RV.Net Open Roads Forum: Travel Trailers: How to level a dual axle TT.
 > How to level a dual axle TT.
Segwin
Storage
Posted: 07/13/10 01:39pm Link  |  Print  |  Notify Moderator
With the class C it was pretty straight forward on how to level the rig on a not so level site.
Rather than reinventing the wheel I'm hoping others can chime in with what works and what doesn't when it comes to the subject. I've already purchased three lengths of 2x8 PT planks - just wondering about the right way to do it for a dual axle.
Thanks again all.
Terry
Cybergrunt
Cedar Rapids, Iowa
Posted: 07/13/10 01:45pm Link  |  Print  |  Notify Moderator
I take care of side-side level first using scrap dunnage. Then I level the trailer out (front-back), but leave it just slightly nose down. I put my stabilizers down (which are actually old full-sized car jacks) in the back and then bring it into level with the tongue jack and front stabilizers.
2001 Coachmen 248TB
5880 GVWR 3768 UVW 4980 GVW 650 Tongue weight
2003 GMC
5.3/3.73
13000 GCVWR 4932 curb 1468 cargo 6400 GVWR 7800 towing 6010 GVW 10340 GCVW
USMC (Ret.)
SEMPER FI!
eric james
Sioux Falls, SD
Posted: 07/13/10 01:52pm Link  |  Print  |  Notify Moderator
I use short 15" planks. I get the trailer positioned where I want it then check the level. If it's way off I use 4x6 plank, a little = 2x6 plank.
I pull the trailer forward 15-20", place the planks behind the wheels on the trailer then drive up on them. Check level again and adjust if necessary. I always raise both wheels.
I can't chock the raised side this way so the scissor style locks are ideal.
I chock the opposite side, both axles before unhooking from tow vehicle. Then level front rear and run down the stabilizer jacks before anyone starts jumping around in the trailer.
Another tip. Level side to side with the slide(s) out. Once the slides go out, the weight shifts and you can be off again.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
mking
Indianland,South Carolina
Posted: 07/13/10 01:54pm Link  |  Print  |  Notify Moderator
To tell ya the truth I check from side to side and then adjust with only 1 board on the low side.I carry a 2x8x7 and a 5/quarterx6x7 board and either use one or both boards under both tires on one side.This has always worked for me.
2006 Dodge Quad-Cab 2500 CTD,4;10 gears,pulling a Forestriver Flaggstaff 831qbss
TowHaul
Ontario
Posted: 07/13/10 01:55pm Link  |  Print  |  Notify Moderator
Your three 2x8's should each be a different length with the shortest one long enough for both wheels to sit on with about 6-8" left over front and back. The next length should be about 6" longer than the short one, then the last board should be 6" longer than the middle one.
Park your trailer were you want it to be, then calculate which side you need to raise and how much. Stack your boards as necessary beside the low wheels - the longest one on the bottom and the shortest one on top, of course. The "back" end of the boards should line up so that the different lengths form sort of a ramp at the "front" end.
Pull forward until the wheels are past the boards then place the boards behind (in line with) the wheels. Slowly and carefully back up until both wheels are on the same level.
It's best if you have a spotter to tell when to stop before the back wheel drops off the end of the board.
2009 Cikira Classic Cruiser 21R
2007 Jeep Commander Hemi
Trailing Away... our travel blog
downtheroad
Pacific Northwest
Posted: 07/13/10 02:06pm Link  |  Print  |  Notify Moderator
Good advice from the above posters.
Instead of lumber, you can also use these. They are light weight, easy to store, strong and very versatile..
Lynx Levelers.
"If we couldn't laugh we would all go insane"
GMC Duramax/Allison (LBZ)
Komfort .... Our Rig Picture>>Click.
Reese Dual Cam HP
keithinspace
Fredericksburg, VA
Posted: 07/13/10 02:31pm Link  |  Print  |  Notify Moderator
Lynx Levelers. Never once did I bother with wood. Too heavy to trailer, difficult to stack, and unwieldy to store.
I installed some sticky levels on the front and side, so I even have it down to how many levelers I need to adjust my trailer...stack 1 for one degree, 2 for two degrees, or thereabouts. One stack and one pull and I'm in like Flynn.
I do also have cross-chocks between the wheels...I don't trust it to the stabilizers or anything else to not have the trailer roll off my little stack of Lynx Levelers. That's about the only downside. Not a biggie, though. Measure, stack, pull forward, check, chock, jack, unhook, level front-back, deploy stabilizers, and hook up. That's about it to parking for me.
2011 Gulf Stream Ameri-Lite 255BH
Hensley Arrow
2005 Ford Expedition Eddie Bauer (3.73 and Towing Package)
Me, Wife, Girl (7 YO), Boy (5 YO), Blind Beagle (92 YO), Tuxedo Cat (1 YO; 7 lives remaining)
Segwin
Storage
Posted: 07/13/10 03:00pm Link  |  Print  |  Notify Moderator
Wow - now that's good thinking. Good stuff!
bob213
Fresno, CA
Posted: 07/13/10 03:24pm Link  |  Print  |  Notify Moderator
I use the Lynx Levelers also. I added some no slip grip tape to 4 or 5 of mine to use as the bottom of my buildup ramp. This way they won't move when you back up on them.
No Slip Tape
Bob and Sue
w/ 4 legged child Jerry
ron the newbie
new york
Posted: 07/13/10 04:07pm Link  |  Print  |  Notify Moderator
Lynx Levelers here as well. Just figure out the height needed and pull the TT on top of them. EASY!
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
