| Open Roads Forum |
| Print | Close |
| Topic: Filter & fluid change Allison 3060 transmission? |
Posted By: The Beave
on 06/26/10 06:08am
My Allison transmission manual ('97) calls for Dextron II, which is no longer available. Is there any particular brand or spec Dextron fluid Allison recommends for the 3060 transmission? The Beave 30' 1997 Beaver Monterey (The shortest DP we could find) 2005 Honda CR-V Remco surge brake
Posted By: imgoin4it
on 06/26/10 06:14am
Call them but I think they will tell you to switch to Transyd.
Retired and loving it ![]() ![]() Living in the Land of Enchantment Traveling in 2007 Newmar KSDP towing a Jeep Liberty with a Blue Ox tow bar |
Posted By: BaldyD1
on 06/26/10 07:08am
Switch to Allison's synthetic as noted above.
Speedy, Jackie & Dusty {Shih-Tzu/Maltese} 2006 Kountry Star KSDP 3912 2005 Saturn Vue (dinghy) |
on 06/26/10 07:33am
imgoin4it wrote: Call them but I think they will tell you to switch to Transyd. If budget were no issue I would go with Transyd, but needing almost 5 gallons at $40-$50 per gallon, thats more than I feel like spending. |
Posted By: Sully2
on 06/26/10 07:51am
The Beave wrote: My Allison transmission manual ('97) calls for Dextron II, which is no longer available. Is there any particular brand or spec Dextron fluid Allison recommends for the 3060 transmission? Dexron III is perfectly compatible. 2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless 2002 Jeep Liberty
Posted By: wolfe10
on 06/26/10 08:32am
Price the 5 gallon pail. That is what you need (on mine leaves one quart left over).
Brett Wolfe 1997 Safari Sahara 3540 EX: 1993 Foretravel 36' U-240 FMCA Forum: www.community.fmca.com/index Diesel RV Club:http://www.dieselrvclub.org/ |
Posted By: Devocamper
on 06/26/10 06:03pm
Not sure about your 3060 but there was a list of serial numbers and at a point on the list they did not recommend using the newer dexron fluids something about the new fluid and the older seals in the transmission this of course was on the Allison in my truck which I think is the 2000 better check with Allison they have a pretty good website. They were talking about dexron VI which is the current standardand that was backwards compatible
08 NU-WA Hitchhiker Discover America 339 RSB 07 Chevy 3500HD LT1 EXT Cab LB DRW D/A |
Posted By: Dog Trainer
on 06/26/10 06:56pm
Sully2 wrote: The Beave wrote: My Allison transmission manual ('97) calls for Dextron II, which is no longer available. Is there any particular brand or spec Dextron fluid Allison recommends for the 3060 transmission? Dexron III is perfectly compatible. My last 2 changes were with dextron 3 no problem in 35,000 miles 93 Airstream 35' Dp 5.9 230 uprated to 300 HP Allison MD 3060 Dutchess and Shadow Golden's Daktari Cavalier King Charles (fur Bearing Children) |
Posted By: Sully2
on 06/26/10 09:14pm
Devocamper wrote: Not sure about your 3060 but there was a list of serial numbers and at a point on the list they did not recommend using the newer dexron fluids something about the new fluid and the older seals in the transmission this of course was on the Allison in my truck which I think is the 2000 better check with Allison they have a pretty good website. They were talking about dexron VI which is the current standardand that was backwards compatible Dexron III OR Dexron IV is usuable where Dexron II was used....but NOT Dexron V or VI |
Posted By: Sully2
on 06/26/10 09:15pm
The Beave wrote: imgoin4it wrote: Call them but I think they will tell you to switch to Transyd. If budget were no issue I would go with Transyd, but needing almost 5 gallons at $40-$50 per gallon, thats more than I feel like spending. I just bought the filter kit and 5 gallons of Transynd here and it set me back $175 for the total |
Posted By: jtfcons
on 06/27/10 08:02pm
Sully2 wrote: The Beave wrote: imgoin4it wrote: Call them but I think they will tell you to switch to Transyd. If budget were no issue I would go with Transyd, but needing almost 5 gallons at $40-$50 per gallon, thats more than I feel like spending. I just bought the filter kit and 5 gallons of Transynd here and it set me back $175 for the total Did the same here but set me back $256 through Allison dealer. The cheapest I could find. John & Sharon, 2 Daughters, 2 Sons-in-law, 5 GK Scottish Terrier (Chloe) 1997 HR Imp., 38CDS, 1 Slide 325 Cummins C8.3Mech., MD3060, EBw/Coast.Sw., Toad-98Tracker 4X4 or 03GMC Envoy 4X4, Excallibar TB, Pressure Pro TPMS, Henderson Mot. Ctrl. Units
Posted By: 80psi
on 06/27/10 08:14pm
Hey Sully2, Will you tell us where you got your $175 deal on the oil and filters? Thanks, I need to do a service on my T3000.
Posted By: Sully2
on 06/28/10 11:41am
80psi wrote: Hey Sully2, Will you tell us where you got your $175 deal on the oil and filters? Thanks, I need to do a service on my T3000. Clark ( used to be Detroit / Allison) |
Posted By: 80psi
on 06/28/10 05:57pm
Thanks for the info.
| Print | Close |
