RV.Net Open Roads Forum: Truck Campers: Regular cab COG
 > Regular cab COG
socal
san diego, california, usa
Posted: 07/13/10 08:00pm Link  |  Print  |  Notify Moderator
hello,
wondering about the center of gravity? have seen it mentioned several times and has got me to thinking. i have a regular cab 1 ton dually on order and curious if i need to be aware of this COG? when i get my slide in camper i would like a northern lite if i can find one. had one before and wish i would have kept it.
any info or advice on the center of gravity on this dodge CTD and camper?
thanks,
david
socal
Itchey Feet
Wyoming
Posted: 07/13/10 08:16pm Link  |  Print  |  Notify Moderator
The COG should be marked on the TC, as long as (when loaded) the COG on the camper is just @ or forward of the rear axel then that part is no longer a worry. Where the problem comes is when some one puts a 8' or longer camper on a truck that has a short box on it and the COG ends up being behind the rear axel and the extra overhang of (weight) starts "unloading" the front axel and you end up loosing traction on the steer tires. JMHO
My feet are fine as long as they are traveling.
mkirsch
Rochester, NY
Posted: 07/13/10 08:51pm Link  |  Print  |  Notify Moderator
Cab style is irrelevant with respect to the camper's CG.
Your truck's owner's manual will explain camper CG, but in a nutshell, the CG is the "balance point" of the camper. The balance point of the camper needs to be very close to the REAR axle on the truck. Preferably, directly over or slightly ahead.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
~DJ~
Boise, Idaho
Posted: 07/14/10 07:04am Link  |  Print  |  Notify Moderator
I have to respectfully disagree. Cab style does make a difference with regards to the weight on the front axle. My last outfit was a standard cab Dodge dually and I carried a S&S camper designed for a crew cab. My camper GOG was 18" ahead of the rear axle.
It would have been fine on a CC but with the SC my front axle was overloaded with all ready supporting the Cummins. I ended up moving the camper back a few inches shimmed with treated 4x4's and removed several hundred pounds from my front axle.
This is something the OP needs to consider since he has a standard cab on order.
As you can visualize from this photo, had it been a CC not so much weight would have been put on the front axle.
2011 F250 Super Cab Lariat 6.2 373 FX4 Short Box 4" BDS, 35" Toyos, TorkLift, 16.5K Warn, Locked & Loaded
2007 SunLite Pop Up
26th Marines RVN 69-70 Semper Fi
M-14 was the only Woodstock I saw in 1969.
JANE CALL HOME
1 800 HANOI
woodhog
NS
Posted: 07/14/10 07:22am Link  |  Print  |  Notify Moderator
This was also my case, I liked this because it allows me to position the camper towards the rear of the truck, throw in a few pieces of wood to keep it from sliding ahead and then I have a lot of extra storage space between the front of the camper and the cab of the truck.
I put a lot of dirty stuff in their like jacks, axes etc.
2004.5 Dodge 4x4 SRW Diesel 3750 Lb NITTO tires Bilstein Shocks
Torklift Stable loads BD Steering Stabilizer Bar Superchips Programer
2006 8.5 Northstar Arrow Longbox 200 Watts Solar Trimetic Battery Monitor, LED lights.
Tundra 42... 12 Volt DC Fridge
socal
Posted: 07/14/10 07:03pm Link  |  Print  |  Notify Moderator
DJ,
in your picture is your camper shimmed? it appears to be sitting just fine on the truck. also 2x4s or 4x4s work?
thanks for the information.
david
socal
ticki2
NH
Posted: 07/14/10 09:39pm Link  |  Print  |  Notify Moderator
Not to be nit picky but the COG of the camper didn't change with the different truck configuration , only where it was applied to the truck ( different wheel base )
Question , what was the COG dimentions for your S&S ?
'68 Avion C-11
'02 GMC DRW D/A
~DJ~
Boise, Idaho
Posted: 07/15/10 05:21pm Link  |  Print  |  Notify Moderator
socal wrote:
DJ,
david
socal
Yes, this pic may show it better. It is shimmed 5" back from the front of the box with treated lumber. I used a 4x4 which is really 3 1/2 by 3 1/2 and a 2x4 which is really 1 1/2 so total was actual 5". I spent considerable time at a closed state weigh station moving the camper back and forth on the truck to get the measurements I needed to relieve the weight from the front axle.
ticki2, no the GOG of the camper does not change. But it will affect different trucks differently. The OP was asking about a single cab and this was my experience.
I don't have the camper anymore to measure but if you look at the pic right behind the propane door on the bottom edge is a blob. That blob is a red arrow showing the COG of this camper.
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/16/10 07:27am Link  |  Print  |  Notify Moderator
To find how much weight will be added to the front axle, you need to know the weight of the camper, the wheelbase length of the truck and the position of the camper's center of gravity in relation to the truck's rear axle center. This can be used for figuring weight a gooseneck or fifth wheel trailer will add to the front axle as well.
Take the number of inches the camper center of gravity is ahead of the rear axle (or number of inches the fifth/gooseneck hitch is mounted ahead of the rear axle), divide by the wheelbase length in inches, and then multiply by the weight of the camper (or hitch weight of goose/fifth trailer).
Ld = Load Distance Ahead of Rear Axle
Wb = Wheelbase Length
C = Camper Weight (or 5th/goose trailer hitch weight)
F = Load Weight added to Front Axle
(Ld/Wb)*C = F
For example, if you have a crew cab long bed truck with 170" wheelbase, your camper weighs 3000 lbs and it's center of gravity is 12" ahead of the rear axle, then 12/170*3000 = ~212 lbs added to the front axle.
If the same camper is put on a reg cab long bed truck with a wheelbase length of 140", then 12/140*3000 = 257 lbs added to the front axle.
In this example, the difference is only 50 lbs for crew cab versus regular cab with the same camper and bed length, which is hardly anything to be worried over.
The weight of the heavier crew cab itself versus the lighter regular cab will add more weight to the truck's front axle than the camper will, so the crew cab truck will have a heavier front axle weight than the regular cab truck will, even with the same camper loaded on each truck in the same position.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/16/10 07:32am Link  |  Print  |  Notify Moderator
That was such a nice truck and camper you had there, DJ.
 > Regular cab COG
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
