RV.Net Open Roads Forum: Skylight leaking - how to repair and level out caulking
 > Skylight leaking - how to repair and level out caulking
rechinca
Vacaville, CA
Posted: 06/24/10 04:31am Link  |  Print  |  Notify Moderator
During our last trip we were in a lot of rain when I discovered the skylight in the bathroom (not the vent) was leaking. I had just cleaned and inspected the roof prior to the trip and did not notice any cracks in the caulking. Sure enough, during a heavy rain I found water leaking into the shower from the skylight. I went up and found 3 cracks in the caulking. I covered the area with some plastic sheeting as it rained everyday and it was too wet to repair. I did pull the inner skylight and let the area dry out and it does not appear there is any damage to the structure. The plastic sheeting kept any additional water from seeping in.
Now, I was looking at using eternabond to seal this up, but this is where my question lies. The existing caulking looks like it was put on with a caulking gun in a nice glob forming pattern with several high spots and very uneven pattern. Do I need to scrape that off and take it down to a more level surface prior to the Eternabond installation? If so, what is the best way to do so? I am up to speed with the videos on their web site, but no one really addresses what to do with the globs of caulking and how to take some off to level it out better.
Any help would be greatly appreciated.
ronfisherman
SE Michigan
Posted: 06/24/10 04:53am Link  |  Print  |  Notify Moderator
I scraped as much of the old caulk off and sealed with 4" Eternabond tape. No more leak.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad
Super C Group Forum
gbopp
The Keystone State
Posted: 06/24/10 05:09am Link  |  Print  |  Notify Moderator
It's not necessary to remove all the old caulking. Just remove the loose sections. Then, clean well with lacquer thinner and apply the Eternabond.
If you want to remove the old caulking I know a friend who used a Fein multi-tool. It came off easily with no problems.
Fein is expensive, Harbor Freight has one for around $40 that will do the job.
Just make sure you clean the area well before applying the EB.
AaronS
Montpelier
Posted: 06/24/10 05:35am Link  |  Print  |  Notify Moderator
I'd scrape it as flat as possible. Use a knife, sharpened paint scraper, whatever you have in your garage and scrape and dig away.
I guess to NOT scrape these lumps and bumps away would not harm a thing but would simply not look good.
Take 20 minutes and give it a professional appearance.
Klueck
Posted: 06/24/10 06:31am Link  |  Print  |  Notify Moderator
We kept checking and repairing the caulking, but kept having leaks. We finally put the Eternabond on and no more leaks. As you've seen with caulking, you don't see any holes, but the water does. If you use Eternabond you won't have any more problems.
granite
ohio
Posted: 06/24/10 01:36pm Link  |  Print  |  Notify Moderator
When ours leaked and tried to seal, discovered that the plastic itself kept curling up along its edge. Ended up replacing it.
othertonka
Stockton, CA
Posted: 06/24/10 05:07pm Link  |  Print  |  Notify Moderator
Try a hair dryer to soften up the putty/caulking and use a plastic putty knife to remove it. Now would also be the time to very carefully examine the skylight itself for curled edges and real fine cracks. If you find any, it might be time to replace the skylight and that way you start with everything new and a smooth surface. I had to replace two skylights and it is not a bad job at all. If you decide to replace the skylights post back and I will post how I did it if you so desire. Good luck
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
LarryJM
NoVa
Posted: 06/24/10 05:18pm Link  |  Print  |  Notify Moderator
I would spend the time and get as much of that old useless caulk off and your goal is to have a virgin surface for the Eternabond to bond to for about 1 to 1 and 1/2 inches on each side of the existing caulk and that might be hard to do on the flange area of the skylight w/o removing all of that caulk. The issue is Eternabond doesn't like uneven surfaces because of the none stretching white outer layer and you need it to lay it flat w/o steatching it w/o stresses for the microsealant to adhere properly. You can see what I did and the results in the Eternabond install link in my signature.
Larry
* This post was edited 06/24/10 05:46pm by LarryJM *
RAINKAP INSTALL////ETERNABOND INSTALL
