| Open Roads Forum |
| Print | Close |
| Topic: Another atwood jack Failure |
Posted By: Snow River TC
on 06/25/10 11:41pm
There has been another failure similar to the one I witnessed in Mexico, this time on a host. I am waiting for photos from the victim. Will post when i have them. I have personally seen 2 failures, & now heard about one more. I suggest everyone use extreme caution with these jacks. It may be coincidence, but I don't know. I would be nervous if i had this brand.
* This post was edited 06/26/10 09:06am by Snow River TC * |
on 06/26/10 09:06am
OK have pics now:![]() ![]() ![]() ![]()
Posted By: BradW
on 06/26/10 01:39pm
![]() Looks like someone might have forgotten to unhook before pulling away. Brad |
Posted By: xnorp
on 06/26/10 02:29pm
Brad you are assuming that is what happened here is part of what he said happened. It happened after i raised the camper(same height as i always have), then pulled my pickup just underneath the cabover as i needed to jump out and pull the rear license plate of so that i could affix it onto the rear of the camper. Before i exited the truck, the left front Atwood jack folded, sending this 5100lb camper forward and to the left where it crushed my dually bed and reeked havic on my beautiful camper. Luckily my wife and dog were standing just off the other side when it came crashing down. And thankfully i wasn't about ten seconds ahead of myself as i would have been stooped over at the rear license plate removing it. I would have gotten penned in this collision. After hours of attempts the next day by two tow trucks, i called in a crane service who was finally able to lift the camper off the truck and load it onto a flat bed where it was delivered to a RV collision center. 2000 F-250 SD PS 04 Snowriver 9'6" Rancho 9000X Super Springs Vision 19.5 w/Toyo M608Z |
Posted By: Raften
on 06/26/10 02:42pm
So the camper moved sideways four feet when the jack folded?
Posted By: nycsteve
on 06/26/10 03:46pm
XNORP Could soft ground caused stress on the jacks? Or failure at the point of connection to the camper (rotten frame etc)? I ask as I also have thhe same jacks. Thank God you werent hurt. I hope all works out with repairs , insurance etc. Its every TC owners nightmare. Good luck. Steve
Posted By: Wanderin fool
on 06/26/10 04:15pm
That looks like an aweful lot of damage just from one jack buckling. But who am I do judge. I DO know I will keep a sharp eye on my jacks. I just loaded my camper today and came in and read this! Yikes!!
Duramax/Lance 835 KTM/Arctic Cats Motorized advocate in Colo. CMTRA, our local club. www.cmtrail.org come visit! Other Forums: Thedieselplace.com ( chevsforever) KTMtalk.com (xrcrasher) Pontoonboating.com (Lounge Lizard) Arcticchat.com (400crasher) |
Posted By: sleepy
on 06/26/10 04:46pm
I hope the insurance company sees it different than I do. It appears to me that the camper jacks were probably down enough to stabilize/level the camper... the owner/driver removed the tie downs. then, the driver of the truck probably decideded to pull out ftom under the camper... but fails to extend the jacks as far as possible. The key observation to me is... the back of the camper has been dragged off. NOW, Look at the ladder... how far it is bent back... When the driver realized what was happening and put the truck in neutral it rolled (sprung) backward. but the ladder stayed at the extrem point that it had been bent to. The fastguns tiedowns appear to be in pieces in the pictures to me... Sleepy, 852, Amsterdam, NY
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans/AC/winter pkg AirFoil, Trimetric, LED lights, Platcat vent heat 2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare |
Posted By: xnorp
on 06/26/10 05:32pm
I don't know how it happened just posting what he said happened. Snow River TC saw one do the same thing in Mexico and has pictures of that one. Yes it is a truck campers persons worst night mare and fear. I think about the stories of jacks failing when I am loading or unloading. Makes one start thinking about Stable Lifts like Red Dog and some others have. I hope all works out with the guy ok got to feel for him no matter how it happened his fault or not. I think I would just puke and be done with it. xnorp |
Posted By: 54suds
on 06/26/10 05:44pm
both set of pistures Beddows posted show a truck that sits at an angle from thecamper .It is possible both trucks started to turn before being clear of the legs and the rear of the bed pivioted into vthe jack leg forceing theleg failure the only way to be reasobanle sure is to examine the truck bed ,bumper and the jack legs for rub marks.
07 chev ltz D/A, ext cab,drw,4x4/ Big wig anti sway bar , torque lift tdn's ,superhitch,36" ext 2012 Chalet Acent 100 / 1988 Bigfoot / 2011 Jeep Rubicon Unlimited /1986 Harley FXLRC |
Posted By: jmtandem
on 06/26/10 05:57pm
I have used Atwood jacks and no issues. To me the pics seem to imply that the weight on the jacks was no longer a direct down weight but rather the jacks were forced to take a side load. Look at the front jack bent, that is not from a direct down load.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed. '09 299bhs Tango. |
Posted By: jmtandem
on 06/26/10 06:02pm
For some reason the front jack is too many feet laterally (sideways) from the rear of the truck's normal position for that jack. A single jack failure would likely not move the camper that far. The middle of the cabover part of the camper is sitting about four feet from the middle of the truck resting on the truck's side bed. I suspect that the truck dragged the camper. If just the front jack failed the rear jacks would probably still be just fine, not taking out a huge section of the rear of the camper. It might be one of the tie downs was still attached dragging the camper as the rear section has been dragged with the jack providing resistance and tearing out the back. Also perplexing are comments that two tow trucks could not get the camper off the truck. Why not use four bottle jacks under 4x4's under the camper floor to lift it enough to get the truck out and provide support for the camper apart from the camper's jacks then stabilize with timbers or cinder blocks. * This post was edited 06/26/10 06:22pm by jmtandem * |
Posted By: Noble1
on 06/26/10 06:10pm
Scary.....
Posted By: wp6529
on 06/26/10 06:34pm
jmtandem wrote: For some reason the front jack is too many feet laterally (sideways) from the rear of the truck's normal position for that jack. A single jack failure would likely not move the camper that far. The middle of the cabover part of the camper is sitting about four feet from the middle of the truck resting on the truck's side bed. I suspect that the truck dragged the camper. If just the front jack failed the rear jacks would probably still be just fine, not taking out a huge section of the rear of the camper. It might be one of the tie downs was still attached dragging the camper as the rear section has been dragged with the jack providing resistance and tearing out the back. Also perplexing are comments that two tow trucks could not get the camper off the truck. Why not use four bottle jacks under 4x4's under the camper floor to lift it enough to get the truck out and provide support for the camper apart from the camper's jacks then stabilize with timbers or cinder blocks. I have the Atwood jack, but on a much lighter camper (~2,000#). The pictures puzzle me as well. I know that if my camper is level I can raise any one of the four jacks off of the ground and the camper remains pretty stable. I can't see how any of the jacks could have failed in a way that would suddenly throw the whole camper off enough to twist and fall like that. I also agree that the tow truck comments are puzzling since it's a pretty straightforward rigging job. |
Posted By: sleepy
on 06/26/10 06:44pm
wp6529 wrote: jmtandem wrote: For some reason the front jack is too many feet laterally (sideways) from the rear of the truck's normal position for that jack. A single jack failure would likely not move the camper that far. The middle of the cabover part of the camper is sitting about four feet from the middle of the truck resting on the truck's side bed. I suspect that the truck dragged the camper. If just the front jack failed the rear jacks would probably still be just fine, not taking out a huge section of the rear of the camper. It might be one of the tie downs was still attached dragging the camper as the rear section has been dragged with the jack providing resistance and tearing out the back. Also perplexing are comments that two tow trucks could not get the camper off the truck. Why not use four bottle jacks under 4x4's under the camper floor to lift it enough to get the truck out and provide support for the camper apart from the camper's jacks then stabilize with timbers or cinder blocks. I have the Atwood jack, but on a much lighter camper (~2,000#). The pictures puzzle me as well. I know that if my camper is level I can raise any one of the four jacks off of the ground and the camper remains pretty stable. I can't see how any of the jacks could have failed in a way that would suddenly throw the whole camper off enough to twist and fall like that. I also agree that the tow truck comments are puzzling since it's a pretty straightforward rigging job. I would like to agree that any 3 of my jacks will hold the camper up and level. I've had mine on our heavy camper usually full of water, propane, clothes, food, etc. No problems in 8 years. When unloading my camper... if the truck doesn't move easily... I stop... get out and look... do what ever and try again... gently! |
Posted By: ryoung
on 06/26/10 07:13pm
I don't see this as an Atwood jack failure, but a structure failure to which the jacks were mounted. It appears the initial failure was in the mounting points. Just my guess. What caused the failure of the mounts? If he left the front left tie down hanging from the camper, it could have caught the corner of the truck bumper, dragging the camper forward as the condition of the right rear jack suggests. ryoung * This post was edited 06/26/10 07:31pm by ryoung * 2004 Dodge 3500 Dually HO CTD 6 sp 4.10 2004 Lance 915 |
Posted By: skipbee
on 06/26/10 07:17pm
A few years ago I watched someone try to pull away from their TC without lifting it high enough. There seemed to be a hump in front of the rear tires and the camper was dragged forward resulting in similar damage. Simple stress analysis, direction of force does not jibe with the description of the event. Insurance adjustors often experience these anomolies,"I don't know what happened,it just collapsed.Just like that, boom!" To me the telltale is the condition of the rear jack, the camper was pulled ahead causing that extensive separation, this was not a job requiring Columbo!
skipbee 2004 F350 Diesel CC SRW 19.5" Rickson W/T 4WD 2005 Lance 1121 well found. 12' Porta-Bote alongside All that glisters is not gold. All who wander are not lost. See us on YouTube" Living the Lance Life" 3 of 4. |
Posted By: 54suds
on 06/26/10 09:56pm
?????? beddows was removed from posting here for many reasons , I believe one of the reasons among many was posting inacurate information , quoting Paul, one of his purposes was to "Stir the pot" it has been civil aroud here for the many months he has been restricted do we want his b.s. to be allowed again ?????? * This post was edited 06/26/10 11:11pm by 54suds * |
Posted By: jmtandem
on 06/26/10 10:28pm
"Another Attwood jack failure" hardly is accurate. Anybody's jacks would have failed in the similar situation. Even if the cabover part of the camper was heavily loaded and if one of the front jacks failed, the camper would rotate on the remaining front jack and the opposite rear jack. There would not be any damage to the ladder, nor any ripping of the back of the camper away from the sides. I have no issues with Beddows but this title is clearly misleading. Unfortunately, manufacturers cannot respond due to forum rules.
Posted By: 54suds
on 06/26/10 11:02pm
jmtandem wrote: "Another Attwood jack failure" hardly is accurate. Anybody's jacks would have failed in the similar situation. Even if the cabover part of the camper was heavily loaded and if one of the front jacks failed, the camper would rotate on the remaining front jack and the opposite rear jack. There would not be any damage to the ladder, nor any ripping of the back of the camper away from the sides. I have no issues with Beddows but this title is clearly misleading. Unfortunately, manufacturers cannot respond due to forum rules. ????? you dont have issues with deception ????? its hard enough to get accurate & honest information * This post was edited 06/26/10 11:16pm by 54suds * |
Posted By: FreeLanceing
on 06/27/10 06:04am
It looks to me like he(she) needs some practise backing up. I think they just were backing up to the rig and banged the right front jack. I don't know that they were trying to load just move the truck. OOps! When they hit it, it wiggled around falling sideways and back forward ripping out the rear wall. A carefull reconsrtuction would prove the cause. The tow trucks? crane shows someone with more money than sence. As was stated a few timbers, blocking and jacks would handle this mess.
Posted By: silversand
on 06/27/10 06:34am
If you want to arm-chair investigate this mishap, you'd have to approach it thus: 1)visualize the camper sitting on it's own without the truck in position, and run scenarios where camper simply failed in these ways: a) completely rotted bulkhead corner(s), b) the single and only bent jack in these photos simply buckled for apparently no reason or outside influence (i.e. truck bump or drag, wind, poor soil support, etc); 2)visualize now the truck sitting under the camper with camper still standing and a) the truck was parked under the camper at a 45-deg angle to camper in an unorthodox loading approach and camper went down pivoting, b) camper jack leg buckled pulling 2 of the 3 remaining jacks completely out of the camper's corner structure(s) pivoted and went down. I am not going to be definitive or make any pronouncements on this one, because too much info simply isn't available (i.e. land azimuth/zenith; soil type under jack pads; wind situation; jack height vis truck bed; etc, etc, etc, etc, etc). One thing appears fairly clear: 3 of the 4 camper corner super-structure appears to be rotten or severely compromised...the camper obviously is a total write-off, and truck appears to have at least $15,000 in repairs needed. Silver- Silver 2004 Chevy Silverado 2500HD 4x4 6.0L Ext/LB Tow Package 4L80E Michelin AT2s| Outfitter Caribou |
Posted By: Lots of Stuff
on 06/27/10 10:02am
Reddog1 wrote: I really think using the TC off the truck, on the jacks put people at risk of injury. Wayne I agree by adding ALL jacks. Never load or unload when people are around the camper. The person doing the loading or unloading should also stay clear of the camper. Never use a unloaded camper unless it is as low to the ground as possible. We have used our camper off the truck extensively with no mishaps. Every Lance Camper dealer I've seen shows campers to customers off the truck, on the jacks and with out mishap so far as I know. If the truck camper is used per the manufacture recommendations it should be safe. DG 03 Chevy Silverado Regular Cab 2500HD 4X4 Duramax 04 Lance Lite 915 |
on 06/27/10 06:58am
First of all as to criticism on the title of this thread, the jack failed whether it was an inherent problem, or it was operator caused and the jack stressed beyond its designed limits. I apologize to Atwood if I worded it poorly. I did see an almost identical accident this spring in person with an Atwood jack. I make no apology for calling that one jack failure, since I witnessed it myself and he did nothing wrong that I could see. BTW, he cut the jack open when he got home to see if it was corroding from the inside as I earlier speculated. I thought there may have been a pinhole in the weld that allowed water in. It was not the case, so it appears the metal bent under the weight of the camper only. This latest incident was bought to my attention by the "victim" who did a net search on jack failure & found the account of the incident I witnessed. From what he says, it followed pretty much the same sequence of events that I witnessed personally. The ground does look softer in these pictures I must admit, so who knows, I can only go by his side of the story. I also witnessed a 3rd failure in 2009 in Mexico. Also an Atwood. In that case which was also a Lance, the welds on a front dually bracket failed. It cause the camper to tip onto its side partially. I was impressed with both Lances that there was relatively minor damage, which says something for Lance quality. The extra damage in this latest case is because the camper was higher than with the one in Mexico and from what I underdstand it came down faster. the one in Mexico happened in slow motion. Also, the one in Mexico was on a 3/4 ton Chevy that was much lower to the ground than this one ton dually, so in this case the impact was greater. Since the rear jacks which held firm were extended further, that caused the damage at the rear, due to a lever effect. It is of course possible that the Lance in the other was a stronger camper than this one, but I don't really think so It is curious that the jack in both campers apparently gave way at exactly the same point just below the bracket. Mont at Stablelift has told me he has photos of at least 150 jack failures similar to this one, he would not say which on the 3 brands, or how many of each. That tells me that camper jacks in general are a hazard under certain circumstances. I suppose I could say everyone, including myself, should have a stable lift, but IMO they are rather unsightly and a pain if you go off road. I am sure camper jacks are OK 99.9% of the time, but it is also obvious to me that they are something that should be constantly inspected, and everyone should probably take more care than they do when loading & unloading to ensure the jacks operate evenly and you are on solid level ground. I wish i knew if the other 2 brands have had similar accidents. I am not trying to pick on Atwood, but having come across 3 accidents involving them you cannot blame me for being suspicious that it is more than coincidence. Part to the reason for posting this is I hope they see this & take steps to maybe increase the gauge of their tubing or reinforce the area under the brackets. That maybe applies to all 3 brands. I am sure all of us would rather pay an extra hundred bucks a jack to have a stronger ones that cannot bend like this. I am going to ask Gordon at TC mag if he can find out what the gauge of metal is in all 3 brands. I personally have Riecos's & have heard of no incidents with them, but then again I don't have access to stats, only what I have seen myself or heard of. I am definitely a lot more cautious these days removing my camper which is fairly heavy. That is another point, I am wondering if jack technology is keeping up with the heavier campers that appear to be out there, or maybe manufacturers are not fitting strong enough models to their campers. Just dividing the weight by four and assuming that is the capacity of jack you should install is not good enough. Everyone knows that you always have situations where the camper weight is on 3 of them since they do not retract evenly. BTW I have 2 photo's now of the one in Mexico being put back on the truck after the truck bed was fixed. he took it to Lance to be repaired, cost about $2k, covered by Mexican insurance, the truck was covered also. He is now getting a stable lift installed. ![]()
Posted By: Seacraft Skipper
on 06/27/10 07:09am
Just looking at the pictures, the truck is a dually. Do the swing out brackets on the front jacks look swung out to you? Bob Seacraft Skipper "Semper Paratus" 2003 GMC 2500HD 4X4 ExCab L/b Air lift A/B. 2002 Lance Lite 915. 1972 20ft Seacraft Sport Fish. |
on 06/27/10 07:16am
They are in the second picture for sure. BTW the damage estimate is 19k. I would not even consider letting anyone but Host repair it. I suspect it will be written off.
Posted By: Jumbo Jet
on 06/27/10 07:23am
Seacraft Skipper wrote: Just looking at the pictures, the truck is a dually. Do the swing out brackets on the front jacks look swung out to you? Bob Yes they are. 2008 Dodge Ram 3500 CTD 4x4 SRW - 2007 Lance 1055 - Torklift Tiedowns, Stableloads, Derringers, Pigtail - Hellwig Anti-Sway Bar - Rickson 19.5" wheels - Michelin XRV tires - Lance Cabover shocks, 2003 Keystone Laredo 29BH
Posted By: PR Connection
on 06/27/10 08:31am
It sure looks like he back in to the right front corner for what evere reason. causing the camper the camper to piviot falling forward because that is where most of the weight is and thus pulling the rear jack off in the direction it did. 2006 3000SL26 Bigfoot Class C 320 Watts Solar With Bluesky 2000 Regulator Four 6volt U2200 Batteries 2000 Watt PSW Magnum Inverter
Posted By: jmtandem
on 06/27/10 09:10am
54suds, I think I was clear that the title of the thread was misleading. As far as Beddows being able to post I don't have anything against him. He could have chosen a better title. |
Posted By: Reddog1
on 06/27/10 09:23am
I am hesitant to make this post, but decided to do so. It is not intended to be a plug for Stable-Lift, but we only have two basic designs in jack selection. The four single jacks or Stable-Lift. There are many possibilities as to why this incident happened. Fortunately no one was injured or killed. I personally do not like the stability of the four toothpicks holding up the TC. I agree with a previous post that the material in the jacks have not kept up with the weights of the TCs. I was motivated to buy my Stable-Lift, when I was loading my 4000 pound TC in the wind, with the four jack system. My ugly Stable-Lift has hit two boulders, and it only scratched the powder coat. It does not wobble like a new born calf, when it raises the TC in the wind. Because the lift points are under the wings, it will not, and cannot tear off like the jacks in the photo. I believe if you backed into the front part of the lift, it would simply push the entire TC backwards, using the "hoop" as a skid. I do find it interesting that many are quick to challenge weights and tires, but are silent on the jacks, other than say the Stable-Lift is ugly. If you are of the belief this could not happen to your jacks because they are not Atwood's, or your TC is not as heavy, you are even at a greater risk. All it takes is soft ground, especially with a soft breeze. You want to use your TC off the truck on the jacks, think about it carefully. I really think using the TC off the truck, on the jacks put people at risk of injury. Wayne |
Posted By: EdFil
on 06/29/10 06:19am
Since the license plate was still on the truck I would belive he was going to load the camper. It is possible that the camper was raised with the front leaning forward and the front leg sunk in the ground since it had no blocking under it. Just saying. Ed
Ed and Fran 2005 F-350 Lariat Xcab DRW 6.0 Diesel 2006 Lance 1191 |
Posted By: iwon415
on 06/29/10 11:58am
Why are the tie downs still on the camper? Looks like operator error. TimH
Posted By: d3500ram
on 06/29/10 12:32pm
iwon415 wrote: Why are the tie downs still on the camper? Looks like operator error. TimH Logically, how could the operator leave the tie downs on and pull away ??? ... the camper would not be able to be lifted off the truck. |
Posted By: RichieC
on 06/29/10 12:39pm
d3500ram wrote: iwon415 wrote: Why are the tie downs still on the camper? Looks like operator error. TimH Logically, how could the operator leave the tie downs on and pull away ??? ... the camper would not be able to be lifted off the truck. Actually, I've left the Fastguns hanging in place before and after loading. It's not a good practice since the rear tiedowns will bump the rear fender on my truck. It may or may not be so on the one in this photo. 2008 Arctic Fox all season 1140 model 2005 F350 6.0 dually with 102,500 miles 85% with camper on. Bulletproof oil cooler and EGR cooler added at 100K Eagle Cap Owners group |
Posted By: Neverhappy
on 06/29/10 03:06pm
I think I am starting to love the square design of my Happyjaks. They don't bend, I had two serious incidents & they tore the camper but no bending. (once the TC fell over when I entered it when fully extended but I had not extended the rear left one...& another incident is when I backed into a low wall and the jack tore off the rear corner) Y2K Silverado 1/2 ton...Whipple Supercharger,SuperSprings Airlifts (I know...) 97 Bigfoot 15C9.5FS ,FastGuns, 2 x 75w Solar 77 Chevy 1 Ton C30 (I love this truck) 2000 Chinook concourse (uncomfortable , badly designed rv ,must get rid of it :-( ) |
Posted By: wp6529
on 06/29/10 05:59pm
Neverhappy wrote: I think I am starting to love the square design of my Happyjaks. They don't bend, I had two serious incidents & they tore the camper but no bending. (once the TC fell over when I entered it when fully extended but I had not extended the rear left one...& another incident is when I backed into a low wall and the jack tore off the rear corner) There is nothing magic about square tubing, it will bend and fail just as round tubing will. In both cases the size and wall thickness of the tube, along with the applied loads are the deciding factor. I think the underlying problem is as I noted before, TC manufacturers building TCs that are too heavy for the available jacks. |
Posted By: d3500ram
on 06/29/10 06:48pm
Theoretically, a round shape will be stronger by virtue of its shape over anything orthogonal given all other things equal. As stated failure (in this case) is probably more a factor of tube thickness. |
Posted By: sleepy
on 06/29/10 07:51pm
the strongest structure is a sphere... then maybe a pyramid... a cylinder is good... a square tube is on down the scale I think about any brand jack has been tested and certified for a maximum weight under specific conditions. We humans are the weak link in the chain.... we don't use our strongest tool... the one between our ears. It is our jobs to maintain our campers and use their components correctly. It would surely be nice if the driver of the truck would tell us the truth about how he caused it. Sleepy 855 St Albans, VT |
Posted By: kcabpilot
on 06/29/10 10:33pm
Not to be nit-picky but I'm pretty sure the strongest structure is a tetrahedron which is the only possible arrangement of four equidistant points in 3-dimensional space. I normally wouldn't know this but I read a couple of Buckminster Fuller books and he really gets into tetrahedrons with a passion. He invented the geodesic dome. 1994 Lance 990 on 1997 F350 PSD Dually "Rhino Haunches" |
Posted By: AnEv942
on 06/27/10 12:46pm
Wow-certainly my worst nightmare realized.. I always have the bed of the truck under the nose of camper when raising to load, when off loading I pull out from under the camper just enough to clear then finish lowereing. For just this reason, hoping that if I lose a jack the truck will 'catch' it. I couldn’t hazard a guess as to what was the cause or contributing cause. I don’t see how if tie downs hadn’t been removed that the truck would have made it out from under that far. I couldn’t raise ours enough with tie downs loosely attached to attempt driving out from under. Possibly though, who knows, twisting the camper, weakening the jack, damage done, tried to get the truck out from under camper it just collapsed. Many possible scenarios. I do see, without any contributing factors, the damage shown easily occurring from the camper rotating as it came down. That much weight- not much is going to stop it, certainly not the other jacks. It looks to me the camper rotated on the left rear jack. As high as I need to raise my camper it would travel at least that far. Why NO ONE is near our camper but me when going up or down. Our camper Most of the weight is on front jacks, I can raise a rear jack of the ground, happens frequently if Im not carefull, never seen a front one even get light, camper twists. Point is I see anything that caused a side load on one of our front jacks (any brand jack) could lead to failure. If not the jack then the mounts. Wether just uneven ground, striking with truck, fatigue. What I did get from this post, I alwasy assumed the camper would topple or tip, but now see as the weight transfers it would indeed cause it to rotate toward failed faiure point. Maybe I need to give my neighbors garage a wider berth At any rate, what ever the cause, i feel for the owner of this rig. Mark |
Posted By: wsdepa
on 06/27/10 03:21pm
OK. Alot of erudite armchair analysis going on. I just have one question. Why are the tie downs - including broken parts, still attached to the camper? Did this responsable camper extend his jacks and then just DRIVE OFF without disconnecting the tiedowns? I do not know this Beddows fellow, but his topic under any circumstance is misleading. I have had NO problems with my Atwoods. I believe that they are the best available. 2006 F-350 S/C 6.0 DRW 4x4 3.73, Airlift,Energy Suspension bump stops. 2005 Lance Max 981,Polar Cub a/c, both awnings, EU2000, Yakima box. http://truckntravels.blogspot.com/ Get in shape America - walk, run, paddle or ride a bike!
Posted By: jmtandem
on 06/27/10 08:19pm
Reddog, Ugly is in the eyes of the beholder. This individual might just rethink 'ugly' as it relates to jacks and Stable Lifts. Before I got the truck bed repaired or replaced with another factory bed, I would make 'lemondade out the lemons' and get a nice aluminum flat bed with storage boxes.....and maybe the Stable Lift. |
Posted By: wp6529
on 06/27/10 09:15pm
A few comments: - Yes, "brown stuff" sometimes just happens, even when you do everything correct, however it is all too common for someone to do something careless or stupid and then try to blame the results on an inanimate object. - The lighter the camper, the less stress on the jacks and the less likelihood of a failure, even if there is a latent defect in one of the jacks. - Use of a TC off truck is entirely safe and supported by pretty much all of the TC manufacturers, but you do need to lower the camper / jacks to the lowest level immediately after unloading. I also put a couple of the small AL tripod jacks under the front corners of the camper and snug them up which helps to reduce wiggle and side loads on the front jacks which normally are the longest and have the most leverage twisting against the mounts. - The StableLift system is bulky and somewhat heavy at a minimum. "Ugly" may not be the best term, but they don't look particularly good unless painted to match the truck. - I believe that part of the jack issue is that TC manufacturers are making TCs that are too heavy for the jacks currently on the market, and the jack manufacturers don't seem to have stepped up to offer a more suitable product. Most of the TC jacks are rated for about 2,000# I believe, and since tripoding on three jacks is inevitable during any lift, three jacks need to handle the load safely. A 5,000#+ camper resting on three 2,000# rated jacks just doesn't have enough safety margin. We need some 4k-5k rated jacks with larger heavier wall square tubes, and longer bodies that attach to the TC at two points to eliminate twisting loads on a single mount point. These heavy TCs should also have at a minimum a full length metal angle in the corners with bolted connections to the jacks, not lag screws. |
Posted By: LanceCamper845
on 06/28/10 06:40am
It looks to me that the ground under the jacks was not stable enough to support the weight of the camper.
2008 Ford F-250 Crew-Cab w/ Camper Package 6.8L V-10 / 5 Speed TorqShift / 4.10 Rear Ride- Rites / Stable- Loads / TorkLift Tie Downs / Fast Guns 2011 Lance 830 |
Posted By: racewave
on 06/28/10 08:09am
Level ground when loading and unloading is very helpful. The ground in front of the camper which the truck will pass over when backing under or pulling out from under the camper is also important. You can raise the camper off the truck bed and start to pull forward with everything lined up, then the front wheels can encounter uneven ground, the truck tilts, the tilt causes the bed to grab and drag the camper. I try and unload only on level ground which is twice the length of my wheelbase. Not always possible, but always more trouble if not.
on 06/28/10 12:39pm
After reading this thread I just realized that I've been driving my truck around for the past three weeks with no rear license plate ![]() From the first set of pictures I see one bent jack and three perfectly straight jacks that are completely torn from the camper, mounts intact. The idea that the camper was just sitting there and suddenly, for no apparent reason, decided to collapse is not easy for me to believe. |
on 06/28/10 12:53pm
Snow River TC wrote: ![]() ![]() ![]() First picture looks like a jack AND camper mounting failure to me! Second and third pictures are CAMPER mounting point failures. The jacks are not damaged as shown in the pictures. On any camper WHAT should fail first jack or the jack mounting point of the camper???? I think the pictures show weak jack mounting points on the camper and pretty good jacks! |
Posted By: BradW
on 06/28/10 01:30pm
Lots of Stuff wrote: On any camper WHAT should fail first jack or the jack mounting point of the camper???? I don't think it was either one. I've seen a lot of photos of TC's flopped on their sides, but none have looked remotely like that. From all the damage, I'm betting on either a meteor strike and/or propane leak. Brad Internet forums only exist to serve their members; never the other way around. 1996 Lance 500 and 2006 F-350 PSD 4X4 DRW Our Truck Camper Photos
Posted By: Raften
on 06/28/10 02:17pm
Perhaps we should put the thread to rest. Whatever the cause of the mess is between the TC'er and his/her insurance company. Considering the location of the accident I am inclined to think it was a Big Foot scratching his/her back against the jack leg.
'01 Dodge 3500 CTD, Lance 1121, Air Bags, Rancho 9000, All Wheels Under Power When Needed, A Few Engine Mods For Increased HP Burning Grease, 800 ft/lbs. of torque from something you throw away.
Posted By: Reddog1
on 06/28/10 02:51pm
Raften wrote: No way, my Bigfoot has been with me all the time.... I am inclined to think it was a Big Foot scratching his/her back against the jack leg. Wayne |
Posted By: Raften
on 06/28/10 04:37pm
Reddog1 wrote: Raften wrote: No way, my Bigfoot has been with me all the time.... I am inclined to think it was a Big Foot scratching his/her back against the jack leg. Wayne So you think but it does hang out in a bad neighborhood while you are away. I hear those Bigfoots are sneaky and elusive. |
Posted By: sleepy
on 06/28/10 04:41pm
Raften wrote: Perhaps we should put the thread to rest. Whatever the cause of the mess is between the TC'er and his/her insurance company. Considering the location of the accident I am inclined to think it was a Big Foot scratching his/her back against the jack leg. Why didn't we think of that Hey everybody... Raften says for us to quit pondering it. |
Posted By: d3500ram
on 06/28/10 09:40pm
Raften wrote: Perhaps we should put the thread to rest. Whatever the cause of the mess is between the TC'er and his/her insurance company. Considering the location of the accident I am inclined to think it was a Big Foot scratching his/her back against the jack leg. This is an incredibly ridiculous statement! I for one would like to know more about the possible causes of the mishap. If there is a real problem and it is just settled "between the TC'er and his/her insurance company" then it is no better than sweeping it under the rug. I live and learn vicariously through others and this thread is no exception. The more we respectfully discuss issues related to RV'ing, the more we learn. If you feel the need to "put this thread to rest" then I submit you refrain from reading it... as for the rest of us, let us gain from the post. |
Posted By: Raften
on 06/28/10 10:08pm
Good grief, I said perhaps. Youall can pull your fangs back in, the full moon has passed.
Posted By: BradW
on 06/29/10 04:55am
![]() I was in Mexico last week when I saw a guy unloading his camper when one of his rear jacks failed. ![]() Brad |
Posted By: Gizmos
on 06/29/10 05:34am
BradW wrote: ![]() I was in Mexico last week when I saw a guy unloading his camper when one of his rear jacks failed. ![]() Brad Well I don't think it was the rear jack that failed, rather it was the fault of the garbage can. Being a structural engineer and seeing how the one piece of wood is laying up against the bush by the right rear of the camper there is no doubt that the garbage can caused it all, now if the can had been turned around then I doubt it would have happened 2004.5 Chevy 3500 CC D/A DRW 2002 Lance |
Posted By: ryoung
on 06/29/10 05:55am
I'll bet that woke up and rattled the neighborhood! ryoung |
Posted By: DIYGuy
on 06/29/10 05:56am
Observations for those interested. The front left jack is bent, all the other are straight. The reasonable assumption is that the left front buckled, and as the leg collapsed, the TC pivoted on the bent leg, placing a lateral load on the other three, destructively removing them from the TC. Once the motion started, the resulting damaged legs provided less resistance to the motion, it accelerated until making contact with the pickup truck. The ladder in the back is an optical illusion. The camera angle hides the position of the lower mount point of the ladder. As the leg was pulled to the rear, the lower edge stayed with the leg as it was moved to the rear and upward. (Look at that element compared to the door threshold.) That leaves us with how could the front leg buckle that way? Without seeing a picture of the ground where that leg was planted we can only surmise one of two events, the leg got shorter, or it sunk into the ground. In either case, the load would have shifted more weight onto the leg and as it got shorter, the load would not have been centered over the leg foot, but at an angle. Once the support got far enough outside of the leg, it buckled. I don't see it any more diffcult that soft soil under the front left leg (operator error), or a shortening of the support leg (mechanical failure). Full-Timers, Class of 2014 2002 Volvo VNL770 Toter - Optimus Prime 2007 SpaceCraft - Just Weight CEO App2Droid
Posted By: ryoung
on 06/29/10 06:01am
DIYGuy wrote: Observations for those interested. The front left jack is bent, all the other are straight. The reasonable assumption is that the left front buckled, and as the leg collapsed, the TC pivoted on the bent leg, placing a lateral load on the other three, destructively removing them from the TC. Once the motion started, the resulting damaged legs provided less resistance to the motion, it accelerated until making contact with the pickup truck. The ladder in the back is an optical illusion. The camera angle hides the position of the lower mount point of the ladder. As the leg was pulled to the rear, the lower edge stayed with the leg as it was moved to the rear and upward. (Look at that element compared to the door threshold.) That leaves us with how could the front leg buckle that way? Without seeing a picture of the ground where that leg was planted we can only surmise one of two events, the leg got shorter, or it sunk into the ground. In either case, the load would have shifted more weight onto the leg and as it got shorter, the load would not have been centered over the leg foot, but at an angle. Once the support got far enough outside of the leg, it buckled. I don't see it any more diffcult that soft soil under the front left leg (operator error), or a shortening of the support leg (mechanical failure Good theory, but I would have thought that if the left front leg collapsed for either reason you give, then the weight on the opposite corner leg, (right rear), would be reduced. With the left front down, the weight would be distributed more on the right front and left rear legs. Hence the right rear leg, would just have dragged through the soil. The missing piece is that there is no picture of the right front leg. ryoung * This post was edited 06/29/10 06:11am by ryoung * |
Posted By: bobndot
on 06/29/10 07:39am
DIYGuy , i think your right. I saw the same thing happen to my friends tc only the RR jack bent the same way causing the tc to tip over to the rearward right, into his shed . His front jacks sustained damage in the same direction as the rear jacks in this posters photo . What caused the jack to bend ? Over a period of time the jack mounting plate leaked water into the corner framework causing the wood frame to rot. The lag screws ripped out, the jack tube then bent causing the camper to tip in the direction of the now broken jack . Upon inspecting the lag screws we noticed rust on the threads that should not have been there. The camper was being stored at the time of occurrence , there was no movement on his part, it happened all on it's own , possibly helped by a gust of wind. In his case the ground was solid and the jacks had large wooden pads to support the feet . When we inspected the framework in the faulty corner, it was in fact rotted by water intrusion. The rot was at the level of the jack plate, no higher , it didn't come from above and drip down to a low point. I noticed in this photo, it appears that some caulk was added along the bottom seam near the jack plate. The owner may have had a prior indication of water damage and thought it was entering along that seam not paying attention to the jack plate or the lag screws which 'no not' appear to be caulked . Since that occurred to my friend and by the advice of others on this forum i now caulk my jack plates as well as the heads of the lag screws. I think it is an important step for anyone that owns a tc . I would like to say thank you to the people who contribute to this forum. The last thing anyone needs is to have a 4000# box fall over and cause a serious or fatal injury to someone. Maybe that's one of the reasons why some CG owners do not allow campers to be taken off trucks . Not all tc owners try to maintain them as we do . Scary isn't it ? Stay safe to all, Bob . |
Posted By: AnEv942
on 06/29/10 09:33am
ryoung wrote: Good theory, but I would have thought that if the left front leg collapsed for either reason you give, then the weight on the opposite corner leg, (right rear), would be reduced. With the left front down, the weight would be distributed more on the right front and left rear legs. Hence the right rear leg, would just have dragged through the soil. The missing piece is that there is no picture of the right front leg. ryoung No its there- Pic of right front is last one in group
01 Ford 250 4x4 DRW Diesel, 01 Elkhorn 9U Our camper projects page
Posted By: ryoung
on 06/29/10 09:46am
AnEv942 wrote: No its there- Pic of right front is last one in group Thanks for pointing this out. I'll have to re-think this one. ![]() ryoung |
Posted By: Tayook
on 10/16/10 06:54pm
Newbie question ... the TC we have now has Riecos on it, that have a horizontal mounting plate that the camper "sits" on. What is the appeal of the new jacks that are mounted to the corners of the TC? Seems like it would be a weaker bond, when I think about holding something, I think it is easier to grab underneath and hold than to put my hands on each side and hold. Or am I missing something? |
Posted By: lawndude
on 10/16/10 08:14pm
Good question and welcome newbie. My answer? Beats the hell out of me. Gonna have to get some old timers on this one.
Posted By: lawndude
on 10/16/10 06:59am
Silver, Thats good enough for me. As far as the manufacturer making a jack thats worth it's salt I could not agree more. Don't mean to sound off here but, I think the attwoods are junk and are always a hair away from a disaster. They scare the hell out of me and I'm not afraid to admit it. [I mean no disrespect when I say] Even you old salts that claim no problems at all in years take a deap breath once the job is done. [up and down I mean] I'm no engineer but even I can see a couple of points to work on. A removable heavy duty support rod even on the swing outs would not be a bad start. Perhaps a self extending rod with lock-in increments on it from the center to the side so as to provide support when lifting. As the camper goes up the rod clicks its way down. If you can visualize what I mean. The stablelift is an amazing product but, $3000.00 cost, $400.00 shipping, self installation if you don't want to go to Montana, 400 lbs weight on top of your $30,000.00 purchase and it is'nt the prettiest thing out there. I think we should join forces and force this issue, there's enough of us to get some ones attention. Joe |
Posted By: Gary3
on 10/16/10 07:11am
That removable support sounds like a good idea it wouldn,t add much cost to the camper.
Gary Lance 1191 solar Gen. |
Posted By: KKELLER14K
on 10/15/10 10:07pm
I'm of the opinion that the front jack foot was possibly sunk or was sinking into the ground at the moment it went over. If the front left sank in just far enough rendering it off balance enough to topple it over, the front left one would bend, the other rears which look as if were resting on stacked boards,(look at the first pic at the right rear on the ground), would cause the rear jacks to dig into the ground once in motion falling off the boards, causing the seperation you see at the rear. I noticed that you really can't see any of the feet in the pics and the one good pic of the front left, you can't see the foot at all, it's burried into the ground. It is also possible that it was just jacked to high in the rear for the fronts to support the TC. MMMM....
* This post was last edited 10/15/10 10:31pm by KKELLER14K * |
on 10/16/10 04:42am
...I've been studying the photos of this incident now for 3 and a half months, and I've come to the conclusion that this camper's corners (thus structural jack attachment(s)) are utterly rotted beyond belief. There is nothing (IMO) that could have prevented the collapse of that and those jacks, and, connections thereto and resultant seemingly disastrous rear wall collapse (I also looked at numerous photos of truck campers that had rolled, been in accidents and had suffered jack(s) letting go posted here over the years as a comparison). Whether the camper was nudged, blown, through telekinesis or otherwise, subjected to S or P waves from an earthquake or swallowed in part by unstable clay was (nearly) irrelevant. That sucker was a disaster waiting to happen. Point finale. Silver- |
Posted By: bwaner
on 10/15/10 09:29am
Just curious, but if it was the left front Jack that started this failure, then wouldn't,t the camper have raised the right rear Jack off the ground and not tearing it off as the pictures suggest. It appears to me the camper was dragged.
on 10/14/10 11:45am
ANYTIME you all! Just trying to help out here. I have had a few hair raising experiences having my TC shift forward and watching the swing outs flex beyond my comfort zone. I had it so I did something! I'm surprised that jack makers and TC manufactures haven't come up with a better solution being that larger TC's are pushing the 5000 pound mark. It is a miracle that this hasn't killed anyone that I have ever heard of, but by the photos I've seen, it appears it's only a matter of time...Maybee this might be a niche after market part... or just as a safety measure, the builders should come up with their own. Even if you don't have swing outs, you could still stiffen those fronts and it would give anyone a little piece of mind. Just another quick idea. If you didn't want a brace on their permanently, you could make one that just clamps on the tube, or bolts on like the Happijac, and uses the eye of the hold down after you take the fast guns, hooks and chains, whatever you use, off. MMMM am I on to something here??
* This post was edited 10/14/10 07:52pm by KKELLER14K * |
Posted By: lawndude
on 10/13/10 05:01am
Keller that's a great mod. I've been looking for something to calm my nerves now since I got my 1181. I was looking into the stable lift but it's to expensive for me rite now. I built my own wobble stopper for this camper and I suppose I could modify the arrangement to incorperate extra support while traveling up and down. Youve given me alot to think about. Thanks, Joe
on 10/12/10 11:54pm
This would be a good time to plug my mod. Front jacks, especially with swing out brackets, need to be better supported no matter who makes them. Any front jacks, especially with swing out brackets, should have better support lower on the jack tube. This is what I did with my front Happijacs: Lucky I had a place to mount the support to. |
Posted By: bluearc
on 10/13/10 03:35am
ryoung wrote: I don't see this as an Atwood jack failure, but a structure failure to which the jacks were mounted. It appears the initial failure was in the mounting points. Just my guess. What caused the failure of the mounts? If he left the front left tie down hanging from the camper, it could have caught the corner of the truck bumper, dragging the camper forward as the condition of the right rear jack suggests. ryoung I agree, looks like the mounting failed first which led to the post bending. In my opinion the verticle force (weight) of the camper would never be enough to bend the pipe (post) in that manner, something else happened here. |
Posted By: lawndude
on 10/11/10 06:20pm
OK late again. I am in the midst of squaring off my front drivers side attwood jack and was looking for some ideas and help. I got what I needed from woodalls chat site from sleepy; same person over on this site I assume. Sleepy I did exactly what you did and it worked out perfect, If your the same sleepy thanks a lot!!! Any way getting back to the talked to death analysis of the fallen camper. #1 There's more wood rot on this camper than I've ever seen. Picture #4 {from the top} shows that the wall itself failed; The jack mount, and the jack itself did not fail, It pulled rite of the frame of the rotted camper in a perfectly assembled piece. I mean you can see the entire rear panel is rotted. The jack itself came off in one complete unharmed piece. #2 The two rear jacks did not slide forward at all. With the frame of the camper giving way the passenger side of the camper simply hit the ground and forced the front same side jack to buckle. All 5100 lbs pushed forward. #3 Look at the way the truck was hit. The camper cabover corner landed inside the truck bed. Then the weight of the camper forced the other side front jack to buckle in exactly the direction the weight is continuing to fall, forward. With the other jack buckled, the weight shifts. Pulling the cabover out and down from the inside of the truck bed, settling in the truck bed pushing the truck side wall down and out. Not down and in. He simply had the truck off to one side while moving the plate. It picked that exact time to fail. He's lucky he did not get crushed. #4 One more thing in the photos you can see where there is putty or caulk over some of the seems. This amount of rot started long ago. There was no fault here. The camper simply has seen a better day. Thats my two sense. Thanks guys, Big Joe PS, I do the same thing with my plate removal, Not any more! And the gang will stay far away while loading and unloading. * This post was edited 10/11/10 06:31pm by lawndude * |
Posted By: 3 tons
on 10/11/10 10:02pm
Lawndude, What is this 'plate' thingy and 'plate removal' you're referring to?? I must be having a senior moment! Thanks, 3 tons |
Posted By: scottz
on 10/11/10 10:22pm
Snow River TC wrote: ![]() Interesting the rear step is down. I suspect either the camper was in use with the legs extended, resulting in fatigue/damage from improper use. Or we are not getting the complete story. 2004 Silverado 2500HD,LB,Gas,4x4,Air-Bags, Hypertech III, Rancho 9000X/XL, Michelin LTX MS2 265/75-16 2005 Lance1030, Happijac Tiedowns, Lifeline AGM Batteries, Yamaha EF2400iS Generator 2006 Tritontrailer ATV168 4pl, 2001 Kodiak, 2003 Trailblazer |
Posted By: lawndude
on 10/12/10 03:05am
3 Tons, I'm talking about the liscense plate removal from the truck to the camper. The original contributer said thats what he was doing when all this happened. Joe
Posted By: 88lover
on 10/12/10 09:05am
Not poositive but I suspect that the camper was not lifted far enough and the back was still in contact with the bed of the truck. I find this problem when camping on unlevel sites (especially when the ground at the rear is higher than the area in the front). In this case I have had to put blocks under ther rear jacks. I believe the Attwood jacks are OK for vertical loads. As far as side stress, my jacks held up during a hurricane. I suspect rot also.
Posted By: sleepy
on 06/30/10 03:38am
kcabpilot wrote: Not to be nit-picky but I'm pretty sure the strongest structure is a tetrahedron which is the only possible arrangement of four equidistant points in 3-dimensional space. I normally wouldn't know this but I read a couple of Buckminster Fuller books and he really gets into tetrahedrons with a passion. He invented the geodesic dome. a tetrahedron is the hardest to turn over... but not the strongest. I know about Bucky... I bought copies of all of his patents many years ago. I built a 30 foot diameter geodisic dome in 1974, It was an icosahedron... with each face subdivided by 5 panels on an edge. I truncated it approx 5/8 ths of the way down from the apex. BTW, An icosahedron has 12 verticies. I'd be happy to post pictures when we return home in a few more months. All of that aside... a sphere is the stronest object of all. Even the shortest straight edge is a weakness... even on an atomic level. (BTW... just for general info.... a dodecahedron looks like a soccor ball) sleepy 855 St Albans, Vermont |
Posted By: ticki2
on 06/30/10 04:09am
Interesting that only one jack bent and the others were stong enough to rip the camper apart .
'68 Avion C-11 '02 GMC DRW D/A |
Posted By: DIYGuy
on 06/30/10 05:33am
ryoung wrote: Good theory, but I would have thought that if the left front leg collapsed for either reason you give, then the weight on the opposite corner leg, (right rear), would be reduced. With the left front down, the weight would be distributed more on the right front and left rear legs. Hence the right rear leg, would just have dragged through the soil. The missing piece is that there is no picture of the right front leg. ryoung I think the pictures show that the right front and left rear legs were torn out. When those failed, weight and motion was shifted to the right rear leg, which then was pulled out. In the picture of the rear of the truck, the right front leg is partially visible as point out at ~45 degrees from the body, which would be consistant with forces experienced and the left front buckled and the rig moved to the left. As the rig tipped, the CG would have shifted toward the collapsing leg as it first pivoted. It is possible that the right front pulled away from the body simultaneous to the buckling of the left front. All of the photographic evidence is still consistant with a shortening of the left front leg as the initial event. |
Posted By: jmtandem
on 06/30/10 09:14am
Brad, Great picture. It looks like about the only thing that did not fail are the jacks (at least the ones in the front). |
| Print | Close |
