RV.Net Open Roads Forum: A new wide-axle wheel chock is coming to town...
 > A new wide-axle wheel chock is coming to town...
Page of 5
chrispitude
Allentown, PA
Posted: 05/12/10 05:38pm Link  |  Print  |  Notify Moderator
Hi folks,
BAL has a new X-chock on the way for wide-axle trailers:
BAL X-tended Fit X-Chock
The same great features of the original X-Chock in a wider application. Extends up to 17" to accommodate wide track axle spacing commonly found on Bullet, LaCrosse, PrimeTime, Passport, etc.
This is a great approach because it does not require ground contact. One can be used on each side, even if one side is up on leveling blocks. We pick up our Heartland North Trail 21FBS in a few weeks, and I'll be buying two of these when they come out. I am a big Rotochock fan, but they were not an option with the North Trail's wide axles.
- Chris
tvman44
Southwest Louisiana
Posted: 05/12/10 06:00pm Link  |  Print  |  Notify Moderator
I have a pair of the regular X chocks and really like them.
Papa Bob
Husky 16K hitch, Tekonsha P3,
LarryJM
NoVa
Posted: 05/12/10 06:10pm Link  |  Print  |  Notify Moderator
WOW at around $45 each they are really proud of those and I guess they serve a purpose in some unique situations, but I've never seen a need for them or to store, put them in and then tighten them. My $8 for 4 of the cheapo plastic chocks along with a 10" piece of 2x6 if needed has served me well for the last 35 years of TT camping. Mine also never rust, require maintenace/greasing and weigh almost nothing along with taking up almost no storage space.
Anyway different strokes for different folks.
Larry
* This post was edited 05/12/10 06:20pm by LarryJM *
RAINKAP INSTALL////ETERNABOND INSTALL
DocP
Macedonia, OH
Posted: 05/12/10 06:11pm Link  |  Print  |  Notify Moderator
Good news, indeed, and thanks for the heads'up! I always used a pair of the regular BAL's on past TT's, but they wouldn't work on my newer Keystone.
2017 Thor Hurricane 35M Class A motorhome
2018 Coachmen Apex Nano 213RDS travel trailer for short trips
chrispitude
Allentown, PA
Posted: 05/12/10 06:20pm Link  |  Print  |  Notify Moderator
LarryJM wrote:
WOW at around $45 each they are really proud of those and I guess they serve a purpose in some unique situations, but I've never seen a need for them or to store, put them in and then tighten them. My $8 for 4 of the cheapo plastic chocks along with a 10" piece of 2x6 if needed has severed me well for the last 35 years of TT camping. Mine also never rust, require maintenace/greasing and weigh almost nothing along with taking up almost no storage space.
Larry
Hi Larry,
A 10" piece of 2x6 won't go very far when the axles are spaced 24" apart. The newer wide-axle trailers require a bit more to chock them. While the cheapo plastic chocks will indeed keep the trailer from rolling away, they never stabilized the trailer's rocking to my satisfaction. Locking the wheels solid improved the trailer stability noticeably.
For the money I spent on the tow vehicle and trailer, $45 is not asking too much if it provides a tangible and perceptible benefits. It's certainly less than I paid for my ProPride hitch. [emoticon]
Sandia Man
Rio Rancho, NM
Posted: 05/12/10 06:43pm Link  |  Print  |  Notify Moderator
Great news for those with the extra wide gap between their axles. I have BAL stab & scissor jacks and their deluxe locking chocks and all have performed well over the years.
LarryJM
NoVa
Posted: 05/13/10 02:38am Link  |  Print  |  Notify Moderator
Larry
Hi Larry,
Then you don't understand what I posted since what I use will work just as good regardless of the distance between the axles. The 10" piece of 2x6 is to put under the wheel on either side of the axle and use the cheapo ramp to get a good angle on the board against the wheel when extra support is needed.
Larry
wdcd
dacula GA
Posted: 05/13/10 06:09am Link  |  Print  |  Notify Moderator
I built a set out of 2X4 and a threaded rod. Had the 2x laying around and spent $5 on the hardware. Made the camper rock solid. Check threads on here as this is where I got the info on how to build them. this is the pic I got from here and what they look like. Mine are much larger as my wheels are 15" apart.[image]
Lantley
Ellicott City, Maryland
Posted: 05/13/10 06:31am Link  |  Print  |  Notify Moderator
Larry
Larry do you have any pictures? I don't understand how your set up compares to the other devices either. Are you able to crank your boards somehow to create additional tension on the tires?
07Duramax w/hips,12Open Range,Titan Disc Brake
H-head TPMS,BD3,K-Bee exhaust brake,RV safepower
Ox Bedsaver,RV760 w/BC20,Glow Steps
Arvika rack,BakFlip,RVLock
5500 Onan LP,Prog.50A surge,keyless RV Lock
Correct Trax,Splendide
willald
NC
Posted: 05/13/10 06:45am Link  |  Print  |  Notify Moderator
...And you don't understand some things very well either, if you're trying to suggest that placing 2x6 wood blocks in front of and in back of the axles can secure the trailer from rocking as well as X chocks like is being discussed here.
As one thats used your approach to chocking the weels as well as numerous between-the-wheel chocks (including a form of the X chocks being noted here)....Suffice it to say, there is NO comparison. The X chocks (or really any between-the-wheel type chock) do a MUCH better job of holding things steady, and are usually much easier to set up and take off.
Only way boards and the cheapo ramp would come close to working as good as an X chock, is if you pull the trailer forward up onto one chock in front, then place one in back to put tension on the tire and force it into a tight 'cradle' between the two chocks. Thats a lot of extra work, though, that you also have to do when breaking camp.
If you're willing to do all that every time you set up and break camp just to save a few $$, knock yourself out. But, there *are* easier and better ways for those that aren't stuck on using the same methods that were used 50 years ago. [emoticon]
Anyway, back to the subject: Yeah, I saw these new chocks on BAL's web page a few weeks ago. Glad to see they finally came out with something for all these newer trailer that have the axles spaced further apart. Also saw they have a newer, improved version of the regular X chocks, that look pretty cool, too.
I still use the 'redneck' between the wheel chocks made from 4x4 wood posts cut up and threaded rod. Actually been thinking about scrapping them and getting a pair of the regular X chocks, though. Main reasons being, the X chocks would be lighter, take up considerably less storage space, and would be a little easier to deploy. That, and the threaded rod on my 'redneck' chocks is starting wear out.
Well, thanks for posting this, Chris. I think this will be a welcome site to owners of newer trailers that have the axles spaced further out.
Will & Angela
2 children that love camping, Stephen & Allison
2012 FR Georgetown 351DS on F53 (V10) Chassis
See it here
Page of 5
