RV.Net Open Roads Forum: Fifth-Wheels: pin box height adjust
 > pin box height adjust
makin hay
austin
Posted: 06/20/10 02:28pm Link  |  Print  |  Notify Moderator
hello everyone
rv rookie here
i have just acquired a jayco 345bhs, i have the pullrite 16k slider for short beds, and the trailer to bed box clearance is marginal. i notice several holes in the king pin box that appear to be for height adjustment. is that the case and if so, are there structural limitations that i should know about if i drop the king pin box to a lower set of holes?
thank you truly
Miles Away
Lebanon, TN
Posted: 06/20/10 02:47pm Link  |  Print  |  Notify Moderator
Yes the holes in the pinbox are for height adjustment. Remember, if you decide to make an adjustment, get some help or find some way to support the pinbox because IT IS HEAVY.
I'm not sure what you mean when you say, "The clearance is marginal. [emoticon]" Of course it is best to attempt to have your trailer ride level, and adjusting the pinbox height or the hitch is the way to do that. However, as with many of the newer trucks out there that have a higher ground clearance and or higher bed rails, this is not always possible. You should maintain a minimum clearance of six (6) inches between the top of your bedrails and your trailer, or risk a collision between them on uneven surfaces.
* This post was edited 06/20/10 02:58pm by Miles Away *
M & M "> On the road again!
2007 GMC 3500-SRW-Duramax-longbed-4X4
2008 Keystone EVEREST 348R 5th wheel
2002 SUNDOWNER gooseneck horse trailer
stickdog
Somewhere, USA
Posted: 06/20/10 02:57pm Link  |  Print  |  Notify Moderator
Trucks vary in bed height, pin boxes are adjustable for that reason. Ideally the Fiver will clear the top rails with what you feel is appropriate and will be level as well. With many different configurations of trucks and fifth wheels the only way this is possible is with adjustable hitch components.
9-11 WE WILL NEVER FORGET!
04 HitchHiker DA LS 33.5 RLTG
09 F350 CC DRW 4X4
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
makin hay
austin
Posted: 06/20/10 08:15pm Link  |  Print  |  Notify Moderator
thank you Miles Away and Stickdog.
my truck bed rails are higher and i'm glad the pin box adjustment is a normal thing because i definitely want the 6 inch clearance.
thanks again
makin hay
austin
Posted: 06/22/10 10:01pm Link  |  Print  |  Notify Moderator
thanks to all
i lowered the pin box, hitched her up, and she sits level with 7" bed rail clearance. took her out of the hangar for maiden flight today and all went splendid. now if i could just back it in straight. i admire the big rig folks.
45Ricochet
North Idaho
Posted: 06/21/10 12:33pm Link  |  Print  |  Notify Moderator
I would use new bolts of the same grade also. You also want the torque values correct. You can remove your hitch and use the truck bed and blocking for support cause as stated, They are heavy. 6" clearance is fine, heck I got by with 4" for 3 years till this past year when I made the adjustment. Really happy with the 5.5" I now have.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
RCMAN46
NorthWest
Posted: 06/21/10 12:59pm Link  |  Print  |  Notify Moderator
Raise the hitch in the truck bed first. If you lower the pin box you may have problems with the pin plate hitting the truck bed rails in sharp turns. If the hitch is as high as it will go then you will have to lower the pin box. But as said before be careful that you do not get the trailer too far out of level. You can overload a trailer axle if it is not level.
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
