RV.Net Open Roads Forum: Travel Trailers: Fayette Dayton axles
 > Fayette Dayton axles
detman64
Nebraska
Posted: 06/16/10 10:20pm Link  |  Print  |  Notify Moderator
I have a 1973 Cobra TT with what appears to have Fayette Dayton axles under it with the round cut out center wheels with 4 bolts holding the wheel to the hub. I went to check and repack wheel bearings but ran in to a snag, I did not realize that the drivers side lug bolts were left hand threads and snaped off one bolt in the Hub. I am going to try and get it out at work tomorrow however I would like some infomation on these axles such as what I might do if I can not get the broken bolt out. Where to find replacement parts and parts for the electric brakes ect. Can anyone help me out? Will Dexter axle parts inner-change???????
jetboater454
Camping or home
Posted: 01/22/11 06:31am Link  |  Print  |  Notify Moderator
Not sure on your hubs,but most studs are pressed in from the inside of the hub.Usually just lay the hub flat and hit the broken stud with a bfh and a drift pin.It should come out.Most auto parts places have the studs,Make sure you get the left handed ones.
If you snapped one,I would replace all of them,unless your a lot stronger than I am.
Hunting down a 5th wheel toyhauler
'07 Toyota Tundra
Harley Dyna Lowrider
