RV.Net Open Roads Forum: Where to get front and rear track bar
 > Where to get front and rear track bar
rubidoo
ny
Posted: 06/08/10 12:41pm Link  |  Print  |  Notify Moderator
Hello all
I have been searching all over the internet and made a few calls to see how much I can get a set of front and rear track bar for a 99 Freightliner xc chassis. Called a local dealer here in Edison NJ and got a price of $315 for the rear and $425 for the front
I can't belive that it cost that much. Since the track bar on the f450 I can get shipped for under 100. I have done tons of jeep lifts and they are at most 400 something and they are adjustable and super heavy duty.
I am not sure if I want to cough up that much or just make my own.
Does anyone know where I can get them for a decent price.
Thanks
n5tc
Salado, Texas
Posted: 06/08/10 01:42pm Link  |  Print  |  Notify Moderator
Call Hendersons-Line UP. They are experts in the field. Robert or John should be able to advise you.
www.hendersonslineup.com
Tom and Judith and Yappy Schnauzer Sable
2010 Allegro 32BA
Honda CR-V Tow Car
MartinDYN
SoCal
Posted: 06/08/10 02:57pm Link  |  Print  |  Notify Moderator
rubidoo wrote:
Hello all
Thanks
I bought the front from Houston Freightliner off the discount parts list at the suggestion of a member here. Like $165 delivered to SoCal.
The rear is still hard to find at a price I can afford.
I want to know why both of mine had destroyed bushings after only 34K miles.
'70 Jeep CJ5 + Sears Tent(Sold)
'70 Jeep + '63 Field and Stream Trailer(Sold)
'86 Ford F250 + Lance Camper(Sold)
'73 Dodge Sportscoach Class A(Sold)
'86 GM Eleganza 31' Class A(Sold)
'99 Suburban + '74 AS Landyacht(Sold)
'97 Damon Intruder 35' DP CAT
rubidoo
ny
Posted: 06/08/10 03:02pm Link  |  Print  |  Notify Moderator
Thanks for the info. I will give FH a call to see if they still have that deal. If they don't I am going to see if the F450 trac bar will fit.
I just tried www.hendersonslineup.com they don't seem to have it for the freightliner.
tommy wilson
southern ca, usa
Posted: 06/08/10 03:14pm Link  |  Print  |  Notify Moderator
roadmaster.com
tommy wilson
1996 kountrystar dp
spartan mountainmaster chassis
MartinDYN
SoCal
Posted: 06/08/10 06:50pm Link  |  Print  |  Notify Moderator
tommy wilson wrote:
roadmaster.com
Truck driving school has parts?
wilanddij
CA Desert
Posted: 06/08/10 09:34pm Link  |  Print  |  Notify Moderator
Here's a link to some DIY rear axle track bars DIYs if you want to make your own.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Jeep Wrangler/Blue Ox
"We have met the enemy, and he is us" Pogo
rubidoo
ny
Posted: 06/09/10 07:18am Link  |  Print  |  Notify Moderator
Thanks for the link. With the material sheet and where to get them, makes the task much easier. Very good write up. I am also exploring the option of using the adjustable track bar from an f350 and the rear lower control arm from a jk wrangler. The dimension seems to fit. I just need to give it a test run. If this work, I can get both parts for under 300 shipped and they come with heim joints and are super heavy duty for off road use so should work.
fcooper
Richmond Hill, Georgia
Posted: 06/09/10 07:41pm Link  |  Print  |  Notify Moderator
Maybe I'm missing something here, but my Freightliner chassis already has trac bars front and rear as standard equipment. The Holiday Rambler build date is 06/99.
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
MartinDYN
SoCal
Posted: 06/09/10 09:18pm Link  |  Print  |  Notify Moderator
Fred
That is right, the OP is just trying to get some cheaper$$.
