RV.Net Open Roads Forum: Class A Motorhomes: Leveling jacks leaking
 > Leveling jacks leaking
bassfishing6163
home
Posted: 04/08/10 12:42pm Link  |  Print  |  Notify Moderator
Has anybody had any luck using Transmission fluid stop leak on their hydraulic jacks. I only have one jack leaking(my fault).
Thanks in advance
tommy wilson
southern ca, usa
Posted: 04/08/10 03:05pm Link  |  Print  |  Notify Moderator
go to hwhcorp.com for the correct answer.
tommy wilson
1996 kountrystar dp
spartan mountainmaster chassis
dougrainer
Carrolton, Texas
Posted: 04/08/10 03:37pm Link  |  Print  |  Notify Moderator
I don't think anyone will recommend it as it may cause a problem with the solenoid valves and such. I will say NONE of the manufacturers use it or recommend it. Doug
fcooper
St. Augustine, Florida
Posted: 04/08/10 07:09pm Link  |  Print  |  Notify Moderator
I got one of mine (power gear system) to stop leaking with a temporary fix. It was a consistent leak. I could wipe down the exposed ram and then see a small line of fluid slowly running down the ram. This jack had been weeping for a while, but then got worse.
I was ready to remove the jack and take it to a local hydraulic shop for repair, but I needed to make a trip and did not have time to do the repair. Knowing that auto brake fluid will swell gaskets designed for petroleum based fluids, I did the following:
I fully extended the jacks, and wiped down the leaking jack's ram with a clean rag. I then coated the ram (thick coating) with auto brake fluid, and retracted the jack. After letting it sit for 15 minutes, I repeated this process.
We've now made three trips without any leak. If it starts leaking again, then I'll remove and repair.
Obviously, I give no warranty with this repair advice.
Fred
Fred & Vicki
LoreeB99
Sparks OK
Posted: 04/09/10 01:27pm Link  |  Print  |  Notify Moderator
As per another suggestion in this forum, I decided to try the transmission sealer before rebuilding my leaking Power Gear jack.
There was a slow leak down the ram alternating between the rear jacks when extended. They did't seem to both leak at once.
This is on a 2001 F53 Triton V10 chassis.
I replaced the ATF fluid (per mfg instructions) in the reservoir but added 16oz of "White Shepherd Automatic Transmission Sealer" in place of the last 16oz of ATF. I then cycled the jacks 6 times before completing the process. No leaks so far for about one month. We full-time in our MH so the jacks are down much of the time. To me it was worth a try before rebuilding. Good luck!
Bill & Loree
2001 Fleetwood Southwind 36T
F53 Triton V10
