RV.Net Open Roads Forum: Fix for squeaky back window?
 > Fix for squeaky back window?
weedlady
ohio
Posted: 05/22/10 10:54am Link  |  Print  |  Notify Moderator
I have a '94 RT Independent on a Dodge 350.
The back window Squeaks going down the road- alot! Driving me insane.
I can see what the problem is...one of the latches seems to be loose and is not holding the window tight. Latch on the other side is just fine.
Is there a way to adjust or tighten this window latch? Or any other ideas?
thanks
Martha
senf
Nanaimo,BC,Canada
Posted: 05/24/10 12:07am Link  |  Print  |  Notify Moderator
We had a back end squeak on our 1996 RT versatile. Could never find it, until my eldest son visited and rode in the back. One trip around the block and he identified it as the passenger side back door rubbing on the the bottom of the door frame. Check out your door frame for shiny metal rub spots and lightly grease them if you find any. If it is the window, try clamping it with a small G clamp to close it properly.
"Drive with Care, Life has no Spare!"
2008 Roadtrek C190V 6.0L Hella Fog, Nighthawk Driving, Halogen Reverse Lights, Fiamma Air Horn, Firestone Air Bags, Custom Bed & Mattress, Custom O/Head Tray. website www.sen-f.ca
weedlady
ohio
Posted: 05/24/10 10:01am Link  |  Print  |  Notify Moderator
thanks everyone for your replies. I think I will try to locate a new latch, but it will have to wait until after our trip to da UP for Memorial Day.
In the meantime, I've put a thin piece of rubber between the glass and the window gasket, hoping that will tighten things up perhaps make it better.
thanks again,
Martha
landyacht318
Near a large body of salty water
Posted: 05/24/10 11:45am Link  |  Print  |  Notify Moderator
If your window latches are the same as on my '89 Dodge, they are adjustable. They are held into place by 3 screws. Loosen these three screws a couple turns, and the whole base which attaches to the door can move around a half in in any direction.
Move it down to tighten the window against rubber gasket.
Handbasket
Asheville, NC
Posted: 05/24/10 05:36am Link  |  Print  |  Notify Moderator
Assuming it's a hinged latch, it depends on where the latch is loose. If it's loose at either of the attachment points (metal window frame, or window glass), it should be possible to tighten the screws or bolts. You may need larger screws or re-threading of the holes.
But if the hinge point is loose, you'd maybe need to remove the hinge pin, drill the holes out to the next oversize, and replace the pin with something larger. Depending on the latch's construction, this could be a $$ machine-shop job.
I dunno if it's a RT addition, or a Dodge OEM part (I suspect it's OEM). But maybe best to check with Dodge or RT and ask if the latches are still available, and get a new one.
Jim, "Mo' coffee!"
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory')
Islandman
NW Washington
Posted: 05/24/10 08:50am Link  |  Print  |  Notify Moderator
Weedlady - If you need a new latch and they're not available from the Dodge dealer, you might check with a good body shop and see if they have parts sources to recommend, such as auto salvage yards. But it sounds like just some tightening of screws may solve your problem.
weedlady
ohio
Posted: 05/25/10 07:12am Link  |  Print  |  Notify Moderator
Oh good thanks, that's what I was looking for. I'll give that a try first to see if that will fix it.
thanks again to all
Martha
