RV.Net Open Roads Forum: buying a used class A under $30,000 recomendations
 > buying a used class A under $30,000 recomendations
dondeemolly
yet to purchase
Posted: 05/15/10 04:58pm Link  |  Print  |  Notify Moderator
I am considering buying a used class a for less than $30,000. Is one engine better than another in gas engines such as Ford or Chev.
What's the best way to determine the condition of the engine and trans?
Any help will be appreciated.
Don
Ka Ron
Kelowna
Posted: 05/15/10 05:25pm Link  |  Print  |  Notify Moderator
Some people are Chev fans and other Ford. Is one better than the other..that depends which fan you are talking to.
Best thing to do would be to have a mechanical check done on older units. That way you can know what condition it is in and also you will know what you have to fix if you buy it.
Join Us For A Trip Down The RV Highway
lizbard
Nacogdoches, TX
Posted: 05/16/10 06:40am Link  |  Print  |  Notify Moderator
Definitely get a separate mechanic to check over the engine, transmission, etc. If you know someone who has an RV and knows about the systems, see if they will check it out for you.
We have a 2002 35' Winnebago that we paid $29k for. We did not have someone else check it and wish we had. Don't forget to check the recall lists and ask if the RV has had it done.
In deciding on whether to buy a gas or diesel, I also checked about maintenance since I don't change the oil in my car and we are retired. Check to see what the cost of changing the oil and filter for gas or disel in your area.
Daveinet
il
Posted: 05/15/10 09:38pm Link  |  Print  |  Notify Moderator
You can get a pretty nice Foretravel DP for that price.
As far as picking between Ford and Chevy, the biggest advantage Chevy has over Ford is the availability and internet knowledge of after market ad on performance enhancement.
IRV2
bsinmich
Holland, MI
Posted: 05/15/10 06:42pm Link  |  Print  |  Notify Moderator
Once it is out of warranty the best engine is the one that has had the best general maintanance. Unless you get one of the few with records you can have a mechanic make some tests or take your chances. Modern engines will take a lot of abuse so your risk is low in my opinion.
1975 GMC Eleganza II & 1995 Roadtrek Versatile. Both old enough to vote and drink (gas)
mrblanche
Posted: 05/15/10 07:50pm Link  |  Print  |  Notify Moderator
Ask to see maintenance records. I got them with the $13,000 Trek we bought, one owner and 88,000 miles. Every oil change, every tire change, every battery change, modifications, problems, etc.
427435
Rochester, Mn
Posted: 05/16/10 03:57pm Link  |  Print  |  Notify Moderator
Try and get a 2000 or newer MH on a Ford chassis. Wider wheel tread along with a good engine and tranny. Also many more places to get service and parts.
Do a search on Workhorse brakes to see why I wouldn't go near a MH on a Workhorse chassis.
As far as DP's, be prepared for higher maintenance costs and really expensive repairs if anything does go wrong with engine or transmission.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 80,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
frankdamp
Anacortes
Posted: 05/16/10 02:06pm Link  |  Print  |  Notify Moderator
The biggest disadvantage of a Chevy motor is the chassis it comes with! Go look at the threads on "Autopark" and on "Workhorse Brake Problems". All that grief sure turned me into a Ford preferrer.
Frank Damp, DW - Eileen, pet - female Labrador (9 yrs old), location Anacortes, WA, retired RVers (since Dec 2014)
UltraKen
Ohio
Posted: 05/16/10 07:53am Link  |  Print  |  Notify Moderator
Regardless of which engine you choose you also need to do a thorough pre-purchase inspection.
You might find the Used MH Checklist in my signature below useful.
UltraKen
Ex - 1968 Ultra Van
NOW - 1996 Safari Sahara 35' - Model 3530 - Cat 300
Pictures of my Coach
A $93 Rear Camera System
My take on replacing tires
Used MH Checklist
Toad: Dodge Grand Caravan on Tow Dolly or 1981 Vespa on utility trailer
