RV.Net Open Roads Forum: Travel Trailers: Removing Wallpaper
 > Removing Wallpaper
maria_bettina
Auburn, CA
Posted: 04/22/10 02:38pm Link  |  Print  |  Notify Moderator
I'm thinking of removing the wallpaper from our '92 Terry TT (18D) and painting the walls a neutral color. At our old house, we used a device that basically made holes in the wallpaper, and then sponged on a solution (I think water-based) and allowed the goop to dissolve the glue and then peeled off the wallpaper in strips (sometimes tiny, sometimes big).
What is the best method/solution for removing wallpaper from the TT interior? Is the same process applicable or should we do something different (oil-based vs water-based solution)?
And what are we going to find underneath the wallpaper? Plywood?
Thanks!
MusTangFilly
Rockin' and a rollin' in Earthquake country
Posted: 04/22/10 03:51pm Link  |  Print  |  Notify Moderator
I spent some time removing wallpaper from the insides of an older trailer. After scraping and working my buns off, I had a light bulb go off in my head. I retrieved my blowdryer from the house, plugged it into an outlet in the tt, held it up to the wallpaper warming it as I scraped and pulled, and voila! Much easier to remove when the glue was warm, or slightly hot. And yes, there was plywood beneath. Hope this helps you..........still lots of work.
May we all have safe travels.
Dick_B
Palos Heights, IL USA
Posted: 04/22/10 04:03pm Link  |  Print  |  Notify Moderator
Is the wallpaper in good shape? If so, why not just paint over it with a roller. I did this at my house and you can't tell it is painted over wallpaper. It may take a couple of coats but it will be a lot easier than trying to remove the paper (which is the easy part) it's the glue that is more trouble!
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
maria_bettina
Auburn, CA
Posted: 04/22/10 04:38pm Link  |  Print  |  Notify Moderator
It's in good shape in most spots except around the windows. I think one of the previous owners took out the windows and when he put back in, the wallpaper scrunched up in some spots.
Grammie
North Carolina
Posted: 04/22/10 05:42pm Link  |  Print  |  Notify Moderator
On HGTV they use a spray bottle of warm water with some fabric softener in it. Wallpaper comes off really easy on HGTV.
Dream Catcher
JJBIRISH
Butler, PA, USA
Posted: 04/22/10 06:16pm Link  |  Print  |  Notify Moderator
If its like most RV’s the wall board is mfg with the wallpaper on it and it is extremely difficult to remove, usually causing more damage to remove it than to just paint over it… often it is a vinyl coated wallpaper and will need primed with a thin even coat of gripper from HD so it don‘t peel…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
KLO
Southern OK
Posted: 04/22/10 06:38pm Link  |  Print  |  Notify Moderator
I think I would try to paint it then put extra trim around the windows to cover where the wallpaper is scrunched up. All TT I have seen have the vinyl coated stuff on the walls that won't come off without a lot of damage.
4*phun*2
Canada
Posted: 04/22/10 07:47pm Link  |  Print  |  Notify Moderator
Downy clothes softner mixed with water. I am sure someone here will have the right mixture. I use a cup to a couple gallons of water when I take labels off wine bottles.
Glenn & Karen
'08 Chevy LT 3500 HD 4x4 CC LB DRW (nice hips)
'06 F350 4X4 Lariat CC LB DRW (nice hips) retired
'09 Victory Lane 38SRV Toy Hauler
'02 HD Road King FLHRCI KRUZN
'04 F150 XLT Super Crew
Our Toys
Wes Tausend
Bismarck, ND
Posted: 04/25/10 07:17pm Link  |  Print  |  Notify Moderator
I would seriously consider painting over the wallpaper instead of removal, too. At one time I fixed a lot of drywall surfaces that were damaged by paper removal. The wood panel under the TT paper should be more durable than drywall, but it still might leave a rough surface. It is hard to tell when non-textured wallpaper is merely painted over which is much simpler.
One other minor consideration: The vinyl surface provides some marginal barrier protection from dry vapor infiltration into the wall cavity where it condenses to water. In cool weather, this problem is magnified in campers because the same vapor from ordinary living is released into a much smaller dwelling and attracted by cool walls. The wrinkled wallpaper around the aluminum window frames is likely been caused by this insidious process rather than uninstall/install. Most people don't notice condensation except on the window glass, or on tent walls in a tent camper, but it is ever present, seeping everywhere it can.
Some paints or primers are quite good at vapor protection if you do remove the vinyl.
Wes
Days spent camping are not subtracted from one's total.
- 2000 Excursion V-10 - 2000 F-250 CC 7.3L V-8
- 2004 Cougar Keystone M-294 RLS, 6140# tare
- Hensley Arrow - Champion 4000w/3500w gen
- Linda, Wes and Quincy the Standard Brown Poodle
TXiceman
Full Time RVer
Posted: 04/25/10 08:03pm Link  |  Print  |  Notify Moderator
Clean the wall paper to remove any oils, etc. Now paint the wall paper with Shielz. This will seal the wall paper and provide a good base coat for the paint. Now you can paint with any latex based paint.
Ken
Amateur Radio Operator.
