about a 1/2 to 1 quart between oil changes. I tow the jeep everywhere we go and I do not baby the V10 and never a issue. So it sounds about right to me.
Posted By: pkunk on 04/04/10 08:16pm
I'll be about 1/2 quart low in 5,000 miles at 61,000 on the odometer. Drained won't quite fill the 5 qt. container & the rest is in the filter.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
Posted By: ArchHoagland on 04/04/10 09:15pm
Nope. I've never measured mine. Measured the Xmission fluid so I'd know how much to put back in, but never the engine oil.
Posted By: Golden_HVAC on 04/05/10 06:44am
Hi,
I found that my 1975 F-350 truck 460" engine would use about a quart of oil every 1,000 miles or so, and I always considered that good, because some oil is burned while lubricating the piston rings. But I went on a 5,000 miles trip with my Bounder motorhome with 97 F-53 and 460" engine and only used up about 1/2 quart. I never even checked the level until I got home.
I had never used more than a tiny amount of oil between yearly oil changes at about 4,500 - 5,500 miles.
My FOrd Edge is about 1/4 quart low after 1 year and 5,500 miles on the engine. Yes I need to change the oil soon. My 1967 VW based dune buggy, with 1600 cc engine is another story, I think it uses a quart every week or two. We have come a long way since air cooled engines.
Good Luck,
Fred.
Posted By: Daboo on 04/05/10 06:54am
i measure the oil in,,but never out...i keep watch on the dip stick during intervals...I had a 99 model V10--it burned about a quart between changes...I used Mobil 1 and use it for 5k miles....it was a good engine...better (IMOP) than this 8.1 we have now
Served proudly 1957-1965..U.S. Air Force
Posted By: 03FatBoy on 04/05/10 07:00am
Start the engined up after the change and let it run for a bit, shut it down, and let it set for a bit (long enough for oil to get back into the pan). What does your dip stick say?
Melissa & Steve (MNC USNR retired)
FMCA F335327, GS
'05 HR Ambassador 36PDD, Saturn Vue Toad
8.3L Cummins w/ 6sp Allison
Posted By: SRT on 04/05/10 07:01am
Yup. But I use Amsoil 5W-30 (my son is a dealer). At 68,000+ miles the "oil consumption" has gone down to 1 qt per 5,000 miles. Still have the same motor home.
Print  |  Close
