RV.Net Open Roads Forum: 22.5 dual tire replacement .... which will fit?
 > 22.5 dual tire replacement .... which will fit?
Scatback
Sun City West, Arizona
Posted: 06/01/10 01:41pm Link  |  Print  |  Notify Moderator
I intend to replace my 235/80/R22.5 Michelin XRV tires on the rear duals shortly. Not being real fond of Michelin's price, I researched other brands...specifically Bridgestone and Yokohama. I see neither of these manufacturers has a 235/80/R22.5 size. This size must be made only by Michelin. Has anybody replaced their rear duals with an alternate brand and size without any problems such as speedometer errors, tire rub, etc?
Retired USAF Nav/Flight Ops
Itasca Meridian 34H
330 Caterpillar
2010 Chevy Equinox
Blue Ox and Brake Buddy
sprintmod1
Allentown, PA
Posted: 06/01/10 09:08pm Link  |  Print  |  Notify Moderator
Just replaced our Micheline XRV's with Toyo M154's; replaced with 245/75R22.5; have put over 1500 miles on them so far and ride is much smoother and we seem to have gained 3/10 to 4/10th of a mile per gallon in fuel milage.
2010 American Coach Revolution 42w; carrying 2014 HD Electra Glide Limited and towing 2015 Chevy Silverado 2500HD.
Dirt's for racing and asphalt for getting there.
410 Sprint Car's rule!
fcooper
St. Augustine, Florida
Posted: 06/01/10 09:35pm Link  |  Print  |  Notify Moderator
Here's another thread with the same question, and has a comparison between your tire size and a 275/70R22.5
Thread about XRV 235.80 22.5
Don't forget to carefully dual spacing.
Fred & Vicki
psyflyjohn
Scam Diego, CA
Posted: 06/02/10 07:02am Link  |  Print  |  Notify Moderator
Replaced my Michelins with Toyo M154's about a year ago. Love em. Good tires.
I have satellite internet - Dial-up speed at broadband prices...
wolfe10
Posted: 06/02/10 07:46am Link  |  Print  |  Notify Moderator
What size wheels (look at outer rear dual for numbers)? That will also limit options and also sets wheel offset.
And MPG change with change in tire SIZE is suspect unless the speedometer/odometer is re-calibrated to account for the change in "revolutions per mile".
Brett Wolfe
2003 Alpine 38'
UltraKen
Ohio
Posted: 06/02/10 02:30pm Link  |  Print  |  Notify Moderator
You need to check the tire specifications from each manufacturer for the size you currently have and any change in size you are contemplating.
Usually you will find the tire diameter, approved rim width, tire width, minimum dual spacing, and Revolutions per mile.
It also helps to have the wheel offset, obtainable from the wheel manufacturer's site.
There are two ways to estimate dual spacing. The first is to compare tire width with minimum dual spacing. The width must be less than the minimum.
You can check your current spacing by measuring from the first rib of the outer tire to the first rib of the inner tire. Subtract the tire width from the measurement across tires and you have the current spacing.
The other way to estimate proper spacing is to multiply the wheel offset by two, and then subtract the width of one tire. Ex. My wheels have a wheel offset of 6.44", doubled is 12.88. The tires I selected are 10" wide. The dual spacing would be 2.88".
Using either method (rib to rib or wheel offset) the estimates are very close.
You should also measure the approximate distance from the outer tire to the edge/surface of the wheel-well. If the replacement tire is 1" wider than the current tire than half that extra width will be on the outside and that much closer to the plane of the body at the wheel-well.
Summary:
1. Tire Revs/mile should be very close. My old 9R22.5s were 543 RPM. my replacement 265/75R22.5s are 540 RPM (about 1% difference).
2. Approved rim width must match actual rim width of your wheels.
3. Tire widths must be close. My 9Rs were 8.9" wide, the new 265/75s are 10" wide.
4. This leads to dual spacing. Subtracting tire width from 2 times the wheel offset gives 3.98" for the 9Rs and 2.88" for the 265/75s. still plenty of room for cooling between the duals.
The bonus: Going from the "inch-standard" (9R) to the metric standard 265/75s meant going from an F rated tire to a G rated tire. I've also got a total of 6" more rubber width on the road, AND based on the coach wgt I am able to go from 85psi front/90psi rear to 75psi front/80psi rear which will give both more wgt capacity and a softer ride.
I've added a spreadsheet that I used to make my comparisons. Towards the bottom is a 3 line set of numbers that is just to do the subtraction of tire width from 2xoffset.
Spreadsheet
* This post was edited 06/02/10 02:40pm by UltraKen *
UltraKen
Ex - 1968 Ultra Van
NOW - 1996 Safari Sahara 35' - Model 3530 - Cat 300
Pictures of my Coach
A $93 Rear Camera System
My take on replacing tires
Used MH Checklist
Toad: Dodge Grand Caravan on Tow Dolly or 1981 Vespa on utility trailer
